Cannot open dvd.
Audiosonic DVD player, serial # KM 0001. When switched on, red light near DVD slot flashes continuously. Cannot open, close or use any functions at all. Please help! Thanks.
Hey i have the same problem! did you manage to fix it? if can u contact me at mesheluvz@yahoo.com. thanks
Posted on Oct 05, 2010
Unlocking my audiosonic dvd player
You maybe able to get a region free code from these WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Feb 05, 2013 | Televison & Video
Display says BLOCKED and DVD tray wont open anyone any ideas
To open the DVD tray: -
1. Remove Power
2. Invert the player, and look for the slot (about 2.5cm long) near the front of the player under the tray.
3. Shine a light into this slot to locate a white plastic lever
4. Insert a plastic blade an slide the lever to the opposite side of its travel, and the tray will start to open
5. Turn the player the right way up and continue to open the tray and remove DVD
NOTE: Depending on what caused the blockage to be reported, they player may or may not revert to normal operation. If like mine there is an underlying fault, then once power is re-applied the fault will still be reported whenever the tray is closed. In this case the motors that operate the tray are inoperative, and I've no didea why. In fact that's what made me read this website. So I hope you have more luck than me.
Regards, D.
Feb 09, 2010 | Philips DVDR70 DVD Recorder
Player won't open. how do we reset?
my dvd player is stand on the red light when i insert the dvd the dvd will hand after few seconds what is the problem please solved my problem
Jan 04, 2010 | Philips DVP642 DVD Player
Flashing red light Panasonic portable DVD-LA95
check the microswith near the hinge . its generally located on near the back right corner of the player , on the control surface. it looks like a very small white plastic button or pip. sometimes these stick down and look like part of the player casing, when they actually are a switch. it needs to be raised , so when the lid is closed it pushes the pip down and turns the screen off. Try prising it gently free with a pin or needle. this happened tome and i was on the verge of binning it. when i looked at the manual and it says power light flashing slowly means screen turned off.
if the light is flashing very quickly then im afraid its knackerred and just not worth repairing.
if this is helpful to you then just drop me a line at choonzy@googlemail.com
good luck
choonzy
Jan 03, 2009 | Panasonic DVD-LA95 Portable DVD Player
Memorex DVD player won't work
the standby light switch is your on/off switch as well......
Nov 18, 2008 | Memorex MVD2042 DVD Player
Audiosonic DVD player no sound
Try using a diferent rf cables.I would suggest that red,white and yellow colour coded RF cable is still the best.(yellow for Pictuer,White for sound and red also for sound(surround).
had similar problem than i cahnge the cables and found out that it worked with that cable...
thanx,
FIJI
Jun 21, 2008 | Televison & Video
Can't power on
try unplugging the dvd player then plug it back in as this treats it like a reset.
Mar 13, 2008 | Aspire Digital AD-8091 DVD Recorder
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Holding the Reset button for 60 seconds didnt help!!!!!!
Unlike the suggested solution to reset to factory settings by pressing the stop button on the DVD player itself with the tray OPEN, in my case I succeeded only with the tray CLOSED (no DVD inside). The light flashed to red e back to green and it was done.
Jan 09, 2008 | Cyberhome CH-DVD 300 DVD Player
Dvd player wont open
Look on the bottom of your player. Between the two front feet you should see a narrow slot that is about 1 1/2" long (it should say "emergency hole". Shine a light into the slot, you should see a black pin about as big around as a pencil lead. Carefully push this pin in the direction of the arrow. It should release the drawer and allow you to open it.
Aug 27, 2007 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
Electro Med Services...
