Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
My HP Pavillion entertainment laptop shuts down everytime I plug it in with the AC adapter, regardless whether the adpater is plugged in or not to the power outlet on the wall. Also I can hear a ticking or beeping sound when the adapter is plugged in to the power outlet.
    Novelist:
  • 184 Answers
1) The laptop shuts off when AC power adapter is plugged in.
Possible cause:
1. Power adapter failure.
2. Motherboard failure.
First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard.
2) If you can hear the buzzing noise from a few feet away and it gets very hot, that means your ac adapter is failing.
Online store of HP Pavillion AC Adapter: http://www.chargerbuy.com/laptop-ac-adapter/hp-ac-adapters.html
Posted on Nov 23, 2010
    Problem Solver:
  • 6 Answers
This you power outlet is abnormality inside..need change a new.
Posted on Jun 20, 2009
My toshiba laptop wouldn't work well when connected to power source but will function well am using the battery
Laptop shuts off when AC adapter plugged in
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
Possible troubleshooting steps and repair solution: First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
Jun 20, 2011 | Toshiba Computers & Internet
Hi, my laptop crashes when the ac adaptor is plugged in yet it will charge the battery fine when the laptop is shut down.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Resource: Acer Laptop AC Adpaters
Mar 20, 2011 | Acer Computers & Internet
When I put my adapter inside for charge my laptop turns off and the light is on saying that is charging but its doing nothing pls help. Regards
Read the article below, may it will help.
Possible cause:1. Power adapter failure.
Possible troubleshooting steps and repair solution:First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
Jan 09, 2011 | Toshiba Tecra M5-384 Laptop AC Power...
3 weeks ago My Laptop HP Pavillion Entertainment system DV9500 shut off while I was using it and now it doesn't even power on. I purchased a new power supply thinking that was the problem but still can't...
unplug the ac adapter from the laptop and remove the battery
press the power button for about 5-10 secs
while the battery is out, plug in the ac and turn on the computer if still doesnt turn on
use a known good adapter and plug it in if it still doesnt work then motherboard needs to be replaced
hope this help
Sep 07, 2010 | HP Computers & Internet
My hp pavillion was no power, please give an advise.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
To verify this, unplug your laptop & try to run it on battery only. Watch out how long it will stay on (if at all). If it didn't work on battery alone, or worked but for a very short time, then your battery is defective.
Apr 19, 2010 | HP Pavilion dv1000 Notebook
Is my AC Adapter for HP Deskjet F380 out of order?
You can contact PRASHANT 9820930880.
I found this on the net while searching for the adapter. Placed the order just now. Not sure how genuine he is
we have hp all in one adapters model f/310/325/335/340/350/370/378/380/385/388/390/394 @400RS. CONTACT : PRASHANT 9820930880
Jan 05, 2010 | HP DeskJet F380 All-In-One Printer
Pavillion dv2025nr Blank Screen, but all LEDs on.
VGA card problem..that's what tech told me & changed it 3 times...but still laptop goes off.(exactly like u described)...they finally said need new motherboard??? so VGA will not do this again!!!! I don't know, If I change motherboard...will this happen again...is it worth it??? My pavillion dv 2000 is only 1.5 years old..was expensive??/
Oct 01, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My laptop HP Pavillion ZV6000, battery started decreasing and wouldn't charge when the ac adapter was connected. I purchased another ac adapter thinking that was my problem. It didn't work. Now I have...
As others have said, the most common fault with the ZV series is the power socket. However, you mentioned the Lightning Bolt. This indicates that the battery is being charged and it should go out as soon as the battery is fully charged.
If the Lightning Bolt flashes on and off regularly, especially when the power cable is moved, then the socket is at fault and needs replacing.
You can check to see if the battery is receiving a charge by doing the following
1. Right Click the Desktop
2. Click Properties
3. Click the Screen Saver tab
4. Click the Power button
5. Click the Power Meter tab
This will tell you the computer's current power source and whether the battery is charging.
I have replaced several of these sockets on ZV5000s and I'm sure the 6000 will be similar. I would not recommend this job for anyone without technical knowledge, despite some of the websites that say you can do it yourself. You will need to strip the entire laptop down and all but remove the motherboard before the socket can be replaced.
Hope this helps
May 21, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Charging problems
Hopefully the battery is just confused and needs to be reset. Drain the battery down until the system shuts off automatically, then take the battery out of the laptop for two minutes and plug it back in, and connect the AC adapter, let it charge without turning the laptop on, then turn it on and hopefully it should work fine again. If not then you may need to buy another battery. Try again with another AC adapter just in case because you don't want to replace your battery (expensive!)
Please rate, thanks!
Mar 31, 2009 | HP Pavilion dv6000z Notebook
Doesn't start up
remove the primary battery and plug the computer into an AC outlet using the AC adapter. If the computer starts up, one of the batteries need to be replaced. If the battery light on the of the comoputer is blinking, the battery has reached a low batery level, which may not allow the computer to start up. Plug the computer into an AC outlet using the AC adapter to start the computer and allow the battery to charge.
Dec 30, 2007 | Toshiba Satellite M55-S3512 Notebook
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
383 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
