Question about Siemens WD61392GB Front Load Washer / Dryer
Siemens wd 1630
Stopped on dry cycle E 6 flashing up and the door won't open
4 Suggested Answers
SOURCE:
  • 16 Answers
SOURCE: The door is jammed on my LG Intellowasher
Hi, Has all the water gone out of the machine? Try it on another spin cycle if it opens then the drain filter or pump could be blocked.
Regards Elect App
Posted on Jul 14, 2011
  • 184 Answers
SOURCE: I pushed the 'pause' button
Hi!
The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
Posted on Aug 08, 2011
Testimonial: "It worked, thanks!"
  • 3698 Answers
SOURCE: Where can I find a replacement board for Siemens IQ1630
www.siemens-home.co.uk/customer-service.html
Posted on Jun 02, 2014
My 1630 needle won't move down
Hi Peg.
go to this link and have a read up.when you go to this link if a link opens on the right had side asking you do you want help just close that down and you will be able to see what is being said on what it could be stoping your needle moving.hope this helps.
have Bernina 1630 have been sewing lot the last couple
or you could try this link as well.
sewing machine 1630 needle won move down Google Search
Jun 16, 2018 | Sewing Machines
I pushed the 'pause' button during the wash cycle of my LG WD-3274HD and now the door won't open.
Hi!
Aug 08, 2011 | LG WD-3274RHD Front Load Washer / Dryer
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
My Maytag QuietSeries 400 dishwasher won't start. Sometimes 88 flashes on the display and that's all. What does that mean? Model # MDB7601AWB
Dishwasher will not start Is the door open or unlatched?
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.
Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob? (Some Models)
The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?
To cancel the delay and cycle, press Cancel/Drain.
Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.
Is the Start/Resume indicator flashing?
Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.
On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.
Is the water shutoff valve (if installed) turned on?
Make sure that the water shutoff valve is turned on.
Jun 19, 2011 | Maytag Dishwasher
How to open the door of the siemens iQ300 washing machine
This problem has nothing to do with water in the machine. My IQ300 regularly refuses to open on the drying cycle! You have to open the small round compartment beneath the door and pull down on the black plastic strap to the right - you may need a utensil to pry it out. What a rubbish machine.
May 29, 2011 | Siemens WIQ1633 Front Load Washer
My aged invalid mother has a front loading LG washer dryer combo and has washed the same garment 3 times and after wash cycle or drying cycle can't seem to get the door to open to remove the clothes. What...
Hi I hope you solved this by now but I thought an answer might be useful if anyone else has the same question. I am not an expert just an owner of a LG WD-1412RD. It sounds like your mum is not aware this is just the normal safety cool down period following drying (as the stainless steel interior gets very hot during drying). The Door lock sign (small red light) is on, and the display shows Cd during this time, then it beeps and the door unlocks by itself. If you need to remove your laundry earlier than this, you can press the START/PAUSE button to end the cycle (it still takes a couple of minutes). This is covered on p 21 - 22 of the owners manual. which can be downloaded from the LG site. http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Nov 28, 2010 | LG WD-14124RD Front Load Washer / Dryer
Unit will not turn on at all. Power source definately works. Unsure if unit stopped during dry cycle or finished and never came back on, but clothes were dry, indicating it was finished with the wash...
Sounds like the problem is with the control board.  There is an internal fuse in the board but it is not replaceable.  You will need a qualified LG technician to service this unit.
Nov 03, 2006 | LG WD-3245 Front Load Washer / Dryer
Siemens WD61392GB Front Load Washer / Dryer Logo
146 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Mike
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
