Question about Mitsubishi VS-70707 70" Rear Projection Television
Mistsubishi VS60-607 standard definition , has scrolling lines+jumpy image
I have a mitsubishi big screen 60 inch projection tv model VS60-607 manufactured in 2001. My problem is that the image on the screen is "jumpy" and has "scrolling lines". I thought at first that the problem may have been one of the red, green or blue lamps, but the lines and "scrolling" appear on each of the lamps the same exact way. So it seems the problem is coming from somewhere before it arrives to the lamps. Could it be in the circuit board? or one of the components that look like "coil packs" that have soft cables with suction cups on the ends? This problem started out not as severe and went away after the TV warmed up . It progressively took longer and longer to go away and now it stays that way all the time.
Change the connector strip it plugs into
Posted on Jan 13, 2008
My tv doesn't show the entire picture. I'm sure it has to be the settings but I don't know what to change it's a Mitsubishi and directv is my provider
  1. Press MENU on your remote control, select Settings in the heading, then select Television.
  2. Select Screen Aspect ratio and high definition, press OK.
  3. Use the arrow buttons to select 4:3 standard definition, widescreen standard definition, 720p on high-definition screens, or 1080i on high-definition screens.
  4. Press OK.
Sep 28, 2016 | Mitsubishi Televison & Video
White dots are showing up on the screen. They are multiplying quickly. I was told to clean the filter but that did not help. The lamp is less than a year old. Nearest dealer is 2 states away. How can this...
This problems is the tv Projection Light Engine design flaw with it IC chip.These problems happen to many models of it DLP tvs Big Screen 60 and up.Mitsubishi,Samsung,Sony,Toshiba all used the same IC chip on their 60 and up on their DLP tvs Big Screen.Tries make deal with Mitsubishi help u split the cost of repair the tv Projection Light Engine by replacing the IC chip or replaced the entire Projection Light Engine system.This problems is not new,been going on for a few years.Many people when on Youtube **** about this problems with white dots showing up on their tvs screens and multiplying rapidly.
Nov 20, 2010 | Mitsubishi WD-73734 73" Television
My 60 inch mitsubishi has horizontal lines acrossed it when i turn it on and they dont get much better as it stays on what might be the proble. rolling jumpy lines all the time it is on .......any help...
The vertical control has gone bad and requires professional help. should cost $180 to 220 to fix. Its not a DIY project unless you are really good with soldering and electronics. Its not impossible to do it but needs safety issues to be addressed and hence not recommed as DIY. Checkout more answers and repair estimates at www.fixurtvs.com.
Feb 25, 2010 | Mitsubishi VS-60703 60" Rear Projection...
Black and white lines running through the screen
you have loose connections on the boards, or capacitors leaking.
Jan 27, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi big screen won't stay on!
Its very possible you have a failing resistor r2200
Nov 22, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Jumping screen on a mitsubishi vs-55707
check the high voltage leads on the multiplier flyback transformer for leakage
Nov 17, 2008 | Mitsubishi VS-55707 TV
Screen gets horizontal lines and jumpy screen.
Your problem is capacitors CP204 and CP205 by the 9 volt regulator on the main board. Cp204 is a 47 microfard @ 50 volt and the other is 100 microfard@ 16 volts
Nov 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Vs 7070 no blueuntilwarm and has dark picture
Might be it is worth the buy a new TV,but it is not worth the money to fix it. It is a serious problem!
solutiondoct
Nov 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi big screen tv model vs-5062
HEY DOG-UNLESS YOU ARE GOOD W/VOLTMETERS THIS TYPE FAILURE ON THIS MODEL TV CAN BE VERY DIFFICULT.THE BEST ADVICE I CAN GIVE IS CALL A TV TECH EXPERIENCED W/MITSUBUSHI TVS AND GET AN ESTIMATE.
Nov 14, 2007 | Pioneer PRO-200 60" Rear Projection...
Mitsubishi VS-70707 70" Rear Projection Television Logo
205 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
