Question about JVC Car Audio & Video
How to run power cable from engine bay through to inside???
Hi, I was trying to install an amp in my 2003 Diamante LE. Having trouble trying to run the power cable from the engine bay through to the inside of the car.
Can anyone please help?
Any help appreciated.
  • 655 Answers
Hello Ljet,
The best possible solution is to find an existing grommet in the firewall to run your wire through. While I cannot be specific about the 2003 Diamante, I've found that you can nearly always locate a firewall grommet. I'm attaching a photo of a power wire going through a firewall grommet. Notice that it has been sealed with silicone sealant.
If there is no grommet in the firewall, you still have a couple of options:
Option 1 is to drill through the firewall, which can be done from either the interior side, or engine side . Be mindful of the brake booster and hoses/wiring on the firewall. You can use a cut piece of PCV pipe or a PVC coupler for a bushing, just measure the OD of the PVC and drill accordingly (just SLIGHTLY oversize - you may need to use a hole saw). Then epoxy the bushing in place. Once the epoxy is dry you have a smooth pathway through the firewall which won't cut the jacket of the wire. Pull the cable and fill the area surrounding it (where it goes throught the PVC) with silicone sealant. If you are running the cables on the driver side, Be careful how you route the wires so that they do not interfere with pedal operation - take this into account when deciding where to drill your hole(s).
Option 2 is to run the cables externally, underneath the car. If you go this route, PVC tubing bolted through the floorboard can be used as conduit (Obviously, you would need to remove the seat and carpet in order to do so). Then you can use the same epoxy bushing procedure listed above to get the wire back inside the car.
Hope this helps.
Posted on Apr 17, 2009
Does a 2003 Mitsubishi diamante have a light that mounts under hood
Not unless you order a certain trim level. There are many engine bay lights that are easy to install as kits.
May 11, 2017 | Mitsubishi Cars & Trucks
How to replace a 1999 Mitsubishi diamante power antenna fuse?
Hi, fuse should be under the dash. There is a fuse box just above kick panel next to steering wheel. The other fue box is in the engine bay next to battery. Good Luck. Remember use same size fuse as replaced.
Mar 09, 2015 | 1999 Mitsubishi Diamante
Wiring the remote lead for a subwoofer amplifier into sony-dab500u
You can always find a fuse in the fuse panel that only has power when the key is on, find the hot side of the fuse, install a fuse tap, run a wire from the fuse tap to a switch (toggle) then run a wire to the amp.
The switch gives you full control and you never have to worry if you turned the amp off or not as it will be off when the car is off.
Feb 02, 2014 | Sony Car Audio & Video
How does the thermostat fit properly in the housing
Pacifica, 2003-2005
Removal & Installation
Print Here is how to do it,if it does'nt fit right make sure you have the right thermostat.
3.5L Engine
CAUTION Never remove pressure cap with the system hot and under pressure because serious burns from coolant can occur.
  1. Disconnect negative cable from remote jumper terminal.
  2. Drain cooling system.
  3. Disconnect radiator upper hose from thermostat housing.
  4. Remove thermostat housing bolts.
  5. Remove housing, thermostat, and gasket.
    Fig. View of the coolant outlet connector (1) and thermostat housing (2)-3.5L engine
  6. Clean gasket sealing surfaces.
To install:
  1. Install thermostat and gasket into thermostat housing. For ease of installation, install bolts in housing for thermostat and gasket retention.
  2. Install thermostat and housing to the intake manifold. Tighten the bolts to 105 inch lbs. (12 Nm).
  3. Connect radiator hoses and install hose clamp.
  4. Refill cooling system.
  5. Connect negative cable to remote jumper terminal
May 02, 2012 | 2004 Chrysler Pacifica
Changing spark plug 2003 diamonte
Hi, to change the spark plug, remove the engine cover and intake manifold plenum. Remove the spark plug cables. CAUTION: When pulling off the spark plug cable from the plug always hold the cable cap, not the cable. Remove the spark plugs.
Hope it helps.....
Jul 12, 2011 | 2003 Mitsubishi Diamante
Looking for any extra help for installing the serpentine belt on my 2003 pontiac vibe....is there going to be any major trouble spots that we should know about?
Hope this helps!!!
2003–05 1ZZ-FE Engine & 2003 2ZZ-GE Engine
  1. Disconnect the negative battery cable.
  2. Use a wrench and rotate the belt tensioner clockwise.
  1. With pressure applied to the wrench, and tension relieved from the drive belt, remove the accessory drive belt.
To install:
  1. Raise and safely support the vehicle.
  2. Remove the right side lower engine splash shield.
  3. Properly route and install the accessory drive belt onto the drive pulleys.
  4. Use a wrench and rotate the belt tensioner clockwise.
  5. With pressure applied to the wrench, install the accessory drive belt.
  6. With the accessory drive belt installed properly, release the belt tensioner.
  7. Install the right side lower engine splash shield.
  8. Connect the negative battery cable. Tighten the battery cable bolt to 11 ft. lbs. (15 Nm).
May 04, 2010 | 2003 Pontiac Vibe
I am having some troubles in my golf 2003 1600cc SR Engine
Sure -
Go buy the new pre made wires - install them cleanly - if the engine runs better leave them - if not - return them - keep them clean and tidy and no one will care.
Best of it
Mar 27, 2010 | 2003 Volkswagen Golf
Fuse cover in english
Try this.
( http://www.worldlingo.com/en/products_services/worldlingo_translator.html )
Jun 02, 2009 | 1992 Mitsubishi Diamante
Having trouble fitting receiver in canopy
if your receiver is separated from fan place it inside sheetrock !
Dec 21, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Car Audio & Video Logo
383 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
