Question about Nintendo DS Lite Console
A pin in the slot 1 is broken
Last day my brother have stick a piece of tape into the slot 1 of the ndsl...
and when he attempted to remove it I notice that one of the pins in the slot 1 of the NDSL was broken or cut....
Is this still repairable or not?
  • bane_cyclone Apr 18, 2009
    no I mean it is really broken, one of the pin fall out and I could not play anymore because of that, I was asking if it is still repairable or I need to buy a new ds...lol
  • 4 Answers
As long as it is still in place it should still work
Posted on Apr 17, 2009
Replaced ink and it still shows replace ink
I have the same problem at times. After putting new ink in you need to spool it. Call brother help line for free and they will tell you how to do this. I am sorry I don't remember how- sometimes turning it off and on will help. Also, I have noticed that if you put it in too quickly it will not recognize it. Try some of these. Spooling is the best try going to your control center and check all options!!!
Hope it helps-
Jul 23, 2011 | Brother Office Equipment & Supplies
I have a cd stuck in my cd player and can not get it out i have a 2003 e class merc
FIRST Reduce electrocution risk by disconnecting all power supplies from the CD player and make sure any electrical charge has been removed.
Method 1
Take a blank/useless CD (such as AOL free trial CD's, you can get them in a plethora of amounts in Best Buy) and place it about 1 inch deep into the slot
Press the 'Eject' button and gently wiggle the CD around. If this doesn't work, repeat and try to get the blank CD below the the jammed CD, and gently pry the target CD upwards.
Method 2
Get a 1 inch to 2 inch wide putty knife and wrap tape around it with the sticky side of the tape on the outside of the knife. Use a strong tape like Gorilla tape for best results. The knife is typically tapered so that if you wrap the tape tight enough it will not slide off the end
Get a piece of paper and stick it to one side of the knife. Trim with scissors. You now have a thin sticky knife you can slide into the CD player opening
Insert knife into CD player with sticky side down trying to get it to go on top of the CD that is stuck. Press down gently to get the tape to stick to the CD.
Gently lift up and pull the knife out. Hopefully the CD will come with it. You might try hitting the eject button if it doesn't work the first time.
Method 3
Get a stiff plastic "card" - like a drivers license but a bit thinner. Put double-sided scotch tape on one side of the card, near the edge of one of the two narrow ends of the card.
Get a thin-stemmed flat head screwdriver (short is better).With the sticky side of the card facing down, stick it into the **** ABOVE the stuck CD. You may have to use the screwdriver to ensure the card goes in above the CD and does not stick to the CD until after you get 1/2 to 3/4 inch of the card in above the CD.
With the card still in there, insert the thin flat screwdriver ON TOP of the card and gently press down on the card. This causes the tape on the bottom side of the card to stick to the top side of the stuck CD.Remove the screwdriver and then slowly pull the card out. The CD should come with the card.
Check out this youtube viedo for a first hand look at what to do.
May 25, 2011 | 2004 Mercedes-Benz Mercedes Benz E Class
Can not find second ram chip
Remove both pieces of ram (mark them with a felt tip marker so you know which one is which), and clean the contacts on the ram and the slots with a pink pencil eraser. Be gentle though, you don't want to remove the gold on the contacts, just remove the oxidation and make 'em bright again. You can shape the eraser to fit the slot with a sharp knife - and be sure to remove the eraser debris from the slots with a soft brush (dry toothbrush is good) . If still no good try this:
  1. Remove both pieces of ram.
  2. insert the second piece of ram in the first slot (leave the other slot empty) If the second piece of ram is detected, then the ram is good, and the second slot is likely the problem. If the ram is not detected, then the second stick of ram is the problem. Confirm this by putting ram stick 1 into slot 2. If the known good stick of ram (1) doesn't work in slot 2, then the slot is dead. If this is the case, get a larger stick of ram for slot 1. Let me know if this helps or not.
Aug 08, 2009 | Computers & Internet
Nintendo ds bent pins
The part with the damaged pins is the slot-1 port. I know it seems rediculous, but this part is too impractical for most people to attempt a repair.
However, if you are savvy enough to attempt the repair of the damaged pins on your DS Lite, here are my recommendations:
1) Cut a flap in the slot-1 port cover and straighten pins.
2) Replace the main board.
3) Remove the slot-1 port cover and straighten pins.
4) Remove the damaged pins from the slot-1 port and straighten.
5) Replace the slot-1 port.
