Question about HP Laserjet M2727nf Multifunction Printer
Cannot scan displays "scanner error cannot connect"
  • 223 Answers
This could be one of two things,
While scanning from the pc the driver is not set up properly and you should uninstall and reinstall the software.
If trying to scan from the device, you have to set up the scan destinations to do so:
1. download additional product software from the install cd
2. go to the scan utility
3. set up
4. you should see 4 options
5. create a destination
6. update your printer
you should now be able to use the scan to button from the printer
Al
Eliteprintersolutions@gmail.com
Posted on Jul 14, 2010
    Novelist:
  • 102 Answers
Hi if you are are able to print fine from the computer than i m sure that printer is successfully connected to the PC and there is no issue with netwrok with connectivity.
In this case you need to upgrade the Firmware of the printer.
Use the link mentioned below and download the firmware and than run there will be prompt for you to select the printer from the dropdown list select the printer and click on send firmware and after completion of firmware upgrade restart the printer and you should be able to scan successfully.
Use the Link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3377075&prodNameId=3377079&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=ma-55531-6
Posted on Jul 02, 2009
Seems to be connected, but scans do not come through
none of the scanners I have owned had to have any programming parameters changed
May 17, 2015 | PANDIGITAL Panscn02 Photolink Scanner
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
Cannot scan documents
go to device manager look for imaging device (scanner) right click and uninstall. / click scan for hardware changes tab, found new hardware must be appeared and click next / select don't search, i will choose the driver to install / click show compatible hardware and choose scanner driver found and click next. and finish.
Feb 11, 2010 | Fujitsu M3091DC Path-Through Scanner
Scanner reserved for pc scan
Get the latest driver´s for windows vista or get rid of windows vista it´s not a good OS extremely slow and very messy a lot of problems a resources consumption.
Hope it helps
Jun 25, 2009 | HP LaserJet 3030 All-In-One Printer
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
TWAIN Driver Error
If connected via USB, unplug cable and insert into another available port and error message should disappear.
Nov 14, 2008 | Fujitsu fi-5120C
Error code 08
Unplug your scanner and switch off your PC. Check the USB connection is secure on scanner and pc. Wait for at least one minute, then switch both back on. Your display should go back to 01 now.
Sep 04, 2008 | HP ScanJet 7650 Flatbed Scanner
Scan gear error code:22500
Check Cannon support site, it has all solutions. Good Luck
Jul 26, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Scanner will not connect to PC
Make sure that the scanner file utility is running on the computer you are scanning to. Go to Start - Programs - Scanner User Software - Scanner File Utility. It will open in the system tray by the clock on the PC. Try to scan again. If still have the same error, go to the webpage of the scanner (just enter the IP address of the scanner NIC in Internet Explorer. Go to the bottom left side of the page and click Scan to PC Destination List. Click on the number to the left of the name you are scanning to. check the IP address listed on the webpage and make sure it matches the IP address of the Computer you are scanning to. One of these should fix it.
Please remember to rate you answers.
Dec 28, 2007 | Kyocera CS-2550 Black and White Copier
HP Laserjet M2727nf Multifunction Printer Logo
680 people viewed this question
Seeker5211
Seeker5211
