Question about GE GSS23SGSSS Stainless Steel Side by Side Refrigerator
Testing if Fault is Comming From Defrost Heater
How do you test if the defrost heater is working or not on a GE GSS23SGSSS refrigerator.
At what temperature should the freezer be?
Should the defrost heater be disconnected?
Cold or at room temperature?
According to GE, this frig now requires dual kit and I am not sure right now what is inside my frig, single or dual defrost heater, How can I differentiate the two besides the obvious?
Thank you.
  • Tigran G Apr 17, 2009
    Can you explain a bit better. Thank you for your time. It us much appreciated.
  • 358 Answers
You check for continuity at each end of each heater.If is ok you have a bad defrost timer or abad defrost terminator(it 'll close when reaches about 30 degrees).
Posted on Apr 17, 2009
  • christian nielsen Apr 18, 2009
    The defrost heaters are atached to the coil inside the freezer in the back wall behind the back panel.When you take that pannel off you'll see the coil and in the bottom of that coil there's one heater element and in the middle you find the other one(they look like aglass pipe sopported by an aluminun rack and you'll see a wire comming out of each end of each heater.To make sure that the heater is ok you disconnect them and check for continuity between each end of eachheater if its burned sometimes you be able to see the black burned spot through the glass.If both heaters are ok the problem is either in the timer or in the defrost terminator(round thing with two wires also atached to the coil)that when the timer stop the compresor and the coil where this defrost terminator is located is under 32 degrees the terminator closes and energized the heaters.The timer is either inside the fridge where the cold contrl is or in the bottom of the refrigerator behind the grill.If the back wall of the freezer block with ice you can turn the timer very slow until you heard aa click or you heard that the compresor stop and if the heaters work and the terminator is ok after a few minutes you start hearing inside the freezer the water from defrost dropping on the red hot heaters and evaporated.In that case the timer is bad.
Refrigerator freezing even when you turn it down
Your refrigerator is freezing due to the unit most likely haveing a defrost issue. This is usually caused by the defrost thermostat, the defrost heater, or the defrost timer or adaptive control having a fault condition. If you remove the rear panel in the rear of the freezer it will give you access to the evaporator coil. Located to one of the side usually clipped onto one of the copper lines you will see a small circular round sensor with two wires coming from it. Unplug the machine and defrost with a hair dryer any ice build up on the evaporator coil. If you have a multimeter you can perform a ohms test to assure that the thermostat is working properly. A defrost thermostat usually has an ohms reading of at least .50 ohms or higher. Located under the evaporator coil is the defrost heater. If you unplug both sides of the heater you can also perform a ohms test with a multimeter which would usually read around 21 ohms or higher. Most often this issue is caused due to the defrost thermostat due to this part being manufactured poorly on most all machines. If you find that you have a positive ohms reading on both these mentioned parts. You would then look at the defrost timer or adaptive control as the part causing the fault condition. I will await your reply and to you testing these first two parts before further posting how to test the defrost timer.
I await your reply,
Thank you,
Rick
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ice building up in bottom of freezer, of side by side maytag
Hello there,
When you are experiencing ice build up in your refrigerator, it simply is due to a faulty defrost unit. The defrost unit is composed o9f the defrost timer, defrost thermostat and the defrost heater. Once the freezer is building up ice, the defrost unit turns on the heater, then the defrost thermostat turns off the compressor while the defrost timer, settings the routine timing for the activity.
Once a component out of the three develops a fault, the routine is stopped and then ice begins to build up in the back of the freezer or at the bottom depending on the type of refrigerator it is.
The solution to the problem is for you to have the defrost timer, defrost heater and defrost thermostat tested, that way you will be able to tell the faulty component and replace it with a new one.
To carry out the testing and replacing of these components, please read this tips, it will guide you on testing the components and replacing them.
Defrost thermostat http://www1.fixya.com/support/r10513592-test_defrost_thermostat http://www1.fixya.com/support/r10513650-replace_defrost_thermostat
Defrost timer http://www1.fixya.com/support/r10523722-test_defrost_timer http://www1.fixya.com/support/r10523742-replace_defrost_timer
defrost heater http://www1.fixya.com/support/r10523771-test_defrost_heater http://www1.fixya.com/support/r10523754-replace_defrost_heater
Hope this was helpful to you. All the best. Elect_Comp
Sep 26, 2011 | Maytag MSD2756G Side by Side Refrigerator
Lowest shelf and crisper drawers freeze food consistently. Have turned the temp dow to lowqest setting of #2.
Hello there,
Defrost timer
defrost heater
Sep 26, 2011 | Refrigerators
Ice forming on the back wall of refrigerator compartment It is a side by side...twenty years old
Hello there,
When you are experiencing ice build up in your refrigerator and a part of the refrigerator is not getting cold, either the fridge or freezer compartment. Then it means there is a problem with a part in the unit.
Investigate these three areas if frost and ice are forming in your freezer and your fridge is not cold enough, test Defrost Timer, Defrost Heater and the defrost thermostat when you detect where the problem is from, replace it.
Before you begin to test your defrost thermostat, defrost heater and defrost timer, make sure you disconnect the appliance's power supply.
Here are some tips for you to go through in order to solve the problem.
