Question about Sony PlayStation Portable (PSP) Console
Psp is working very slowly
My psp started working very slow. but only games are running slowly.
all my songs are being played normally. what is the solution
    Sergeant:
  • 239 Answers
Lens has to be clean
Posted on Apr 17, 2009
My psp works really good but when i try to play games or movies it starts to slow down and flicker
1. Set “UMD Mode” to M33 driver NO UMD
The PSP firmware version was 3.71 M33 but is also tested with higher versions like 3.8 M33. These firmware versions should have the UMD mode to M33 NO UMD.
To set the following you need to go to the Configuration Page. To go there you need to:
i. Turn off your PSP
ii. Press and hold the R button. While doing that slide and hold the power button up. This would turn on your PSP. You should hold until the black screen appears saying “M33 Recovery Menu Configuration”
iii. If the PSP just turns on to the normal menu, just repeat the two steps above.
2. Set “Use VshMenu” to Disabled.
It is also in the configuration page. Use the steps above and you should be able to find it.
Now after these two steps, if you continue no further, your PS would run faster – but only for the menu screen. The menu would be fast and really responsive. However, try playing a game. You would notice that loading is still slow and the gameplay is still played in slow motion
3. Set the CPU speed to Default.
Now this is really important. The CPU may not really be used when playing music or in the menu screen but its very important when you play games.
There are two settings you need to adjust. Speed in XMB and Speed in UMD/ISO. For us normal users we just need to set these two to “Default”.
After this, your PSP should be running ok. However, I recommend that you do another step which would also help the performance of your PSP.
4. Free up memory from your Memory Stick.
You can do this using two methods. One, you could connect your PSP to your PC using a USB cable. Two, you could remove your memory stick and use a card reader. I prefer the second method but you may use any of the two.
Method Two: Remove your memory stick and use a card reader.
Freeing up memory is easy, if you know what files to remove. As my friend is not really using her PSP for music and videos, majority of her files are game files. What she does is that she just puts games that she really plays. I recommend doing the same for your PSP.
Game files are located at the folder named “ISO”. The game files have a .CSO file name extension. You don’t need to delete them. Just transfer them to your hard disk. That way, when you want to play them again, you just have to transfer them back to your memory stick.
But if you have music and video files that take up much space, I recommend that you look into those first. Normally you would like to have at least 500MB of free disk space. You’d need the space for your game saves.
My friends have done the steps above with ease and have solved their slow PSP problems. Most of them, if not all, had to do all four mentioned above. The first three usually solves the problem.
Mar 07, 2010 | Sony PlayStation Portable (PSP) Console
Hello...i start my PSP everyting is OK but whe i try to play game slow?
Your memory may be to full to run a game as fast as it is supposed to be try deleteing usless info
Jun 22, 2009 | Sony PlayStation Portable (PSP) Console
Psp works slow
press the power button on your psp phat then press the r button triggerly and go to the cpu speed then press x button then default thats it
Jan 05, 2009 | Sony PlayStation Portable (PSP) Console
Zune 30GB plays songs at slow speed
Go to settings in the top right portion of the Zune software,
Click Device update, make sure it's up to date, then install games.
Darndest thing, but it worked for me. :)
Oct 22, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
PSP SCREEN FLICKERS AND GOES SLOW IN MAIN MENU
Go to psp recovery menu and set the CPU speed in XMD to default, it should work
Aug 23, 2008 | Sony PlayStation Portable (PSP) Console
PSP running slow
I'm not sure if there is a VHS menu on normal firmware, but if your running custom most likely the problem is your last update. Here is how to fix:
Click Select->Select CPU Clock XMB->Toggle To Default->Exit Menu
Because your PSP is running on something like 20/10 and lagging real bad it may freeze when you open the menu, if so turn your PSP off by holding the power button up and forcing the shutdown, keep trying until you can get the menu working. It will also not respond to your commands properly, when you click down it will move through like 3 options because of the lag, be patient wait till it lands on CPU Clock XMB and follow the instructions. Happy Gaming!
Mar 11, 2008 | Sony PlayStation Portable (PSP) Console
Psp game
What firmware are you running? Are you playing game from UMD or Memory stick
Dec 08, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
74 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
