Reboot and select proper boot device
At first it ask that need to reformat my hard drive ,i did reformat already then download a new xp program.it will to up but it will continue to rebbot and select proper boot device
    Scholar:
  • 39 Answers
Make sure that there is no floppy disc in the floppy drive.
If there is no floppy, the next time you start or restart your computer, there is that blackish screen that says hit Delete (or F2 or F12) to enter Setup Menu. Do that when you see it come up.
Then you want to move around in the options until you find Boot Devices. I usually set mine up to CD-ROM, Floppy (if you have one), then Hard Drive.
If you still get this prompt, then set your first boot device to be your hard drive.
Posted on Sep 22, 2009
  • 4 Answers
You will probably have to replace your CMOS battery (looks like a big watch battery) and check to make sure the HDD is fully plugged in. Also, I believe that if it tries to reboot again, you will want to hold down the F5 key while it is rebooting. Eventually, it should change to the system BIOS screen, and you can change the order of your boot device to one that works.
Posted on Apr 17, 2009
I tried to re-install windows xp to clean my computer (running slow). It aske if I wanted to include web updates and I answer yes. Computer went to a blank screen and no won't load from recovery disc or...
Hi, you will need to reformat your hard drive before installing XP, First boot into BIOS by pressing the F1 key during bootup, change the primary boot drvice to CD rom, save changes. Insert XP cd into drive and reboot PC; select boot from CD when this appears during the initial boot fase. Allow files to be installed. When this finishes, delete partion and then repartion hard drive. Select format hard drive, when this completes your PC will reboot, do not select boot from CD and XP will start to install normally.
Hope this helps, if not come back to me.
Aug 04, 2010 | Computers & Internet
On the mini 1000 - tried to install Windows xp (tried Vista and 2000 also) after a system crash. Since there is no dvd/cd drive I used an external drive with a usb interface. It starts to install and then...
Hi, you need to ensure your hard drive is set up correctly! To install XP first press the F1 key during bootup, select the primary boot device (your external drive) in BIOS, save changes and reboot, allow files to be installed, but when finished, select delete operating system, partion hard drive and reformat, allow system to reboot, then commence new installation of XP. If your problem persists it is most likely a bad section on your hard drive, and will need replacing.
Hope this helps
Jul 16, 2010 | Computers & Internet
How to reformat a computer?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Jul 19, 2010 | Microsoft Windows XP Professional
My 13 year old son laptop need be reset like new
There are a couple possible solutions to your problem. If the computer will still turn on and load windows, and I assume you are using Windows XP, you can try doing a system restore. To do this, go to Start, Programs, Accessories, System Tools, and select System Restore. If system restore is enabled, you should be able to choose a date in the past when the laptop was working properly and restore the computer to that date. If you want to completely reload windows, you will need a Windows XP installation disc. Load the disc in the CD or DVD player and reboot the computer. You should see a screen asking you to press any key to boot from CD, go ahead and press Enter. You will now enter setup where you can reformat the hard drive and reload windows XP. Follow the on-screen instructions to delete any old partitions, and then create a new partition and format it using NTFS. The windows XP installation will continue after the hard drive is formatted. If, when you reboot the computer with the installation disc in the drive, you are not prompted to boot from CD, you may need to reboot and press F2 or F12 to change the boot selection to the CD or DVD drive so it will load the CD first before it tries to load your original Windows installation.
Jul 18, 2010 | Dell Inspiron 1525 Laptop Midnight Blue
Restore will not work comp goes thru the motions and comes back with unable to restore, it doesn't matter how far back you go
Hi, I believe you need to reinstall your operating system, follow these instruction:
Hope this helps
Jul 15, 2010 | Medion MD-1768 PC Desktop
Problem is (the dist structure is corrupted and unreadable). please help
Hi, looks like you will need to format your hard drive and reinstall windows. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Jul 01, 2010 | Computers & Internet
How do I get my inspiron 5100 back to its original factory settings? I don't care if I loose my documents they are saved on a jump drive
Hi, if you have your Del CD, you can just put this in and select repair or reinstall. If this is not posible, follow the following:
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing ESC button, or delete in some machines. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Jul 03, 2010 | Dell Inspiron 5100 Notebook
Reboot and select proper boot device or insert boot media
its basically telling you that your master hard drive with O/S installation cannot be found in the booting system...Check if your master HD is not corrupted and see if your O/S still exist or maybe wiped out..
Mar 31, 2010 | Computers & Internet
After installing new Biostar Motherboard (MCP6P-M2+), Windows XP won't start
You may need to check your bios settings and make sure the proper hard drive is set to be booted. If it is, follow the next set of instructions.
Windows " tailors " itself to the hardware it's connected to when installed. An easy fix is to repair your XP install like thus:
boot the PC from the XP installation disk
DO NOT select recovery console if prompted, instead continue installation
when XP searches your HDD it will find your previous install of XP, when it does, it will ask you if you wish to install, or repaire, select repaire...
it will seem as if XP is being re-installed, infact it is, but it will retain your files, and programs.
Once completed, your computer should boot properly.
Nov 02, 2009 | Computers & Internet
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