Defrost timer testing http://www.fixya.com/support/r10523722-test_defrost_timer Defrost timer replacement http://www.fixya.com/support/r10523742-replace_defrost_timer
Defrost thermostat testing http://www.fixya.com/support/r10513592-test_defrost_thermostat Defrost thermostat replacement http://www.fixya.com/support/r10513650-replace_defrost_thermostat
Defrost heater testing: http://www.fixya.com/support/r10523771-test_defrost_heater Defrost heater replacing: http://www.fixya.com/support/r10523754-replace_defrost_heater
All the best Elect_Comp
Sep 21, 2011 | Sub-Zero 695/O Side by Side Refrigerator
My rgr profile side by side is at 47 and wont go down
The PSS26MSRSS is famous for burn out of the defrost heater part number=> WR51X10042 or 914080 Defrost Heater you may click on photo or banner for Repair Clinic once on our web site. You should always replace the defrost thermostat while working behind the freezer rear wall with power disconnected. Part=> WR50X10054 Defrost Thermostat or 1170024 Defrost Thermostat
Watch our "Part Testing" video to determine if the defrost heater has burned out and needs to be replaced. Please rate this solution and as always thanks for usingFixya, Sea Breeze
Feb 10, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer ice up. how to defrost it?
The icing of the freezer is caused by the failure of either the defrost heater or the defrost thermostat, and sometimes, both. Before replacing either or both, it is good practice to determine which one has failed. WhileThe defrost heater can easily be tested with an ohmmeter to determine its state, such is not the case for the defrost thermostat. Testing the defrost heater alone can give a clue of which one is bad. In either case, replacing both would solve the icing problem.
Dec 23, 2010 | GE GSS25QSTSS Stainless Steel
GSS23WSTA refrigerator freezer section is getting warm.
Just the fist indication that defrost is not taking place. Most likely the defrost heater and defrost thermostat will need replaced. part number Click Here=> WR51X10101 for heater and will be easy to spot if burned out and you should also replace the defrost thermostat just in case part number Click here=> WR50X10068 Let me know if you need assistance, you may reach me through Appliance 911 or Sea Breeze Appliance Parts and Technical Services
Thank, Sea Breeze
Dec 25, 2009 | GE GSS23SGSSS Stainless Steel Side by Side...
Defrost Heater or Main Control Board, Which one is at fault?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To answer your question I know of no reason the electronic type of board would cause the heater to go out unless the defrost thermostat (or sensor) and board stuck in the defrost possession and did not stop the heater. Any time you replace the board and have had a defrost problem a check of the heater will either confirm or eliminate it but the defrost sensor should be replaced if the board is being blamed for non defrost. I cant rule out 100% that a bad board will not cause a heater problem but the high 99% range is most likely. If you have a volt ohm meter and can find the heater circuit on your board and the freezer has been running down to correct temp you can check the defrost circuit by ohming it out. Lower resistance of 10 to 60 ohms is common. Anything higher will require ohming the heater out directly and the defrost thermostat will be open if the temperature is above the stats range.
Common to all self defrosting refrigerators / freezers is the need to move air around to pickup heat inside the compartment. Common to all frost free refrigeration to maintain this feature are 3 items:
1 and initiator (defrost timer or circuit board),
2 A heat source for defrost (Usually an electric heat element but can be other types of heat sources)
3 A safety limit to stop the heat source, leaving it warm enough to defrost and keep the heat contained where it will not affect the compartment advisedly. In a standard type defrost (non - electronic) it is called a thermostat. In an electronic board defrost it is called a sensor.
The defrost timer / or board will never be in the Freezer. Other than that it could be in the refrigerator section behind a plastic cover or metal cover on the back outside. It could also be under Neath the front corners or center of the front kick plate.
A timer you can turn the cam clock wise till it clicks. A board will depend on the manufacturer as to how to send into defrost for a test. A sensor on the defrost type board may be required to by-pass into defrost or test mode.
The freezer section has the only cooling coil. It sounds like it is blocked with frost and thus won’t let the air circulate from freezer to refrigerator.
There is a defrost timer, (or board), a defrost heater, and a defrost safety thermostat. Any One of these or a combination of 2 can be your problem. If you have a energy efficient model that has electronic controls then you will have a board. The procedures for checking the circuit on a board vary by manufacturer of the board used and manufacturer of the appliance.
The defrost heater always has resistance and is attached to the freezer coil.
The defrost thermostat is also attached to the heater electrically, unless it is an electronic sensor type. Sensor types have a range of resistance that needs to be known to check and varies slightly with the temperature of the sensor.
If I haven't lost you here you maybe equipped with the life experiences that will allow you to do most of these checks. If its over your understanding I recommend you contact a reliable technician..
Apr 17, 2009 | GE GSS23SGSSS Stainless Steel Side by Side...
Defrost Heater on Refrigerator
It's located on the freezer side.Take off all the shelves and the drawer and you see a panel with lots of screws atached to the back wall , take it out and you'll see the coil and the heaters atached to it ,one in the bottom of the coil and the other in the middle.
Ge refrigerator & freezer not cooling - frost build up on back wall of freezer
You probably have a bad defrost heater behind back wall of the freezer if you turn the unit off and let it defrost a fan will help speed this up the unit will run for about 2 weeks giveing you time to get a defrost heater GE have glass tube heaters and they are bad about going out good luck
Mar 31, 2009 | GE GSS23SGSSS Stainless Steel Side by Side...
Open Questions:
GE GSS23SGSSS Stainless Steel Side by Side Refrigerator Logo
820 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
