Question about HP Photosmart C3180 All-In-One InkJet Printer
HP photosmart C3180 stops printing
For some reason after working perfectly well, my printer suddenly won't print anything. The documents just keep backing up in the queue. One time it appeared to be solved by the offline/online selection. That hasn't worked this time. (it's confusing - if the online option is visible, does that mean it is selected or do you have to click it to select? Have tried both and makes no difference anyway...) I've tried the fixes sugested on the HP website down to the spool off/on but still nothing. Very frustrating! I have had VISTA since Feb and has only happened since then but that may not be relevant. Help!
  • 1 more comment
  • jaci212007 Nov 14, 2007
    MY HP PHOTOSMART C3180 STOPPED PRINTING I DONT KNOW WHAT TO DO BUT THE COPY AND SCAN PART DOES WORK WHAT CAN I DO?
  • Anonymous Jan 18, 2009
    i'm having the same problem, i have a mac and the hp supplies tools keeps on unexpextedly quitting and when i print it says printer is offline and jobs get stuck in que
  • Anonymous Jan 19, 2009
    After i have loaded the printer and set the printer for that type paper I press the black cartridge and themachine goes through the process in printing the article, but the paper comesou blank
    Scholar:
  • 21 Answers
Posted by JACOB I understand that you are unable to print and when ever u try to print the jobs stuck in queue... When we right click on the icon if we see a option use printer online this shows that the printer is offline, if we see a option use printer offline in the list then this shows that the printer is online status. To resolve the issue we have to first clear the job in queue. Open the printer folder and then double click on the HP printer icon this will show the jobs in queue just right click on each job in queue and select cancel to clear the job in queue if there are still jobs in queue we have to performe the restart the print spooler steps by keeping the usb cable disconnected so that all the jobs are clear when the spooler is restarted. One the spooler is restarted just reconnect the usb cable and check if there are any jobs in queue. If there are no jobs in queue we can move ahead an set the print directly settings. Steps to set the print directly settings: Right click on the printer icon and select properties then click on the advance tab and under it select the option print directly to printer and click on apply and Ok to save the settings. Once done try to print to check with the issue. If the issue presists you can try to check with the port settings. Right click on the printer icon and select properties and then click on the ports tab and check if the virtual usb001 port is selected if not select it and click on apply and ok to save the settings if you don't see any usb port check if you have dot4 port in the port list select it and save the setting and try to print this should resolve the issue.. Once done try to print and if the issue presists you can try to refresh the usb ports. This will re-detect the usb drivers for printer and you will be able to print after restarting the computer.
Posted on Sep 19, 2007
Simple problem, not sure how to fix it. my printer is offline but now i dont know how to get it back online. help
Posted on Sep 16, 2008
SOURCE:
The tri color keeps flashing, won't print
put the printer through its cleaning cycle as the jets may be blocked
Jul 09, 2010 | HP Photosmart C3180 All-In-One InkJet...
My hp photosmart c3180 printer keep saying check paper when im trying to print or copy something.
please disconnect the power cable from the wall outlet then press and hold the power bottoum for 20-30 sec then restart
and try to print test page and copy if still it not work then follow this instrution mention from the below URL
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00652863&cc=us&lc=en&dlc=en&product=1146331
if still your problem is not resolved then contact HP toll free number 1800-474-6836.they will replace your printer if its under warranty.
thanks
regards
Hamid
Feb 25, 2010 | HP Photosmart C3180 All-In-One InkJet...
My hp photosmart c3180 is very slow printing photos
It is just normal, printing photos required more detail/refine and for best result it should be print slower than normal printing.
Apr 11, 2009 | HP Photosmart C3180 All-In-One InkJet...
Can I enable my hp c3180 printer to print from windows vista
Hey Mainland,
The driver/software package for Vista isn't available on the install CD that shipped with the C3180. I think HP has a full feature driver available for download now though.
Take a look at the info here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01575424&lc=en&dlc=en&cc=us&lang=en&product=1146331
Hope it is a fix,
_K
Jan 15, 2009 | HP Photosmart C3180 All-In-One InkJet...
PRINTING IN BLACK ONLY
My solution would be stop typing in caps so I won't hesitate to help you, but my solution is to just buy the ink cartridges or get an old, black only printer instead of a $120.00 HP All-In-One c3180. I have one and I cant use it for some reason, but I'm trying to get it to work desperately...
Jul 25, 2008 | HP Photosmart C3180 All-In-One InkJet...
C3180 will not print as error occurs even when installed
Try printing a manual self-test page:
1. Press and hold Cancel on the control panel.
2. While holding Cancel, press Start Copy Color.
The self-test report prints, containing the serial number and service ID.
This should tell you if it is a problem with the unit itself, or with communication between the unit and your computer.
Feb 19, 2008 | HP Photosmart C3180 All-In-One InkJet...
Problems with Color printing
Click Start - All programs - HP - HP Solution center.
Click Settings - Print settings - Printer settings
Click on the Features tab. Set the print quality to best. Click on the Colors tab. Under color management - Enable the option Managed by Application. Click OK . close solution center. Try to print.
Dec 22, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
1,112 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
