Question about Select Brands Matsonic mATX 800Mhz s775 P4, VGA/Audio/Lan DDR400 SATA RAID 0, 1, 3PCI 1 8X AGP, 8X USB2.0(BRAND NE... (MSP4M800M) Motherboard
How to know what RAM works for what MB?
Since not all RAM can be used on the MB! So how can a layperson know what RAM to use? It is going to waste lots of money trying right! If it is not enough just to follow the spec stated on the manual.
    President:
  • 2,961 Answers
You should go to a web site called crucial to scan your system to see which memory fits your motherboard, but be aware that not all makes of memory will work in your pc, it's best to try and get the same make or type as you already have fitted, click link below: http://www.crucial.com/systemscanner/
Posted on Sep 16, 2007
Slow loading,game cutting off
Try adding more RAM
Adding more ram will boot applications / games quicker
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
You should always ask or get working pairs in a ram upgrade some ram modules wont work together even if they are of the same brand and type ie: DDR ,DDR 3
Checking Amount of RAM
Click on "My Computer" and select "Properties" using right-click in the Explorer window.
This will open "Systems Properties."
Click on the "General" tab.
Here you can view the physical memory installed on your computer.
The amount indicated is the total RAM installed on your computer.
RAM is usually 32 MB, 64 MB or 128 MB in older PC versions.
Newer PCs are usually equipped with 256 MB, 512 MB or even higher RAM.
Check the usage.
To know the currently used RAM (based on programs you are running), open the taskbar or press "Ctrl + Alt + Del" to open a pop-up window. Click on "Task Manager."
Click the "Performance" tab.
You can view the amount of memory currently used by each program running on your PC.
Mar 18, 2014 | Computers & Internet
Hi, I want to upgrade my RAM from 256 MB 400MHz DDR1 (hynix) to 1GB DDR1. Do the both will work together or i would have to use 1GB alone? Im having ASUS K8V- VM motherboard. Will it be compatible with...
It will be compatible but it is recommended, you use same type of modules(RAM)
ie 256 MB + 256 MB
1GB + 1GB
Plus the advantage of using two instead of one(If you want 2GB, go for 1-1Gb two modules, depends on you) are, if one fails other works.
Apr 24, 2011 | Computers & Internet
What is better? to put four different rams or one single ram of 4gb in p4p800 vm asus motherboard
I would suggest going with a single piece or 2 identical pieces of RAM for expandability purposes. If you want to upgrade later, you will have the option to add more RAM. From a cost standpoint, you might be better off buying 2x 2GB sticks as a single 4GB stick of RAM might well exceed the cost of 2x 2GB sticks.
Best, Hunter
Mar 03, 2011 | ASUS P4P800-VM Motherboard
'm installin win xp on my pentium3 with 10gb harddisk n 256 mb ram... it shows setupdd.sys could not be loaded error code 7 durin installation.. i tried change d xp cd 3 times.. still hav same problem
change the cd-rom unit,i know it sounds crazy but try it before you waste anymore blank discs,im a tech and that is one solution that works ,good luck
Feb 27, 2011 | Computers & Internet
My system has a ddr 256 MB but it shows 192 mb only. what is the reason and solution plz
Your graphics card is sharing your system memory.
This means that you physically have 256 MB of Ram in you laptop, but the operating system can only use 192 MB of Ram because 64MB of Ram is dedicated to your on-board graphics.
Hope this answers your question!
Please remember to let me know if this information was useful!
Kind Regards
Dec 06, 2010 | Intel Motherboard
Se7520bd2 - I installed 4 GB of ram (2 sticks) I added later another two ram chips the same mobel. The M/B is not recognizing the 2nd set? My Emial is info@csmc-usa.com
1) unless your operating system is 64 bit, your computer can only use 3 GB RAM maximum, so 4GB is a waste of time.
If you already had two identical sticks of RAM, chances are your BIOS is setup to recognise twin channel RAM is it has larger bandwidth so it is quicker. To use two channels your RAM must be identical in both channels, clearly if 3GB is the maximum you have a lopsided config and you have to swap the BIOS to single channel RAM.
Of course if you have already checked the BIOS rather than windows, and it still only sees 2GB RAM, the problem is a different one.......
Feb 05, 2010 | Intel SE7520BD2 Motherboard
Hi All, I had intel d101 mother board, which ishaving ddr ram of 512 MB, now i want to upgrade it using ddr2. i know that is not the supported for my motherboard. i want to know is there any connector is...
It used to be a waste of time and the only solution was another MB. Now they have come up with higher value ddr's (I think they call them 2 in one). If these ddr's are available, then all you will need is to raise the CPU chip voltage. You have to give me the CPU speed in Mhz. I see it as a good possiblity to update the computer with more RAM and raise the frequency to make it faster. You can get some life out of the computer and then sell it and replace it with another new computer. I have worked with all kinds of mother borads. There are some very good and expensive ones (which are not any better than the others). There are also some expensive mother boards that are plain no good. In my years of experience, if I needed a new mother board, I would buy one of the various models that they curently have. The name of the company is PCCHIPS from Taiwan. I have three so far for my own personal use and I am happy. I started to ask you about the CPU speed and forgot to ask you to let me see it. This way we can make our decision, upgrade MB and speed up the CPU vs. Buy another MB vs. buy another computer. Remember that jut about all computers perform equally. Equally, it is the reliability. I have three laptops we use for travel: one Compaq, that after 8 months we had to replace the MB du to problems. New MB's are more reliable than OEM. My other computer is a 1600 series ACER. About a month after the buy, I lost the CD/DVD drive. Other than that, everything works.... The third one is a business computer by PH. It works and works and works... 3 years now. They have a good blower, unusual for the run of the mill, the computer is mostly cool, even when I have to leave on for overnight VOIP calls. My name is Constantin (arzconst is my nickname assigned by my employer Fixya.com)
Jun 13, 2009 | Intel D101GGC Motherboard
RAM / HDD upgrading
u need 1gb Ram in total it is more than enuff for u u will never feel short after this and sure it will boost performance , u have 512 mb
if u have 2 chips of 256mb each then u need to buy 512mb X 2 chips and ur old ram will be left with u , luckily if u have 1 chip of 512 mb in ur system then u will save money like only buy 1 chip of 512mb but pls check the whole ratings of ur RAM and make of RAM is it samsung or hynix chips or what bcoz u will have compatibility issue in matching ur old and new rams pls let me know of whole specs written on RAM i can help u in matching
if u need urgent boost in performance then i will suggest replacing hard disk u will see a big change in loading OS and opening programs RAM is secondary in this stuff , but it is imp u can also go for 756 mb in total if u dont want to waste money if u have 2 chips of 256 each
secondly go for 160/250 GB 7200 RPM drive for top performance but 5400 RPM is still fast in ur notebook it is like 4200rpm according too my expertise
pls rate me FIXYA for my analysis if u like
Mar 08, 2009 | Acer Aspire 5100 Notebook
Select Brands Matsonic mATX 800Mhz s775 P4, VGA/Audio/Lan DDR400 SATA RAID 0, 1, 3PCI 1 8X AGP, 8X USB2.0(BRAND NE... (MSP4M800M) Motherboard Logo
74 people viewed this question
Top Select Brands Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Select Brands Computer and Internet Expert? Answer questions, earn points and help others
