Question about Gigabyte Computers & Internet
Keeps on rebooting at startup
Hi, My PC keeps on rebooting at startup and then goes to the safe mode screen, but when i select one of the feature, it reboots again and does the above over and over again. please help
    Scholar:
  • 88 Answers
It's either you have a corrupted system boot file on the hard drive or infected with some virus. Try to verify that the PC will not reboot itself in BIOS. If so, memory is most likely the cause.
Burn a CD "HDD Regenerator 1.51" and boot from it, scan all the hard drive and it will attempt to recover all the bad sectors.
If HDD Regenerator finds nothing, then it's very likely Virus related. Take the harddisk out, connect it via external case and Scan with Antivirus on another system. If nothing found, backup your data and rebuild your PC (Reinstall Windows)
Posted on Apr 17, 2009
How to run 3000 y410 laptop in safe mode
Hit F8 during the boot process to bring up special boot features like Safe Mode. With Windows 8 you can open a search bar and type "Startup". Select Change Advanced Startup Settings". Select Safe Mode. Reboot.
Oct 04, 2013 | Lenovo 3000 Y410 Laptop
Upon startup requests password then fails to load 'youre settings' and therefore becomes inopperable. Please advise
reboot the system and press F8 it will got windows advanced option menu.select safe mode and log on to the safe mode.don't actually need the admin pwd.go to control panel and change the password .issue will be resolved if this is related to password.
if still doesn't work.in safe mode go to start run and type msconfig.go to start up tab and disable all and then try and reboot.if that works fine.again go to safe mode enable all start up items and try disabling each item and reboot.you will get to know that which one is causing the issue and keep it turned off.
Oct 27, 2010 | Dell Inspiron 1525 Notebook
Spontaneous Rebooting
Hi ,
Which anti-virus have you tried to install and reinstall as it can happen if its not properly installed.Please check if its manually uninstalled. Try rebooting the system in safe mode . Go to Run type msconfig and select Normal Startup save and reboot.
Jan 28, 2010 | Microsoft Windows XP Professional for PC
Black screen after turn on
That "Blue Screen" is also known as "Blue screen of Death".
The problem is due driver compatibilty or unstablity.
Try to boot your system to "Safe Boot" by pressing F8 during startup.
Select "Last know good Configuration that works"
Check if it can take you to desktop.
Unstalled the wi-fi driver and reboot.
If the above procedure fails, again
Select "Safe boot"
Now create a restore point  and download the lastest version of your WI-Fi driver and installed.
This should work fine.
Otherwise Backup all your important data from your hard drive (mainly opearting system file installed drive usually C:\) and go for a new Installation.
Dec 28, 2009 | Acer Aspire One PC Notebook
Start up problem!!
When you boot up start pressing F8 and you should get a Windows startup page with more options. If you do select Safe Mode
When windows has loaded, goto MSConfig and select Diagnostic Startup. Ok and reboot
See if windows boots normally.
Apr 26, 2009 | Acer Aspire 6920 Notebook PC
Hi from london, have new acer aspire 1 zg5 new keeps shutting down after boot can u hlp pls?
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, keep tapping on F8 key on your keyboard. When the Windows Options menu appears select the "Safe mode" then press Enter.
Once you managed to boot to Safe mode, change the computer startup and recovery settings by right-clicking "My Computer" then select Properties. Select Advanced tab. Under Startup and Recovery, click Settings. Uncheck the box for "Automatically restart" under System Failure.
Reboot again normally, see if it will reboot again by itself. If you managed to make the system boot normally, proceed to Events Viewer to find out what is the caused.
If the system failed to boot normally after doing the above, you might want to boot the system to "Last known good configuration"
Jan 11, 2009 | Acer Aspire 3690-2196 Notebook
HELP!! (dell precision 340) im getting 4 screens when i turn on m
Reboot into Safe Mode by repeatingly tapping on F8 while in process of rebooting and then select "last known good configuration". If that fails reboot again to safe mode and select safe mode with command prompt and in the command prompt type "chkdsk /f /r " <enter>
If that doesnt work do place your Windows CD into the Cd-Rom, reboot and select option "Repair"
Jan 02, 2009 | Dell Precision 360n PC Desktop
Acer aspire t135 rebooting problem at startup constantly
I am assuming that it starts up, goes to the windows splash screen, the reboots and starts the whole process again?
Try to boot into safe mode: When you see the first screen, hit the F8 Key repeatedly, which should bring up a menu of boot options. Choose the safe mode option, and hit enter. If it boots into safe mode, I would start by running a checkdisk on the hard drive. Here's how:
Hit the Windows key and the letter R, in the prompt that comes up type in cmd and hit enter.
This should bring up the console. type in chkdsk /r/f in the prompt. It should say the drive is locked, and ask if you want to run on the next startup. Type y and enter. Then reboot. The checkdisk should run, and may be able to recover any bad sectors it finds. If it finds lots of problems, a more thorough diagnostic should probably be done, as the hard drive may be failing.
Jan 01, 2009 | Acer Aspire T135 PC Desktop
Give me
Please reinstall your windows...
Sep 26, 2007 | Microsoft Windows XP Professional With...
Open Questions:
Computers & Internet Logo
143 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
