Question about Maytag Neptune MAH9700 Front Load Washer
Our Washer is overflowing through the dispenser drawer
When we use our washer, as it is filling up it overflows through the dispenser drawer and also leaks water from the bottom to the front loader drawer. How do we disassemble the washer to check out whether or not the water switch is broken or that the hoses are connected properly.
  • 1 more comment
  • sport532 Jan 06, 2008
    I have the same problem it just started. It does not do it all the time.
  • Anonymous Jan 07, 2008
    My washer just started to have the same problem. It is overflowing through the detergent dispenser drawer as well as the bottom of the front loading door. I am going to contact Maytag as they sent me a GFI circuit in March due to the potential on water leaking on the circuit board and causing a fire. Well, the GFI will prevent the fire and my question is what about the leak?
  • DanGill Oct 28, 2008
    Water flows for too long into soap dispensor drawer an then it leaks out front of machine. Worked OK for over two years. Is this a valve problem or a valve controler problem?
  • 209 Answers
Water out of the soap drawer could be a multitude of things, start with removing the drawer and checking for blockage in the pipe from the drawer to the drum, next try turning down the water pressure a little sometimes that can help, or has the machine filled up totally till it overflows, that is a blocked pressure switch pipe, start with looking for the blockage first, work with safety unplug if removing lid etc. rate me if i have helped, thank you
Posted on Sep 16, 2007
Water does not drain from dispenser into tub/drum fast enough
pull out the dispenser,check inside where the dispenser goes into,i found in two washers the white circle piece that's inside the cap to detergent,when water would go in the cap would block the fill tube,if you checked the dispenser and water flows through you have something blocking the fill tube,hopefully the washer and dryer are not stacked,you might have to take the top lid off to get at the fill tube or fill hose to clear it.good luck with your washer
Dec 25, 2014 | Washing Machines
If water get overflow from the tub what defect it will cause to the machine
it can cause a lot of rust on the metal parts of washer and could cause wires to short out
May 22, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Front load washer dispenses fabric softener drawer fills water
either the auto dispenser is sticking , take out and clean with hot water. Or flow control valve needs replacing.
Feb 24, 2014 | Bosch Washing Machines
Water overflows from the soap dispenser drawer when filling tub
Hello, the problem here is you have a blockage between the soap dispenser and the tub, remove the top of the machine, Normally 3 screws at the back lip of the machine. Now you have access to the soap dispenser. There is a pipe that runs from the dispenser to the tub, remove this pipe and inside you will most likely find a sock or similar item of clothing. Put everything back together and you are all set. Good Luck! Mike
Nov 01, 2009 | Malber WD1000 Front Load Washer/Dryer
As the washer is filling with water, it overflows out of the dispenser area. it appears that the water is not getting into the machine quick enough as the dispenser fills with water.
hi there......this problem is usually caused by a build up of detergent in the hose leading from the soa disenser into the wash tub....remove the soap dispenser....check for accumulated detergent under the drawer....and in the top of the fill hose....easy removed with a little patience and warm water....
regards Sir Galahad
Aug 16, 2009 | Washing Machines
Machine does not always accept conditioner
If it takes it down sometimes, then the way to see if it is working, is to do the following test.
Remove the dispenser drawer from the washer, and fill the compartment with clean water until it starts to overflow, turn the water off and the water in the dispenser should continue to run out until it is empty, if it does not, then it is blocked.
If this is o/k ,then the prob is elwsewhere.
PLz rate my solution.
Jan 03, 2009 | Indesit W 123 Front Load Washer
Hotpoint WD440 Drawer overflowing
I would check the inlet hose from the bottom of the soap dispenser where it goes into the drum for a soap blockage.
undesolved powder can build up here and prevent the water entering the drum
You can access this hose by removing top cover.
the hose is on the left side front.
This should solve your problem.
Please leave feed back.
Nov 25, 2008 | Hotpoint Aquarius WD640 Front Load...
Kenmore HE2 #1104751. Overflows as it is just beginning to fill with water
ck inlet just inside door upper left could be blockage in line from dispenser into tub especially if you have been using dry detergent remove detergent drawer and ck for blockage from that end too
Oct 09, 2008 | Kenmore Elite 45986 Front Load Washer
Water gushes out dispenser
Something has gotten into the fill tube hose of the tub.  You will need to pull the drawer out and look down in the dispenser assembly to see if there is something blocking the hose.
Dec 30, 2007 | LG WM-2077C Front Load Washer
Maytag Neptune MAH9700 Front Load Washer Logo
629 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
