Question about Kitchen Appliances - Others
We are looking to replace the ''washer'' that goes under the paddle in the bread pan in the fan assisted breville bread master model no. BR3
Bought a replacement machine.
Posted on Apr 19, 2009
Is there anything I can do?
I don't know about your specific model, but in most bread makers there is a removable paddle that goes in the bottom of the bread pan after you put that in the machine. The paddle usually has a flattened side on the hole which slides on to the post sticking up from the bottom of the machine. If you look at the post straight down from above it should be D shaped. The usual procedure is to put the pan in the machine, install the paddle, and then add your ingredients. Assuming you are doing this and it is still not working, trying running it through a mix only cycle (like for pizza dough) with the machine empty to see if the paddle is engaging and spinning properly. If it is not, contact the manufacturer for assistance.
Aug 08, 2014 | West Bend 41053 Bread & Dough Maker
The spindles that you attach the paddles to is leaking a black lubricant or something like that. I was making a simple sweet dough. By the way, I NEVER bake in the bread maker. I only use it to knead the...
Your machine has a lubricating grease that is under the small gasket or washer at the bottom of the pan under each paddle. After a lot of use the little gasket can fail and the grease can get get past the gasket and into your bread. The best thing to do is either replace your pan with what is called a "pan assembly which will include everything but the paddles. If you decide to do that be sure to keep your paddles. The other choice of course is to replace your machine which might not be a bad idea if your machine has been used a lot because you would have a new pan assembly but older parts may begin to fail such as the drive belt. Bread machines aren't all that expensive anymore so you may want to go ahead and replace especially since you just use your machine for making dough.
Feb 08, 2011 | Zojirushi BBCC-X20 Home Bakery Supreme...
I have a BR1 Bread Maker and I require a new seal
The individual seals are not available. You will have to try and find a new bread pan. Try ebay.
Hank
Nov 19, 2009 | Kitchen Appliances - Others
ITEM : BREVILLE BR1 BREAD MASTER: PADDLE SHAFT REQUIRES
Sorry, I don't have a solution as mine has done the same thing. did you manage to find a fix cos I'd love to know what it was?
Sep 02, 2009 | Kitchen Appliances - Others
Shaft falls out on BB280 breadmaker
Unfortunately there are no official spare parts for the bread pan of the BB280 other than the pan and the paddle, I suggest checking with your local Breville service centre to see if they have a circlip that will suffice, or to check that the pan is intact.
May 23, 2009 | Sunbeam 5891 Bread Maker
Makes a bad loose sound when mixing dough
My Breadmakers Hearth was making the same sound, so after taking it apart I found that it was only the Bread Pans "under paddle" that the machine reaches up and connects to to drive the Paddle. I wears loose and wobbles and starts to slip making that banging sound. You can either replace the Bread Pan or like I did INVERT the under paddle (requires removing the C-clamp washer) to extend the life of the Pan and use of the Hearth. Hope this helps you.
Oct 20, 2008 | Toastmaster Breadmaker's Hearth 1193 Bread...
Kitchen Appliances - Others Logo
129 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
