Question about Motorola Mobility ROKR E6 Smartphone
On Miele w770 washer, the open door button, when
On Miele W770 (1986) washer, the open door button, when pushed, slightly depresses the start button and will not open the door. I adjusted the large Allen wrench screws inside door to no avail. Have to open it with the pull ring at bottom inside removeable grill. Have remounted the latch inside the door and know how to remove the ring gasket if necessary. It seems to be an electrical relay problem. Any ideas? captbobm@live.com All in all, a GREAT machine - 23 years of many loads a day......
Door seems slightly out of alignment and machine wont start.
manufacturer & model number? seems like the door switch (push button) if there is, is not totally depressed when door is closed. if the door hinge mounting screws are accessible you might be able to realign the door. loosen the screws, temporarily put a spacer to help line up (aligned) before tightening screws. (or tape a thin spacer on door to totally depress the switch)
Oct 08, 2015 | Washing Machines
How to unlock washing machinge
Question is somewhat ambiguous, since in normal operation the door "unlocks" when the cycle is finished and the orange DOOR button is depressed. To manually open the door mid-cycle or with no power, find the yellow plastic tool attached to the soap tray and use it (or something similar) to pry open the front access panel at bottom left. There will be a plastic ring projecting downward into the cavity behind this panel: pull it sharply downward and the door should open.
Jul 11, 2014 | Miele Novotronic W1918A Front Load Washer
Miele washer softtronics door will not open
go to this page and proceed according:
http://www.ehow.com/how_8562942_remove-door-miele-washer.html
God bless you
Jul 18, 2012 | Miele Washing Machines
Miele Novotronic W 832 washer won't turn on. It suddenly turned off after trying to open the door and now it won't turn back on. I tried switchinging powersources, didn't work.
Make sure the door is properly closed!!! The door opener is electric, and the electrics are turned off unless the door is properly closed, hence with the door closed but not fully "home" you will neither be able to re-open the door nor wash what is in the machine. Just give the door a firm push closed and it should spring to life.
Apr 27, 2011 | Miele Novotronic Premier 500 Front Load...
We have a Miele W701. We just finished a load of laundry and the door won't click open. The electricity is on and I cannot see any other problem with the machine.
The most common cause for this problem, is the Electro Magnetic Door lock, itself. The part may cost about $170, new. However, you can open the door manually, from the bottom side of the washer. Other causes may be a defective "push button switch," or drainage problem. In a drainage problem, water sitting inside washer, won't allow the user to open washer door, until the water is manually drained out. Good Luck.
Nov 17, 2010 | Miele Novotronic Premier 500 Front Load...
'Close the Door' on Miele WT 2670
Door lock faulty or wires to lock adrift.
Mar 06, 2010 | Miele WT945 Front Load Washer / Dryer
Miele W770 washing machine won't cycle through
Hi Sandy,
I had the same problem and some time later it stopped completely. The probmlem is in the Prorammer.
UNfortunately it is very hard to find because the appliance is very old. If you find one, I can tell you in detail what is the sequence to change it.
Sep 14, 2009 | Washing Machines
Washing machine door won't open!
I have the same machine and the door won't open using the button. Speaking with technicians gave me a very expensive fix. However, there is an easier solution:
If the bottom panel is removed, just underneath the door there is a protruding section with a "T" slot in it. Inside that is a ring. If that is pulled down it will open the door. I've been using a screwdriver for almost 2 years now.
Good luck,
Andy
(Portsmouth, NH)
Jul 14, 2008 | Motorola Mobility ROKR E6 Smartphone
HE3t wont start
open the top access panel, 3 screws in top rear.
start washer
push up gently on one of the center black wired connectors that connect to the control unit (in back top of washer)
if it starts to work then the relays on the control circuit board need to be re-soldered . a normal reoccurring issue
its rarely the latch
Mar 21, 2008 | Kenmore Elite 45986 Front Load Washer
Motorola Mobility ROKR E6 Smartphone Logo
79 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
