Question about Maytag MAV7600 Top Load Washer
Mav7200-57-58 when wash cycle is on agitator does not spin but when rinse cycle is on agtiator spins. all other setting work fine just the wash cyle when water is up to level does not agitate playing with timer nob somtimes gets it to work. Any help would be appreciated..
  • guysr1 Sep 20, 2007
    Thank you very much for your help
    Scholar:
  • 136 Answers
The timer itself is bad, replace and wala! Timer Part Number: PT756240 Made by MAYTAG http://www.partstap.com/partsearch/model.aspx?model_id=47859 $70.22 + S&H
Posted on Sep 17, 2007
Agitator quit working during wash cycle. If I move timer to rinse and fill with water then move timer to spin the agitator works fine and drains water from the tub
depends on what u mean by agitator works fine on spin? it doesnt do anything on spin cycle cause its not suppose to? if ur saying ur not getting any wash agitation? then I suspect ur cam dogs inside agitator are bad? remove the 7/16 bolt nut and remove top of agitator and u will see the cam dogs underneath it. there fairly cheap like 5-10 bucks for a set, if u can push the agitator back and forth when its all together in tub, and its catching the teeth and not easy to move back in forth, their not bad, but if u have no resistance then they are bad
Feb 19, 2015 | Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Washer stops agitating durning the rinse cyle, but timer keeps going. Also won't wont spin the water out on the rinse cycle. Wash and spin work just fine. This problem is the same on all three cycles.
I suggest you replace the control box. I need Mgfr & model # to find the part number for you. The replacement steps are more mechanical than electrical. Oh! make sure you UNPLUG unit before starting repair.
Feb 11, 2010 | Washing Machines
Kenmors 110 keep spining
The tranny should either spin or agitate not both
Nov 02, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine fills, but won't agitate
sound like the lid switch is open, if that doesn;t fix it try the water level switch
Mar 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAV7600 Top Load Washer Logo
111 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
