Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Westinghouse SB907 - Water draining out right after filling up
Hi
I have just bought a second hand Westinghouse Dishwasher SB907. The Dishwasher fills up with water and then sounds like it has started to wash, but then all the water drains right out of it again.
Thanks in anticipation
Helen
  • 105 Answers
The drain hose has to have a loop in it. In other words as the drain hose exits the dishwasher, it must go up at least 18 inches before it goes down into the drain. If not, the water will siphon out of the machine.
Posted on Apr 17, 2009
Hi, My westinghouse dishwasher SB907 goes through the washing cycle but doesn't seem to heat up and use the hot water. I have changed the little switch thing, that costs around $20, so what else cold be...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 06, 2011 | Dishwashers
Westinghouse sb915 - draining too early.
1. Is your drain point higher than the bottom of the dishwasher? (ie, does it drain into the garbage disposer or does the drain line drop down below the floor into house plumbing?) Did you just install the unit? You may have to install an "air gap" to prevent syphoning.
2. Did the dishwasher work then suddenly stop working? (asking for clarification)
Dec 13, 2009 | Westinghouse Dishwashers
Hi, I installed LG dishwasher, control board is working, water is coming from the water line but when hooked up to the dishwasher and dishwasher is on, there is no water coming into the dishwasher....
it should drain a bit of water out before it fills when it first starts. if that water doesn't drain out then you may have a drain pump fault. You can test this by dumping a few glasses of water into the machine then starting it up ( you should hear it drain that water out)
if that worked... then you have a fill solenoid fault or a line filter fault.You can check power to the fill solenoid or give it a couple of taps when its suppose to be filling to see if its just stuck. the inline filter could be plugged where you hook up the water supply to the machine (clean it or take it right out)
Aug 23, 2009 | LG Dishwashers
Water does not fill .
chances are, your water switch is stuck..
its the thing inside the dishwashe that kinda looks like a plastic mushroom.. (its a float)
sometimes they get corroded with excess detergent.. wiggle that up and down some to free up the float and it just might fix your problem.
May 25, 2009 | Westinghouse Dishwashers
Does not fill or drain.
Test the timer control board and the impeller pump.
pump is tested by energizing. Board is tested using a multimeter.
Observe strictly safety rules.
May 21, 2009 | Kenmore Dishwashers
Our westinghouse 921 does the first part of a cycle then switches off
most likely if your dishwasher fills and then stops with clean water still inside and hasent drained your problem is most likely your pressure switch is sensing an over fill situation possibly a blockage in the pressure switch hose or split in pressure switch hose or a faulty pressure switch.
Mar 29, 2009 | Westinghouse Dishwashers
Westinghouse SB907 Dishwasher
ON the the control pannel it might show a symbol of a lock. You will need to hold that key or sometime Keys for 3 to 5 seconds to release the control lock.
Sep 15, 2008 | Westinghouse Dishwashers
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
469 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
