Question about RCA HD52W59 HDTV Projection Television
RCA HD52W59 REAR PROJECTION
I have a 52" RCA rear projection TV. My screen just went out. Warranty expired. The main menu displays, some colors are missing. The unit powers on fine and the convergence shows all four colors. The machine doesn't shut off itself or anything like that. The sound comes through on all inputs, however the picture doesn't at all. Can anyone help?
  • MauriceA Feb 02, 2008
    I have a 52" projectuion screen tv. It works for about 5min then i lose the picture (black screen). I still have sound. What could be the problem?
    President:
  • 4,402 Answers
There should only be three colors.. can they be aligned?
Posted on Jan 10, 2008
RCA HD52W59
I think already answered this but:
If on screen menu comes up hook up something to one of the rear av inputs and see if set works (have to move to that input with remote or input feature on front of set)
if picture etc that way tuner in set may be bad (look to see if coax fitting is loose or broken)
Mar 11, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 52 rca rear projection was watching tv and went black after a few minutes it turned back on from the power button and i have color lines on the screen and pic is ditorded almost like in a bubble....
Go to Menu ,then Setup look and see if you have Convergence on the Menu ? If you do not see convergence in the Menu then you have a Blowed Fuse FL231 on the Deflection Board.
Let me know what you have listed in the Menu.Problem is not in the Tubes R/G/B.
Feb 13, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 in HDTV red, green and blue colors not alligned - concave
That repair only repairs the issue of the convergence option missing from the on screen menu. If thats what your problem is then the ITC222A convergence option missing repair kit at the following link should repair the issue. The kit contains the fl231, DL231, CL230 and the CD with detailed instructions.
http://www.tvrepairworld.com/
Jul 17, 2009 | RCA D52W19 52" Rear Projection Television
Is the tubes going out on my rear projection tv?
If the red, green, and blue colors are separated like a rainbow, then the convergence amps are going out. This set has a common problem of two electrolytic caps going bad. The caps are in the upper left-hand corner of the main board and will have a bulged top if bad.
I would not think the picture tubes are bad, especially all at once.
- Dan
Apr 28, 2009 | RCA D52W19 52" Rear Projection Television
52 inch rca shows picture in 3 colors will not focus
is thr convergence adjustment option still listed in the on screen menu? Let me know and I will try to assist you.
Jan 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 Projection Big Screen TV
you have cold solder conections if you know how to solder you can fix it with a good light
Oct 14, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Convergence problems
That should still be under RCA warranty. Have RCA cover that repair before your warranty expires.
Apr 10, 2008 | RCA HD52W59 HDTV Projection Television
RCA 52
ok go into setup menu.... go to convergence.. try to adjust convergence .. does the crosshair move up and down side to side... if not then you might hqve q poblem with convergence power supply if they move then u might have s setup issue
Mar 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic Rear Projection TV
its either the color wheel or light engine they can both cause this symptom. I would inspect the color wheel see if its brken or at the very least got a good connection as thats alot cheaper than a light engine.
Mar 03, 2008 | Panasonic PT-47WX49 47" Rear Projection...
52 inch RCA big screen
check all connections and different sources(dvd, vcr, antenna) to make sure that it is the tv. otherwise i would say call a technician because you could be in for some extensive troubleshooting
Jan 25, 2008 | RCA P52960 52" Rear Projection Television
RCA HD52W59 HDTV Projection Television Logo
213 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