All of these recommendations require disassembling the DS Lite using a specialized triwing (or Y) screwdriver and a lot of patience. The following video will help in disassembly: http://www.youtube.com/watch?v=HQlTpTLUyFQ.
Recommendations 3 to 5 all require solder work. Recommendation 3 requires solder work for 4 solder joints, 1 at each corner. Recommendation 4 requires solder work for up to 17 solder joints, one for each damaged pin. Recommendation 5 requires solder work for all 21 solder joints.
Dec 10, 2008 | Nintendo DS Lite
Correction tape
To replace the correction tape:
1) use [SPACE BAR] or <<-¦ to move the carrier to the centre of the platen
2) open the top cover
3) remove the cassette ribbon (if installed)
4) pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen and lift it up and out.
5) Pass the new tape through the left guide, behind the ribbon guide, and out thropugh the right guide. The rough (stick) side of the tape should face the platen.
6) Attach the feeder spool to the pin on the left
7) Attach the take-up spool to the pin on the right
8) Turn the take-up spool counter-clockwise until a small amount of white tape has wound around it
9) Replace the cassette ribbon and close the top cover
10) Press 'spider web' key +// to move the carrier to the previous position.
Hope this helps.
Regards TC
Jul 16, 2008 | Brother GX-6750 Typewriter
Broken ds lite. the games were inserted into slot 1 the wrong way round. the pins are bent.
Jun 27, 2008 | Nintendo DS Lite
Sd card stuck in memory reader of toshiba laptop
I had the same problem, read some of the proposed solutions and came up with one that worked for me! Here it is: (1) cut a piece of duct tape that is about half the width of the slot and a couple of inches long (2) use a small flat head screwdriver and depress the card down, so that a small gap is created above the card (3) take a second small flat head screwdriver and force the tape into the gap above the card - adhesive side towards card (4) continue to work the tape into the gap so that it covers as much of the card as possible (5) remove the screwdrivers and gently pull on the tape until the card is removed!
Apr 01, 2008 | Computers & Internet
Memory Card Error
Chances are that the contacts in the card slot are either dirty or worn out. First thing I would try would be to try blow out the card slot. I suggest caned air, You could use a straw and Puffs of breath, but keep it dry. If that doesn’t work put a lint free cloth over a piece of cardboard about the same size as a memory stick. Be vary careful that it is not thicker then the memory stick. Dampen the end with Alcohol (Denatured Alcohol is best but standard rubbing alcohol might work in a pinch). I repeat, dampen with alcohol not dripping wet. Remove the battery just to be sure. Insert the swab into the card slot a half of a dozen times when you pull it out look to see if you see any residue on the swab. Hopefully you see dark stripes on the cloth. Let the camera sit with an empty slot (and no battery) for a hour before you try it again.
If all that fails the last chance (short of replacing the card reader) try to put some electrical tape on the memory stick on the side opposite from the gold contacts, be carful not to cover the contacts. Try one piece of type at a time and DON’T force the memory stick into the slot This will slightly increase the pressure on the contacts inside the card reader slot. If you have to resort to this be carful that the tape sticks completely and that it is neatly trimmed, you don’t want the type coming off inside the cameras. If this works you will need to add tape to all memory sticks used in this camera. I would NOT use any “taped” sticks in any other readers without removing the tape first.
Feb 12, 2008 | Cameras
Nintendo DS Lite gold teeth bent
I dont like to give you bad news but this is a difficult part to find and replace without some technical knowledge, and even if you get it, i.e. from a parts NDS, and with the technical knowledge, its difficult as this part is surface mounted and have many pins to desolder.
Actually I dont remember how difficult is it to put the pins of SLOT-1 in place by opening the device though you can try that as first option (find some open NDS pictures, the guides are also online everywhere).
You can also use a SLOT-2 (GBA) game cartridge for backups (ROMS) with flash memory as many options are online too but may be dificlt and you may need to do some proccedures as you cant use the SLOT-1 (NDS games).
The other option is to buy a broken NDSL somewhere like ebay making sure the main board works good, as you dont worry about broken hinges, cracked screens, etc. Or last pick, sell it for parts.
Good Luck...
Oct 10, 2007 | Nintendo DS Lite Console
Correction Tape
Is the ink cartridge correctable ( yellow or orange core) not nultistrike (blue core) ?
Aug 29, 2007 | Brother EM-530 Typewriter
Nintendo DS Lite Console Logo
119 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
