Question about Dell E193FP 19" Flat Panel LCD Monitor
Dell 19" monitor screen turns blank
I have a dell 19" inch lcd monitor and when turned on it shows the desktop of a second then the screen turns blank. The power light on the monitor stays on. I tried a different cables an a different computer but still same. I dont have a warranty but want to fix it, if i knew what the problem is??
  • 1 more comment
  • Want2repair Nov 27, 2007
    Dell 19" monitor powers on fine displays image for a few seconds and then no image. Power light stays green no flashing. power it down and then back up shows and image and then goes blank again. same thing no matter how many times you trun it off and on.
  • lapeen2 Jan 28, 2008
    Same issue... brand new monitor that I just got on Friday. Mine is a widescreen 19"
  • solar113323 Mar 24, 2009
    the same problem is happen when the power is on it works properly after 4 second the screen will be change to black some times it workers proper until the computer is restart
    tanks in advance
I had same problem, fault was traced using a multimeter set to diode measurement, i found that one of the high power switch transistors in the inverter side of the power board was short circuit (there are four in the same area sticking up from the board, not surface mounted). normally they should measure 450 ish but when they read 0-010 its gone, pulled it out of circuit and remeasured it, gone, replaced and fixed.
Posted on Mar 10, 2009
Press Fn and F6 when you turn it on
Posted on Jan 31, 2010
  • 46 Answers
Your inverter power board has gone bad, www.lcdrepair.us sells the board for $49 and has instruction videos or will fix the whle unit for $69 regardless of the problem.
Posted on Jun 21, 2008
  • 63 Answers
Unfortuneately this is nothing that is going to be fixed over the internet. Do you see anything at all when the screen goes blank, an outline (very, very dim) almost like a ghost image, on the desk top? Sounds like the inverter on the lcd has gone out. It would be a lot cheaper to get a new monitor than to fix this one.
Posted on Sep 18, 2007
I have a Samsung syncmaster 933bw 19 inch LCD monitor. It use to work but for some reason it stopped. When I turn it on, it comes on normal and shows the background of the desktop for about 2 seconds and...
hi, try to open the monitor back cover, then look at some of the capacitors in power supply modules if anything looks normal maybe the problem on it are the socket of the flex,
try to unplug aligned and plug it back.
hope this will help......thanks
Jun 18, 2017 | Computers & Internet
Screen Too Bright
Do a factory reset on All Settings:
http://support.dell.com/support/edocs/monitors/se197FP/EN/ug/setup.htm#Using_the_OSD
Dec 06, 2009 | Dell SE197FP 19 inch LCD Monitor
Pavilion f1903 silver goes blank seconds after turning on.
The monitor you have has bad components on the circuit boards inside.
This is a classic problem with all LCD monitors.
I rebuild them on a daily basis so I recognize the symptoms.
I would suggest finding someone who can do component level repair on the circuit boards inside.
I also suggest not trying to repair yourself as there are many breakable components to them as well as components inside that do not like static electricity discharges.
May 17, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Power supply on 17" acer monitor
franh, Typical of a lcd/fpd monitor! There is nothing you or hundreds of others can do to repair it all by yourself. I have repaired 3 monitors and helped tutor 2 others on fixya with their monitors. All had same exact symptom as your monitor. I need you to do a simple test for me. With failed Acer monitor near to your Fully Booted PC with a known good desktop being displayed on back-up monitor, quickly swap out the monitor cables from the back of the PC. Keep touching the CTRL key on you keyboarb every 30-50 seconds to keep the PC from sending out sleep mode command to monitor while doing the reconnect of acer to your PC monitor output port. Make sure the Acer also is connected to a live wall outlet/power strip. Turn on the Acer and note what happens. If screen shows a sharp clear image for a second, then goes black, do the following. Get a bright flashlight and shine it on the screen from a distance of 1 or 2 inches and tell me if you can see the desktop display. get back to me with your observations. I'm louie12fix on fixya or lmistyrel@ aol.com.
Apr 05, 2009 | Acer AL1916W 19" LCD Monitor
19 inch Dell Moniter Screen turns blank
i think may be its monitor problem or may be the wire problem that are attached with ur CPU...... change it and then see its again wrking??????
Mar 23, 2009 | Hitachi CM721F 19 in.CRT Conventional...
Screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Jan 20, 2009 | Samsung SyncMaster 940N 19 inch LCD...
Philips 19s lcd monitor
you have to replace the capacitor in the high voltage board inside your lcd if you know how to open it
Nov 03, 2008 | Philips 190S7FS (Silver) 19 inch LCD...
LCD monitor from "LCD Universe"
Inverter unit inside the screen may be defective
Apr 07, 2008 | Computers & Internet
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Dell E193FP 19" Flat Panel LCD Monitor Logo
897 people viewed this question
Alun Cox
