Question about LG LD40E Dehumidifier
Why isn"t my dehumnidifier putting out any water?
  • 105 Answers
It could be that it is just too cold still. Typically these units don't work well if it is under 70 degrees. However....we have had a lot of problems with these machines. Many of them have either sealed system problems (leaks) or the fan motor fails. I would suggest that you take it to an authorized repair center if possible. I believe there is a five year warranty on the machine.
Posted on Apr 17, 2009
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Nov 27, 2012 | Kenmore 54351 Dehumidifier
Danby Dehumidifier DDR7009REE leaking water, bucket not full
The unit may need cleaning. You can contact Danby customer service (1-800-263-2629) to get in contact with a technician.
There may be something clogging the passage to the bucket and the water is finding the path of least resistance.
As well, it is important to remember to clean the filter once a month.
May 14, 2012 | Danby DDR5009EE Dehumidifier
No water collected
check to see if the fan is blowing across the condenser. there should be warm air blowing out the back. if there isn't, the fan may need to be replaced so the heat exchanger can cool down. may be running too hot. also check the condenser in the front to see if the air flow is blocked with dust. if so, change the filter if it has one. if there is cool air blowing, the compressor may not be turning on.
May 11, 2012 | Dehumidifiers
The dehumidifier motor is on but only extracts tablespoonfuls of moisture from the air every 48 hours. In other words it isn't functioning as it should. Model #DH40; traceability code GR and barcode...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 10, 2011 | Goldstar DH304 Dehumidifier
Our LG LHD45EL 45-pint Dehumidifier is not collecting water. The fan is running, and there isn't any error message in the display. I have tried unplugging it for a while to see if it would re-set....
heatman101
Jul 14, 2011 | LG LHD45EL Dehumidifier
Right when I turn it on, it says "FULL". It is not full. I have a hose to drain it. There is a part in the front that opens up. There's no water inside... This isn't even a year old.
The float valve in the top of the bucket may be stuck in the UP position. If so, gingerly jiggle the float valves arm, to get it to return to the DOWN position.
Hope this helped you.
Jun 25, 2011 | Kenmore Dehumidifiers
I just bought a friedrick 1883 50 pint dehumidifier but it came with no manuel. it's working great except its not collecting water in the water tray. what am i doing wrong?
Go here for a manual along with other resources.
http://www.friedrich.com/support/brochures-and-manuals/residential-dehumidifiers
I suspect that it isn't collecting water either because there is not enough moisture in the air to remove any water, or the humidity setting is to high.
Thumbs Up if helpful, Feedback is Appreciated!!!
Jun 17, 2011 | Dehumidifiers
Dehumidifier isn't not removing humidity. Fan and lights are working, but the water container remains empty. It is not pulling water from air. I think that the heating element may not be working.
heatman101
May 25, 2011 | DeLonghi DE500P Dehumidifier
I have a FDL70S1 dehumidifier that runs and runs but doesn't take out any moisture from the air. I have cleaned out the filter and front screens thoroughly but it still doesn't work. The unit...
heatman101
May 10, 2011 | Frigidaire FDL50R1 Dehumidifier
How much water to put in the water entering tray
dehumidifier's remove moisture from the air,so you really don't want water anywhere close, the tray in a dehumidifier is to collect water removed from the air. a humidifier is easy, you put a pan of water close to a heat source or moving air
Jan 31, 2010 | Dehumidifiers
LG LD40E Dehumidifier Logo
359 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
