I am looking for the following spares for Panasonic plasma TV MODEL Number TH-42PWD5BX: PART NUMBERS: TNPA 2534 EL2719B (SC) BOARD x 1 TNPA 2589 EL2719X (D2) BOARD x 1 Can you help
SOURCE: panasonic th-42pwd5bx - rear screen noise - please help!!
sounds like the fans is there a hest source nearby or underneath, plasmas suffer severly from this thats why they so cheap everybody buying lcd at the moment no heat or screen burn issue but not as good a picture(when they are cool) the gasses distort the picture when hot hence cooling fans hope this helps ps warranty void if over a fireplace or next to a rad dont tell you that do they!!!! belly
Posted on Jan 14, 2007
SOURCE: Panasonic Model #Th-42PA25
it is just an example for the part that should be replaced that is why i suggested that a service technician should check the tv physically to determine the part that needs to be replaced.
Posted on Sep 05, 2008
  • 4234 Answers
SOURCE: I own a Panasonic Plasma
There must be more than one board that is bad. Retail pricing for the replacement boards run between $300-$800. Evein including labor, that should not be more than $1200-$1500 at worse. Realize that the servicer does not pay retail for the parts either. It can not e the panel as that would exceed $4000 for the part alone. What is the problem with the set?
Dan
Posted on Sep 29, 2008
  • 3 Answers
SOURCE: Panasonic TH-50PZ Plasma TV won't come on.
what is a UPS?? mines doing it too
Posted on Oct 05, 2008
  • 8457 Answers
SOURCE: Panasonic plasma viera tv will not auto tune, can
Reboot all cables,satalites,and telicoms boxes.Like unplug,replug the box an hour later.Let the boxes up grade software,go to ur tv menu setup rescan all channels again well get them back.Ur signal not there after that, than ur Tuner Signal board is dead.Need it replaced.
Posted on Mar 13, 2010
Where can I buy a Panasonic TNPA5175 SC board?
I purchased one from panasonic directly. TV did power up but did return to 7 blinking lights. Must be a buffer board short that caused the SC board to fail. . Not spending another $200.
Aug 04, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Panasonic TH 42PA25. Front power switch LED is solid red. SC Board LED (D6583) is not lit. SS Board LED (D6765) is not lit. However, SS Board LED D6769 is lit. I suspect PA or P board.
The TV is on standby mode due to protection; some error in the board. If you have spare boards, try replacing it one by one, starting from display board.
Jul 28, 2012 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Hi i have problem with my Panasonic TH-42PV8EY- 7 red blinks on the start- nothing showed on the screen. After disconnecting SC board seems like it starts. Disconecting SU and SD boards dont give nothing...
I have not repaired this model. My first thought are bad capacitors in the power supply board. If you do have the exact board to replace. I would certainly do so. Numbers check and you say they are the exact same, should be an easy fix. If this board came out of another TV of the same model, you must remember, it will have the same longevity as the board that does not work. I would compare the boards, and look for bad capacitors on the board that does not work of course. You may check the capacitors with an ESR meter (about 50 to 75 bucks). The purchase and price of one of these will pay for itself. You can fix other electronics. Thanks for asking Alan. I'll be here if you have more questions.
Oct 21, 2011 | Panasonic TH-42PV80 Plasma TV
Panasonic TH-50PZ80U plasma wont turn on, power light blinks 2 times.
YOU MUST BRING THIS TV TO A REPAIR CENTER EXPECT AT LEASE 450,00 AND MAYBE MUCH MORE THERE MAIN PROBLEME IS SC BOARD AND OFTEN SD SU AND WORSE PANEL !!
Apr 29, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
TH-42PX60U wont turn on. Blinks 10 times. replaced the power supply board, but the same issue.
What I'm learning is there are several models of Panasonic TV's that have a video card that doesn't play well with HDMI applications and the end result is, you need to call this number and not only make arrangements to replace the bad board,but also this!
Your model doesn't show below,but I'd certinly inquire about the necessity of a "Firmware" update!,,,Panasonic knows FULL WELL they have a HUGE problem here!
Hope this helps!
At panasonic.ca I found the listing for the fw update under customer support-important notices
If you own a plasma TV with model and serial number within the range specified below, please contact our toll-free VIERA Concierge hotline service at 1-866-330-0014. A VIERA product expert will arrange an in-home software update for your TV at your convenience.
Model Numbers Serial Number Range
TH-42PZ77U
TH-42PZ700U **71250001 ~ **80189999
TH-42PZ700UA
Jan 28, 2010 | Panasonic TH-42PX60U Television
7 blinking Red Light. Power Supply problem??
Need replaced su.sd and sc board
Panasonic TXNSC1RKTUS SC BOARD BOARD, SCAN DRIVE ASSY
Panasonic TXNSU1RKTU SU BOARD BOARD, UPPER SCAN OUT ASSY
Panasonic TXNSD1RKTU SD BOARD BOARD, LOWER SCAN OUT ASSY
Dec 09, 2009 | Panasonic Viera TH-46PZ85U Plasma TV
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Oct 21, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
Electro Med Services...
