Question about kawasaki 19.2V 4 Piece Cordless Tool Kit
Drill chuck locked up
The kawasaki drill chuck is locked up/broke, is there a way to fix it or do I need to get a new one. this drill is only a few months old and I bought it through Sams Club. Thanks.
  • 25 Answers
Your problem is with the screw holding the chuck onto the shaft. That screw if a reverse thread and needs to be tightened in reverse direction.
Posted on Apr 23, 2008
  • Carl Blank Apr 23, 2008
    Your problem is withe the screw holding the chuck onto the shaft. Thart screw has reverse threads and needs to be tightened in the reverse to correct the problem
  • rohit510 Jan 28, 2011
    where can I found the screw?
    I bought the drill from costco
1/2 hammer drill and the chuck is broke what do I do to get. New drill or fix
Assuming that the drill is still operating, I suggest that you get a replacement chuck, To remove the old chuck, insert the chuck key in the cogs on the left hand side as you hold the drill facing outwards, then using a hammer tap the chuck key firmly so that the chuck will revolve anti clockwise. Replacing the chuck us the reverse of the above procedure.
Apr 05, 2017 | Hammer Drills
The bit wont lock in the drill, how do i fix this problem
This is a very easy fix - you have a quick change chuck on this tool. Turn the chuck counter-clockwise and pull it straight off - the new one goes on the same way. Quick Change Bit Chuck
May 23, 2014 | Bosch 11236VS Rotary Hammer
Chuck broke on my hole hog how i fix it
The back needs to come off, you need to remove the spindle, press it off the gear, replace it by pressing the gear back on and reassembling. You will need to have your serial number then go to toolpartsdirect.com and look up the parts diagram. It looks like the part number is 38-50-5076 which also comes with a new chuck. I just looked at the kit as I actually have one in stock.
Aug 16, 2012 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Cant get the bad chuck off my RIDGID 18v cordless hammer drill
The chucks on these drills are put on not only VERY tight but usually with some lok-tite to boost so they don't come off easy. In my shop we usually lock a 1/2" hex driver in the chuck and use a 1/2" impact wrench to knock them loose. It usually takes a few seconds to come loose. Another method is to lock the short end of a 1/2" allen wrench in the chuck so that it sticks straight up with the drill standing up. Then lay the drill on its side with the top at the edge of your bench and the allen wrench sticking over the side of the bench. NOTE: The chuck follows the lefty-loosey, righty-tighty rule, the chuck screw is reverse thread. Have someone firmly hold the drill and then hit the end of the allen wrench until the chuck comes loose. Once you break it free it will spin off easily. You do need to put the new one on with lok-tite and as tight as you possibly can then lok-tite the screw and tighten it as much as you can by hand.
Jan 20, 2012 | Ridgid Drills
Hi i broke the chuck on my 1/2 makita cordless
Put the biggest hex key you have in the chuck and tighten it then hit it clockwise with the spindle lock engaged a couple of times. The screw in the chuck will then undo clockwise and the chuck can be undone after by putting the allen key back in and unscrewing it anti-clockwise maybe with a light tap from a mallet.
Hope this helps
Jon
Jul 01, 2010 | Makita 6349DWDE 18-Volt Ni-MH 1/2-Inch...
My client has a drill press BDDP100 Type 1 - broken chuck
McMaster- Carr ships every where. www.mcmaster.com
There is probably a Grainger location in south Florida, they would ship any where you want.  www.grainger.com
There are a few different tapers used on drill chucks but they are pretty standardized: you don't need the black and decker part, you just need a standard chuck of the correct taper. try to get a basic Jacobs chuck they will last much longer than the one it came with.
Feb 28, 2010 | Black & Decker Drills
My chuck is broke , on my 18v makita cordless drill , how do i fix it
Put the chuck key on and strike it with a hammer counter clockwise. the chuck key must be properly seated in the hole. Once the chuck is brokrn free, you can unscrew it my hand. Buy a new chuck an screw it in olace and againm strike the key but no as hard clockwise. It will self tighten more as it is used, Good Luck-Ned-
Sep 17, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Dewalt Drill DC728. Chuck came out of drill body
I would clamp chuck in vise and use a chuck key or a Channel Lock Pliers to loosen the chuck.
Jun 08, 2009 | Dewalt Drills
Chuck broke on Skil hammer drill
As long as the new chuck threads onto the old spindle then any chuck will work fine.
Dec 19, 2008 | Drills
kawasaki 19.2V 4 Piece Cordless Tool Kit Logo
674 people viewed this question
Top kawasaki Drills Experts
Marvin
Marvin
jasbo
jasbo
john h
Are you a kawasaki Drill Expert? Answer questions, earn points and help others
