After changing breaks pads (front and rare) light on the panel-check the breaks!!! How to reset? Thank you
  • charles raynor May 11, 2010
    This question somehow got posted in PC desktops.....
    Are you working on a computer or an automobile?
  • 53 Answers
Refill the brake fluid as some has leaded out, leaving the indicator light to flash.
Posted on Jul 28, 2009
Rr.ABS and the brake lights on
I have a Chrysler sebring 2004, the ABS and traction control light has come on the dashboard display plus I have now no heater. I think it is a blown fuse but not sure
Jan 24, 2010 | 1999 Isuzu Trooper
Lrejlkehg9oiqew
there is no reset. if the light is still on, there is a problem with one of the pad sensors or the connection. also, make sure that the front pads are not worn enough to trigger the light.
Dec 08, 2009 | 2006 BMW 5 Series
How to shut off Brake wear sensor after pad change
If the brake pads were worn enough to activate the warning light the sensor or sensors must be replaced. There is no reset for this.
Oct 24, 2009 | 2004 Lexus LS 430
Changing front and rare break pads in hyundia excel
this front::
  1. Raise and support vehicle, then remove wheel/tire assembly.
  2. Remove lower bolt and caliper assembly. Position assembly aside using suitable wire.
  3. Remove brake pads and shim.
  4. Bottom piston in caliper using suitable tool.
  5. Install new brake pads and attach shim to the outer pad. Tighten lower bolt to specifications.
this for rear::
  1. Remove axle nut, then the hub and drum assembly.
  2. Remove end shoe springs, cylinder and hold-down spring.
  3. Remove shoes and adjuster as an assembly.
  1. Reverse removal procedure to install, noting the following:
    1. Apply suitable grease to backing plate shoe contact surfaces.
    2. Install shoe hold-down pin, then assemble return spring with the pushrod shortened.
    3. Pull parking brake lever fully upward. Repeat process several times.
Jun 04, 2009 | 1994 Hyundai Excel
Reset change break pads light
With a code scanner or I do beleive it will clear after 100 starts.
Jun 02, 2009 | 2000 Cadillac Seville
Brake Pad Sensor
i have replaced both front/ rear pads, and no matter what the dash light will not go off. I have disconnected both front/rear sensors, and light is still on , any suggestions?
Jan 20, 2009 | 2001 BMW 5 Series
Brake wear sensors
Redmondeo34
A couple of things to check.
This is only if you replaced the front pads, after the warning light came on.
1. Make sure brake fluid is level and at the max mark
2. Did you replace the front pads sensors with the new pads.If not please do.
3. Check that the rear pads and sensors are not worn and do not require replacing.
4. If all above is good, Drive vehicle for about 5klm and switch off and on it will reset itself
regards
I hope this helps.
Jul 03, 2008 | 1996 BMW 318
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
