Question about Rockford Fosgate 100a2 Car Audio Amplifier
Crackling in 1 channel
I have an old school punch 75 pre hd that has a bad crackling in 1 channel. It was both channels. I replaced all output fets, all the ao6 and a56 transistors, all emitter resistors and 1 side works great but the other does not. The side that does not work will not bias either. I did find a very burnt resistor just in front of the transformer but don't know if it is part of the chaneel or causing the problem. Its so burnt I can't tell the value. Its right next to a IN5336B diode. A picture would be nice. Please help??
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
MJE182 is a replacement for the now obsolete D40D8, although the D40D8 is still available on e-bay.
Posted on Jan 09, 2016
  • 1,068 Answers
Sounds like the D40D8 transistor the one that stands straight up on the board and not heatsunk! there are two of them. could have a cold solder joint there. have had a few of these problems from people doing hack repairs to them. they look like this http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290297644906&ssPageName=STRK:MEWNX:IT
Posted on Sep 16, 2009
Operate my samsung smart tv
The problem is 1 of 2 boards. Bad capacitors on the power supply or 24V missing on the output section of it. The other common problem is the inverter boards. 1 or more FETs are shorted and the surface mount fuse is open OR the PWM IC is bad. Hope this helps you.
Mar 02, 2015 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Lost remote sand need to be ablr to put TV on channel 3 for DVR hookup. problem is i had clean antenna and the channel is 3.2. or 3.1 who do i fet to channel 3 manually?
go to your menu button bring up add/delete start at 1 and and when it gets to 3 add it add 4 also just in case 3 doesn't work ! or go to ebay and buy a remote that is what i did .. good luck
Jul 03, 2014 | Emerson LC320EM2 32" LCD HD Television
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
How to bridge a 1 channel 1000 punch 55amp
You can not bridge a 1 channel amp. Bridging is when you combine the output of a bridgeable two channel amp into one channel, typically to power a sub woofer.
Feb 13, 2012 | Rockford Fosgate Car Audio & Video
When i started to plug my battery in my amp made
you have blown the actual filters that make the sound. a amp is basically a filter with the same filters on both channels on each side of the inside of the amp - channel 1 and channel 2, that pop was in the heat sinks of the amp usually. if you have replaced the fuse in this amp and you get no on light, the internal amp is in need of repair
Oct 24, 2009 | Rockford Fosgate Punch 401S Car Audio...
Crackling
Possibly bad news I am sad to say. You might have lost the transistor in the right channel output Or if it is an IC that. The things on the heat-sink! However you might be lucky and it might be just either a bias resistor or a ceramic capacitor. The small components are cheap the bigger ones tend not to be. Resistors often look burnt, but apart from that is a case of replace and see.
May 28, 2009 | Audio Players & Recorders
I cannot find the specs or user manual on the JVC archived items list. A few sites want to charge $10.00 for the user guide info, but I think that is too much to charge.
Defiantely not 200 watts
KS-A82
  • 2 Channel Amplifier
  • Bridgeable 2 channel amplifier
  • Output power: 25W x 2, 20 - 40,000 hz at .08 THD
  • 2 ohm stable
  • Adjustable gain (.1 - 2v)
  • MOS-FET DC-DC converter
  • Multi phase connection
  • 1 Pair of line input terminals
  • Remote relay turn on system
  • MSRP: $159.95
http://www.admtechusa.com/JVC.html#KS-A82
May 22, 2009 | Car Audio & Video
UHF Tuner
Check to see if the TV/CABLE setting is on CABLE.
Jun 05, 2008 | Sony KV-27V42 27" TV
P10002 blown?
needs repair bad fets or outputs
May 08, 2007 | Rockford Fosgate Punch P10002 2-Channel...
Rockford Fosgate 100a2 Car Audio Amplifier Logo
422 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
