Question about ASUS A8N-LA GeForce 6150 LE Socket 939 mATX Motheboard w/Video/Sound/LAN Motherboard
Can i use btx power supply with a atx motherboard
  • 3,267 Answers
You can provided you can fit in the psu box. Its just placement difference between the two...............sodeep
Posted on Apr 17, 2009
Biostar g41 m7 wont power up after installing cpu
have you an ATX/BTX PSU?
with 24pins ATX + 4pins P4 connector?
if you haven't that it's normal that's don't work
else your PSU 5Vsb or/and your motherboard are dead
Nov 19, 2012 | Biostar G41-M7 Motherboard - Socket 775,...
My Gateway GT 4016 starts up , loads windows, and goes to the desktop screen then shuts down. The power supply, hard driive, ram and video card are all ok so I think the motherboard is shot. It is a BTX...
Might be better to go with a new one by the time you have the money and effort into it be about the same I would think and get a newer comp upgraded mem and such just a thougth
Sep 21, 2011 | Gateway GT4016 Desktop PC
Can i change out the motherboard on my dell dimension 4600 and use the one from my optiplex gx 520 in place of it.
No you can't. The Optiplex system board is a BTX type, and the Dimension uses an ATX style. The BTX board was supposed to be the new standard, with the layout changed to improve cooling air flow. Unfortunately, the I/O connectors (keyboard, etc.) aren't in the same place as on ATX boards, and you can't just drop the BTX board into the same case. (This is one of the reasons the new design didn't catch on. Seems people didn't like the idea of shelling out for a new case as well as the board.)
May 28, 2011 | Dell Optiplex GX520 (XG309) Motherboard
I would like to move it in to a bigger case
When looking at the specifications of the HP Compaq DC7700 SFF Desktop PC, all they state is the motherboard form factor is, 'Custom'.
Same thing for the DC7700 USDT Desktop PC.
Both of these desktop computers are of the 'Pizza Box' design.
(Flat rectangular box)
The DC7700 CMT model is a tower model, and the motherboard form factor for it is uATX.
uATX can also mean Micro-ATX.
The form factor of a Micro-ATX motherboard is 244mm by 244mm, or also said as 9.6 inches by 9.6 inches.
(9.6 inches is approximately 9 and 9/16ths inches)
To regress for a moment, and explain the term Form Factor.
This term is supposed to apply only to motherboards, but has gone on to apply to computer cases, and power supply's.
Form factor means the dimensions of the motherboard, and also where the I/O area is located.
[I/O = Input/Output
Area for the Input/Output devices that are attached to the computer.
Examples: Mouse, Keyboard and Monitor]
Whether the motherboard is installed onto the Left side of the computer case, and the I/O area is on the Left side also (ATX , Micro-ATX, and uATX form factor),
or
whether the motherboard is installed on the Right side of the computer case, and the I/O area is on the Right side also. (BTX)
Dimension sizes:
ATX is 305mm x 244mm. (12 inches by 9.6 inches)
Micro-ATX is 244mm x 244mm (9.6 inches by 9.6 inches)
http://en.wikipedia.org/wiki/Computer_form_factor
Above the link is the Maximum size for the Micro-ATX form factor.
It can also be the Minimum size of 171.45mm x 171.45mm
(Or 6.75 inches by 6.75 inches.
6.75 inches = 6 and 3/4 inches)
http://en.wikipedia.org/wiki/MicroATX
Point of all this?
The motherboard form factor inside a DC7700 SFF is probably a uATX form factor, and is 6.75 inches by 6.75 inches.
Or some variation thereof.
It's a custom size.
This means good luck in finding a computer case you can buy off of the shelf, and is large enough to install an ATX power supply.
You can get a custom one made, and you're probably looking at $150 to $200.
Or, you can modify one of these computer cases VERY easily,
1) http://www.directron.com/cs888uvbl.html
The above is an Acyrlic plastic computer case. It's approximately 1/4 inch thick for the case walls, bottom, and top.
VERY sturdy.
It has metal Standoff's that are set up for an ATX motherboard.
It should have holes in the case where a Micro-ATX motherboard can be mounted, by unscrewing the Standoffs, and screwing them into the Micro-ATX holes.
[A Standoff is a piece of metal that is hex shaped, and has a threaded hole in one end, and a threaded end on the other side ]
If there isn't the proper holes for mounting your motherboard, you make the holes.
The case is plastic.
Uses an ATX power supply.
The cost of the case is $50
Mar 08, 2010 | HP RT810UTABA - HP dc7700 small form...
Machines T1862 PC Desktop I need to know if an
Your cabinet doesnt support the full range ATX size motherboard..
It supports onyl Micro ATX and BTX motherboard..
Please leave me comment, if you need further assistance
Thanks for using Fixya
Please rate this solution
Rnj VinodKumar
Dec 15, 2009 | E-Machines T1862 PC Desktop
Power supply wont come on
I've check and that board uses an ATX power supply. that is your problem. slap in an ATX and you'll be good to go. Please be so kind as to rate this answer thanks and good luck.
Jan 28, 2009 | ASUS A8N-SLI Premium Motherboard
No power supply to the tower
Be sure that the ATX or BTX power cable (the rectangular cable with 20 or 24 pins) is securely fit into the motherboard. Re-seat it if needed. Also, check the +12V 4-pin adapter (if exists) is seated, just like the 20/24 pin is. If that doesn't solve the problem, be sure that the PSU is switched on and is at 120V (USA) before plugging in the power cable. If that doesn't work, contact the computer manufacturer or the PSU manufacturer (depdending on what you purchased.)
Hope this help!
Robert W.
Jan 09, 2009 | Dell Dimension 8400 PC Desktop
No power to 12 volt, Hard drive, or Disk drives.
Retrace your steps there may be a loose wire(s). Have you checked and rechecked your pinouts? maybe one of the wires is backwards. Hate when that happens. It could be bad out of box. Try unhooking everything then one by one rehook your components. Maybe by terrible coinsidence a part fried and is preventing the machine from booting. Make sure your CPU fan is plugged in. I am installing a new motherboard now and those are the pitfalls I keep track of.
Mar 08, 2007 | Enermax (by Coolergiant) ELT400AWT Liberty...
ASUS A8N-LA GeForce 6150 LE Socket 939 mATX Motheboard w/Video/Sound/LAN Motherboard Logo
102 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
