How to creat ghostcast server & oparate server & multi use this program. boot ghost for lan
  • Patrick Kam May 11, 2010
    This question is too much to explain, Symantec will most likely email you hundred pages PDF of manuals.
    At least let us know what your Network Infrastructure have. Booting to Ghostcast server session requires more than just a DHCP on your router. A specific boot option in DHCP is needed to forward Boot-From-LAN requests which may not be able to implement in your router.
    I have successfully implemented Ghostcast Server on Windows XP Pro with this utility as well. However you cannot use this on existing DHCP enabled network. I have used XP Pro to serve DHCP, PXE boot on one of the LAN Adapter. The connected devices can surf internet through the other LAN Adapter that connects to my router to share internet.
    Problem Solver:
  • 15 Answers
If you installed ghostcaster server from the cd you will have a computer with the server on it. Then once you do that you want to install a PXE server so that you can then advertise to the network
Posted on Aug 21, 2009
How to make bootable cd for ibm system x3200 server
Create the CD using Roxio. Follow the direction within the program and option to make a CD with Boot Sector fortification. Establish to Boot format and save the data to the disc accordingly.
Feb 10, 2013 | IBM System x3200 M2 Server
Tip
How to make Windows Server 2003 Enterprise Edition see more than 4GB RAM
Issue – After upgrading a server to Windows 2003 Enterprise Edition and adding additional memory, the OS still shows only 4 GB of RAM.
Additional Information – Physical Address Extension (PAE)
In Windows Server 2003, PAE is automatically enabled only if the server is using hot-add memory devices. In this case, you do not have to use the /PAE switch on a system that is configured to use hot-add memory devices. In all other cases, you must use the /PAE switch in the Boot.ini file to take advantage of memory over 4GB.
The newer Dell servers are capable of using hot-add memory devices, but the older servers do not.
If you upgrade an older Dell server and are experiencing the issue above, make the following change to the boot.ini file.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(2)WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(2)WINDOWS="Windows Server 2003, Enterprise" /fastdetect /PAE
Add the /PAE flag to the end of the boot device. Then reboot the server.
After rebooting the correct amount of memory should be displayed
To summarize, PAE is a function of the Windows 2000 and Windows Server 2003 memory managers that provides more physical memory to a program that requests memory. The program is not aware that any of the memory that it uses resides in the range greater than 4 GB, just as a program is not aware that the memory it has requested is actually in the page file.
on Apr 19, 2010 | Computers & Internet
How to update Lan Driver of mfsys25 server to suse?
This all-in-one system, built on Intel Multi-Flex technology, supports six compute modules, each supporting up to two Multi-Core Intel Xeon 5000 sequence processors, and up to 32GB of memory, virtualized shared storage with fourteen hot-swap hard disk drives, an integrated management module for centralized management, redundant Ethernet switches and storage controllers.
each "compute node" is a computer in the very basic of ways. what you will need to do is pray there is a VGA port and the ability to use it as a desktop until you get it set the way you want the go headless...
use an extrnal usb case to modify the hard drive on another system then BACK UP EVERYTHING use an HD imaging program to get an exact copy of the drive. suse isnt for beginners and even pros make mistakes having a backup will save you. load suse onto the drive useing a live distro converted to usb thumbdrive boot. then load up the server with the OS and complie and install...
that isnt exact instructions and your setup will be differant than the next guys that is the "features" of Linux. so if your not comfortable with Linux and installing a system of this nature i wouldnt attempt it.
Jun 10, 2010 | Intel MANAGEMENT MODULE FOR MFSYS25 ...
Self installing image
Try Acronis True Image. Similar to Ghost but works better. You can create an image of your system on a separate partition. When booting your system, you can recover from this image by pressing F11. Sort of like the hidden partition some companies put on a hard drive to return it to factory state. Only you create the partition yourself.
Aug 08, 2009 | Computers & Internet
DELL DL-380 G5 "could not allocate page table memory" GSS 2.5
First of all, Dl380 is an hP product.
Secondly your ghost version seems a bit old as ghost 14 is the latest version. Having said that the problem could be at two ends.
1. At the ghost side where your version doesnot contain NIC drivers for PXE boot and HDD drivers for imaging. To fix this you can try manually adding the drivers to the network boot or floppy boot diskette.
You can get the drivers from HP website or the PSP CD that came with the server.
Alternatively you can upgrade to RDP instead of GHOST, RDP is Symantec's offering sold by HP for imaging it's servers.
2. There's some problem with your NIC settings or card if you are trying to PXE boot.
If you are using a floppy drive/ usb HDD, check from BIOS if it is detected.
Jun 25, 2009 | HP Compaq ProLiant DL380 G4 Server
Can onboard LAN in 661GX-M MB load OS from net?
Check in the bios settings if there is any LAN Boot ROM option. If yes then enable it. Now you will be able to boot from LAN provided there is Server running which supports PXE
Nov 25, 2008 | EliteGroup 661GX/800-M (661GX800M7)...
Dark colonymultiplayer
If the game uses serial codes to install or use the game, you need to have purchased 2 copies. Then you can either connect them with your (i'm assuming is a lan) cable. OR Download hamachi (you should use version 1.0.1.5) and create a network. Hamachi is a program that creates a virtual lan cable. You can download it here: http://www.filehippo.com/download_hamachi/2114/
Oct 28, 2008 | Video Game Consoles & Games
I need a recovery disk for my Vista OS preinstalled on Acer Aspire T180. Can I create it by myself? (Recently my system crashed and I had to a tecnichian for using his recovery disk)
You can use a hard drive imaging program such as Norton Ghost to create a recovery DVD(s). Norton Ghost is available as part of System Works or as a stand alone program. Power Quest's Drive Image is also an alternative, however it is too old to be compatible with Vista - you could do a Drive Image outside of Windows - booting off the Floppy.
Sep 09, 2008 | Acer Computers & Internet
Ghost dell 2500
Just run Ghost in windows and follow the wizard to create a bootable floppy for your hardware
Feb 20, 2008 | Dell PowerEdge 2500 Server
Intel 82566dc...
Hello there,
If your board is Intel, you can download drivers from there, using the code number of the board, or name.
it is more easy!
www.intel.com
Jan 04, 2008 | Computers & Internet
Computers & Internet Logo
889 people viewed this question
David Payne
David Payne
