Question about Compaq Presario C700T Notebook
Display problem 8 pin ic short
Avishesh
I have a problem with my laptop bcz any one take place passward on my laptop setup
Posted on Apr 17, 2009
WHAT IS THIS PROBLEM R805 RESISTOR 33 Ohm BURNING how this solvation sharp tv?
Vertical output IC shorted. Replace it. Before replacing it, check all the associated components connected to its terminals for failure; especially for any zener diodes for short. It is most possible case. Refer its circuit digram [schematic diagram] for more details.
Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 02, 2014 | Televison & Video
I have a Nokia 6630 Second hand phone.Sometimes I have displayed 'Not Charging' when I am using my NOKIA Original Charger. but my charger is working properly.Is it a battery problem or Power IC problem
yes once check ur charger and all pins of that charger and check the phone pin at connnet of the charger if it not works u should change ur chrger or phone pins ok thinks and all the best and please
OR:
Please change Phone In The CHARGING JUMPUR
rate my answers too
Dec 28, 2010 | Nokia 6630 Cellular Phone
Hi i haave 6500c,but it show white display.i change also new lcd but same problem pls tell me about this problem.
as my knowledge its internal IC problem. Not display side issue. there is 2 small IC with 6 to 8 pin ( for power operation of LCD ) may be damaged. replace it with temperature control solder iron. It will solve your problem and this is cause to big shook or vibration.
Dec 06, 2010 | Nokia 6500 Classic Cellular Phone
Hi have samsung ml 2240 printer top light is flashing green orange and red and the bottom light is flashing red have changed the toner cartridge but printer still not working
its of Paper count problem. tourn of printer power and open the back cover and find the IC 366...... ita a small 8 pin ic just short Pin NO 1 And 4 just restart the printer ur problem has been resolaved
Jun 21, 2010 | Samsung ML-2240 Laser Printer
LC-46D43U Lcd display broke on inside. The screen is fine. Have sound no picture, just a bad spot and some lines. How can I fix this?
If the LCD Display is broke, only replacing the LCD Panel will fix it. The Main problem is that the cost of doing this would exceed the cost to replace the whole unit. I am sorry about the bad news.
Skyassoc
Nov 15, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How to reset samsung scx 4300 printer cartridge
you can not reset this chip change it you must be buy a new one cartridge
Nov 04, 2009 | Samsung SCX-4300 Monochrome Laser...
My printer massage display toner exhied
no there is no solution to short pin, it has software solution to reset printer.
We have Zero cost solution for samsung -scx-4300, ml-2240,ML
2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
The picture on my Vizio 42" flat screen suddenly shifted to a whitish pale color with ghostly looking images that look like negative film.
This is the fix for the Main board repair :
Locate IC 32 small 8 pin surface mount near top of Main Board and remove. Short pin 2 to pin 5. (pin 5 through 8 are together and pin 2 and 4 are together)
You will need a good TV Tech to do this for you.
Aug 04, 2009 | Vizio VO42L 42 in. LCD TV
Motherboard not powering up
hi this is parveen
solutiom for d845gvsr not poweringup only led flashing--
short pin 92 and 93 of smsc LPC47M172 with fine tip soldering iron .
pin 92 is nrsmrst signal that is 3.3v at time of working m/b when this signal is low than motherboard not powering up so we short pin 93 that is standby (3.3v) and motherboard powering up again and working properly this problem doesn,t come again in future. this solution is 98% working 2% chances to change the chip.
Aug 07, 2008 | Intel Motherboard
No power-up only the little green light by the cpu lights up
I tried Parveens solution for this problem on 2 absolutely dead D845GVSR mother boards and it fixed the problem for me on both. On mine you had to permanantly short pins 92 & 93 of the LPC47M172 IC near the ddr ram slots.
There must be a reason for why the motherboard went dead in the first place because from the factory, pins 92 & 93 of this IC are not meant to be shorted. Albeit the motherboards work perfectly the shorting of pins on this IC get over the problem but the original fault is still really there but has been bypassed! Still having said that, what a result!
Feb 02, 2008 | Intel Motherboard
Compaq Presario C700T Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
