Question about Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
Even vertical lines on fax/copy
Hi All When I transmit a fax or make a copy, the entire page is filled with vertical lines spaced evenly apart (4mm). The actual image is fine except for these lines. I have cleaned the glass, rollers etc, but these look system generated.
  • jojolina Sep 16, 2007
    Sorry, machine is a Samsung fx900 thermal fax
  • 31 Answers
If you know how to disassemble the unit and know where LSU(LASER SCANNING UNIT) is located. try to clean all the mirrors you can find.
clean it with alcohol and clean rugs
Posted on Mar 11, 2008
I do not what SMPS or CIS scanners mean? I "Brother" 625 fax machine and when I transmit a fax or make a copy, I have black verical line on the left 4" wide. What I have to do?
Thank you
Posted on Mar 08, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 167 Answers
TYPICALLY SF900 FAX USES A DIFFERENT CIS SCANNER , THSI SORT OF INDICATION IS EITHER SMPS BAD OR CIS SCANNER BAD. HAPPY FAXING OMNIRESENT
Posted on Sep 23, 2007
Tip
When u print if u r getting the Horizontal or vertical line then follow these...
If the print is a dismal gray rather than a sharp black, you are probably almost out of toner. This can manifest itself evenly across the entire page or in splotches or stripes, depending on the printer.
Sometimes you can wring a little bit more out of a toner cartridge by taking it out and gently shaking it from side to side (never up and down, as toner can spill out). You can also try turning up the printer’s contrast adjustment, if it has such a knob (usually on the back side if it exists). Faded print can also result from a dirty corona wire, because a dirty wire inhibits a full electrical charge from being passed.
If the printouts are consistently varied in density, and you have to frequently remove the toner cartridge and shake it to redistribute the toner inside it, make sure the printer is sitting on an even, flat surface.
Horizontal black lines
A horizontal black line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant black lines on the page and then use Table A to determine which part might be causing the problem. Table A
Distance between lines
Faulty part
0.5”
Registration assembly
1.5”
Upper registration roller
1.75”
Lower registration roller
2.0”
Toner cartridge developer roller
2.56”
Lower fusing assembly roller
3.16”
Upper fusing assembly roller
3.75”
Toner cartridge photo drum
Regularly spaced splotches
If there are evenly spaced black spots but they don’t extend all the way across the page, the problem is probably a scratch or flaw in the drum or a build-up of toner on the fusing roller. If the spots are less than three inches apart vertically, it’s probably the drum, because the drum has a larger diameter than the fusing roller.
Vertical black line on edge of page
This can indicate an almost empty or faulty toner cartridge or (less frequently) some spilled toner inside the printer.
on Aug 28, 2008 | Lexmark X5470 All-In-One InkJet Printer
Black vertical lines on transmitted faxes.
Just go to menu and then in tools...run alignment and clean them....
Jun 29, 2010 | HP 1040 Plain Paper Inkjet Fax
I have a Ricoh 2050L that is leaving vertical lines on copies by not transmitted faxes. How do I clean my fax or who can perform the needed service. What is a fair price in the market?
What you are saying cannot happen. When you send a fax or make a copy, you are using the same mechanism. Do you mean print outs instead of copies?
Open the doc feeder and clean the scanner glass.
Feb 10, 2010 | Ricoh 2050L Laser Fax
MX318 fails all fax functions
If you are using only one incoming telephone line, you need tro reset your printer at 'fax priority' position onn your printer. An MX-typr handicap.
Sep 20, 2009 | Canon PIXMA MX310 All-In-One Printer
I get a dark line in the middle of the pages
Dust in the scanner, clean the scanner line inside the refill  compartment
Mar 06, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Transmitted pages are too dark, practically unreadable :
I suspect your scanner unit is going bad or it is extremely dirty.
Making a copy gets same result as when you send.
Nov 01, 2008 | Brother FAX-8360P Plain Paper Laser
Printer Problem - Konica Minolta 7450
Horizontal lines
A horizontal line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant lines on the page and then use Table A to determine which part might be causing the problem. Table A
Faulty part
0.5”
1.5”
1.75”
2.0”
2.56”
3.16”
3.75”
Vertical line on edge of page
Sep 03, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
I have problem with a quality of fax
Make a COPY and see how the copy comes out. If you see the same black vertical lines that other people are seeing, then you probably have something like whiteout on the scan glass.
Open the fax top cover where you feed your originals, and then look inside for a piece of glass about 10" long by 1/2" wide. Then I would try cleaning the glass with rubbing alcohol and also go over it again with windex.
After cleaning the glass, try making another copy to see if it has improved. If it has, but still has more lines, then try re cleaning the glass.
Hope this helps.
Good luck.
Mac
Mar 08, 2008 | Brother FAX-575 Plain Paper Thermal
Panasonic KX-FHD331 Plain Paper Thermal transfer Fax Logo
273 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
