Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Hanging and restart problem
Sir, i have a pc which is hanging continuously when working and automatic restart,i have already change smps power supply and ram,but the problem is as it is, what can i do.......
    President:
  • 2,961 Answers
It sounds like ann overheating problem or a driver is corrupt, go to control panel>administrative tools>event viewer and look o the programmes and software menu to see if any red crosses or yellow exclamation marks are showing, if so right click on the line and select properties to give a clue as to the problem
Posted on Sep 16, 2007
    Problem Solver:
Right click My Computer---properties---Adv. tabs---on startup and recovery option click on its setting then uncheck Auto restart.
Posted on Jan 09, 2008
See all the connection. maybe some connections are not onnect well.e.g. avr
Posted on Dec 14, 2007
SOURCE:
Hello sir my computer in motherboard an problem something inside power i diagnose a out put parts like a SMPS & RAM & PROCESSOR & Temperatures & HDD I diagnose Bios I m just start...
When you open up your PC does it have a beep sound continuously.. if it has try this steps make sure you turn off and unplug your pc power chord before doing this 1. check your memory card and graphic card by disconnecting it in your motherboard..after doing it 2. Clean it using pencil eraser the bronze plated part of your video card and memory card you connect to your motherboard rub it with pencil eraser in a single stroke vertically..After doing it connect it again to your motherboard the video card and memory card then turn on again your pc. If the beep stops and this solved your problem good. But if not try to re install your operating system...Hope it will help you..
Jul 11, 2011 | ASUS P5PE-VM Motherboard
Sir i am using asus motherboard(ASUS M2N68-AM SE2) in my pc, when i switch on my pc the processor fan and smps fan is rotating for few seconds(4 to 6 Seconds) and it stopped rotating. 1. the monitor shows...
remove all the ram from motherboard and switch on the system and see it is working or not like just on and fan are rotating and the smps fan is also working and your system is giving beep sound for ram.try with other smps also some time problem with power supply also. Remove the connector of power switch and restart switch and directly try to on from shorting the connector with the help of pen or screw driver point. Some time faulty switch also give problem. Just try all these possibilities.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Jan 03, 2011 | ASUS M2N68-AM SE2 Motherboard
My nokia x2 hangs and restart while seeing a video and also while making a video. While i connect my nokia x2 to pc to update it software. during restart it powered off but dosenont powered on...
sir you have to reinstall the software in the nokia service center the will install the newsoftware to the cellphone [or] check the battery of your phone in the service center............
Nov 20, 2010 | Cell Phones
SMPS problem?
the problem is with yur smps i think.yur turn on button is directly connected with the smps i think.if the smps fails to run yur system will hang.please wipe and dust yur smps completely and see if the system is working.. or else you should change yur SMPS..
Jul 05, 2009 | Gateway GT5428 PC Desktop
Hang & Restrarting of PC
Change the power supply, i.e. the SMPS with a new one of the same rating and make sure all the power & data cables are snug tight in their respective slots. Also take out the RAM, clean it and replace. Try to remove any dust if possible from all the sockets/connectors...........sodeep
Apr 30, 2009 | ASUS Terminator P4 PC Desktop
Computer Restart again and again
remove the cmos battery from the motherboard for at least 1 hour then replace , if it continues to reboot it may also be your hard disk or os causing it
hope this helps
Jan 05, 2009 | ASUS P5LD2-VM Motherboard
Pc hangs up oftenly or show blank screen
Set your C Drive as Master and other all Drives as Slave
I Think this will slove your problem
Try IT
Mar 07, 2008 | Intel D845GVSR Motherboard
My pc hang >>> help
when my pc running,its automatically hang.but i dont know whats the problem.my sound card,agp is building.now i want to sollution this problem.please help me.
Feb 19, 2008 | XFX GeForce FX 5200 Graphic Card
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
47 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
