Question about Samsung CLP 300 Laser Printer
Smart Utilities Library cannot load (code126)
It indicates that Smart Utilities Library (code126) cannot load
My Trane AC thermostat (900 TOuchsreen) has an error code 126
Error code126 is equipment does not match value at startup. Usually a power surge or brown out can cause this problem. Turn power off to inside and outside unit, wait 5 minutes. Retry system.
Jul 15, 2016 | Heating & Cooling
Both Status light and black toner light are red. Dumped L-shape tray. Any help appreciated.
Dear
Pl. run the SMART PANEL on your pc and get a test print from your pc, the smart panel will indicate the description of the error.
from the black toner light red means black toner is going to or exhausted.
For smart panel you can follow the link and put your model in search box to down load.
Printer Support SAMSUNG India
Thanks.
Mar 16, 2015 | Samsung CLP 300 Laser Printer
I am doing a java application to structural analysis.it involves the solution of system of linear simultaneous equations.may yuo pliz assist me with a java code to solve the equations.its urgent .pliz...
The absolutely-best, most-robust, software for solving systems of linear equations is the LINPACK software library.
It was originally written in FORTRAN.
But, see: http://www.greenecomputing.com/apps/linpack/
which indicates that a JAVA version exists.
Mar 02, 2011 | Computers & Internet
Windows has stopped this device because it has reported problems. (Code 43)
This is some information on from the Western Digital website: information library.
http://www.wdc.com/en/library/index.asp?language=en
0009 - 0014 SMART Error Self Monitoring, Analysis, and Reporting Technology (SMART) Error returned during SMART Status/Self Test Command. Retest the drive. Replace the drive if the error repeats. Re-test Drive
Sep 09, 2010 | Western Digital My Book Essential 500GB...
Smart Heap Library Mem_bad_pointer Can't Synchronize - Period
Hello.
What I would suggest is to reset the device by disconnecting and reconnecting the wires from the battery.
Here is a link to replace the battery. So, just follow steps 1 - 5, 9 and 10. And, you won't need the glue.
http://reviews.ebay.com/How-to-repair-Palm-Tungsten-E2-replace-battery_W0QQugidZ10000000000937354
Hope this helps.
Jul 04, 2010 | Palm Tungsten E2 Handheld
Fn key
Try installing the "Sony Shared Library" and the "Sony Notebook Control Device Drive".
First install the Sony Shared Library, restart the Computer and then install the "Sony Notebook Control Device Driver" (restart the Computer again).
NOTE: Sony Shared Library is the system component which makes the download and installation of Drivers and Applications compatible with the Computer. While "Sony Notebook Control Device Drive" is utility which will enable the Function keys in the Computer.
Check this Link to download these Utilities.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCGFRV27
The Sony Shared Library will be listed under "System Components - 1 file(s)" and Sony Notebook Control Device Driver will be under "Notebook Control and Utilities - 1 file(s)".
Good Luck!!!!!!!!!!!!!!
Nov 17, 2009 | Sony VAIO FRV27 Notebook
Vaio service utility stopped working? VGN-FZ298CE
Hi rante_12,
You need to re-install the Sony Shared Library and Sony Notebook Utilities in the Computer.
Below is the link to download the Sony Shared Library
http://esupport.sony.com/CA/perl/swu-download.pl?mdl=VGNFZ298CE&upd_id=3090&os_id=28
Please download and install the Sony Shared Library in the computer first. After that restart the Computer and install the Sony Notebook Utilities.
Below is the link to download the Sony Notebook Utilities.
http://esupport.sony.com/CA/perl/swu-download.pl?mdl=VGNFZ298CE&upd_id=3092&os_id=28
Please make sure that you restart the Computer after each installation for the settings to take the effect.
This should fix the issue.
Good Luck!
Thanks for using Fixya.
Oct 10, 2009 | Sony VAIO V505 Notebook
Library cannot load when saving video
first click on all video you will get all videos you have saved
May 04, 2009 | Compaq Computers & Internet
Windows Vista and Autocad r14
try this thread from autodesk it is having solution
Feb 02, 2008 | Microsoft Windows Vista Ultimate Edition
Error code 1516
Error Message:
Error 1516: Partition improperly dismounted (EA3905EC).
Solution:
Solution #1: One possible reason for the error involves the improper setting of a “dirty” flag in a restart record in the journal file, or activity log for a given hard disk. The term flag refers to a yes/no or true/false variable or a specific quantity that indicates the current state of a program or a piece of hardware. This can happen if the system crashed, or lost power while you attempted to create or write to a hard disk.
Running CHKDSK can solve this problem. Click Start, Run, type cmd, and then click OK. The Command Prompt should appear. Next you need to indicate the disk you want to repair. Type cd C:\, and then press ENTER. If you suspect that the error is on a drive other than C:\, substitute the appropriate letter for the drive you want to check. Next, type chkdsk /f, and then press ENTER. This command checks the drive you indicated for errors, while the /f switch fixes any errors. You may need to run the utility more than once to fix all errors.
Solution #2: Another reason for this error involves a conflict with Windows 2000/XP and SMART (Self-Monitoring Analysis and Reporting Technology) error detection, which is a feature of some software utilities. To resolve the problem you’ll need to disable the SMART error detection feature. Consult the utility’s documentation for instructions on disabling the SMART error detection feature. If you can’t turn SMART error detection off, you may need to uninstall the offending utility.
Next, insert the Windows 2000 or XP installation CD into your computer’s optical drive and reboot your computer. At the Startup menu, press R to access the Recovery Console. Type chkdsk /p and press ENTER. Reboot the computer and attempt to run DriveCopy. If SMART error detection was successfully disabled, then you shouldn’t encounter the error anymore.
Dec 13, 2007 | Computers & Internet
Samsung CLP 300 Laser Printer Logo
363 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
