Low memory why dose my pc say low memory i had a windows 98 i up graded it to windows xp works great and much better but now it says i have low memory on it i do a disk clean up on it but that isnt helping so what is the next step i can take ty
  • 326 Answers
You can increase your virtual memory settings. To do this follow these steps:
Press and hold the Windows Logo Key + press "pause break" key to access System Properties, note the amount of RAM it states before continuing, you will need it for a calculation. (xxxmb)
Select Advanced Tab > Under Performance click Settings > Click Advanced Tab > Under virtual memory click Change button >
Set the Minimum and Maximum to a number 1.5 times the physical amount of RAM that you have. (Providing you have less then 512mb. 2.5x for 1gb or greater.) Hit set, Hit apply.
Before restarting, you may want to consider reducing some of the Visual Effects of XP to gain some resources back.
Manually un-check the boxes listed on the Visual Effects tab that you encountered right before setting the virtual memory.
You can also click "adjust for best performance" for an automatic trim.
This will solve your issue.
Posted on Apr 17, 2009
    President:
  • 1,901 Answers
Right click on the My Computer icon on the desktop and select "Properties". How much RAM do you have in your computer? If you have 256MB or less, it is not enough.
(Note: If you do not have a My Computer icon, go to Start>Control Panel. If in Classic View double-click "System". If in Category View, click on "Performance and Maintenance", then click on "System".)
Another way to determine the amount of RAM you have is to go to www.crucial.com and run their scan application. It will tell you how much RAM you have, how much your computer will hold and what kind it takes.
Oh, RAM stands for Random Access Memory. It's what your computer uses to run the programs. The newer the operating system, the more it takes. XP needs more than Windows 98. Vista needs more than XP. And so on.
If you need more advice comment back with the information about your computer and we can make some recommendations.
I have a emachines EL1300G-02w and need to restore my OS, can you assist?
If it has XP O/S the first thing I would do is up-grade to windows 7 or windows 8 RP. I have the same machine and I up-graded memory to 4 gig and put a 250gig HD in it and I'm running windows 8 Release preview and it works great.
Feb 18, 2011 | E-Machines eMachines Desktop PC
Compaq SR1650NX HARD DRIVE MESSED UP RECOVERY DISK WON'T WORK REPLACED HARD DRIVE CAN'T GET BIOS TO RECONIZE HARD DRIVE SHOWS UP IN BOOT BUT NOT IN MAIN HP SAID TO INSTALL NEW OS HAD OLD 98SE LOADED WORKED...
Are you trying to set up a raid configuration? If not I would reformat using the 98 disk and reinstall. (You may be able to skip installing 98, try installing xp first and it should ask for the disk containing the software (win98) that qualifies for the upgrade.
Jul 11, 2010 | HP Compaq Presario SR1650NX...
My laptops slow need to make it better
Hello
Installing windows xp, will only slow down your computer, as windows xp use much more resources than 98.
Also, we are not allowed to provide customers with piracy links.
Regards
Andrea
May 25, 2010 | ASUS L 8400B Notebook
I have an older computer and it takes windows 98, what i need to know is how to down load the 98 boot disk onto a cd that is in the lap top it has no floopy disk, my computer has been up graded with...
www.bootdisk.com try that, but if you had xp on it then get into the bios or press f.1.2 at post & switch it to "boot from cd"(make sure your xp disk is in). It should re-boot & ask to press any key to boot from cd. Continue from there. Trying to put '98 on without a floppy drive can be tricky to say the least. You'll need to find a way to load the windows dos based cd driver, from a cd just to get to the next step of the install. Avoid using 98 unless you really,really need it.
May 13, 2010 | Dell OptiPlex GX150 PC Desktop
Need to upgrade from windows 98 to windows xp on ibm 760e thinkpad
Before you begin, be sure to go to Lenova Website and download the appropriate XP software & drivers and burn them to a CD or flash drive. You will need them after the install is completed. After that is completed, you are ready to install. Insert the XP Install disk and choose INSTALL XP and on the next screens drop down menu, choose UPGRADE. Follow the instructions. After it is completed, use the CD or Flash Drive to install the proper system software & drivers.. GREAT LUCK!! Please rate me, k? Thank You Lucky4lynn2
Mar 06, 2010 | IBM ThinkPad 760E (9546U4A) PC Notebook
Supposed to have 20 GB of memory, only have 1.99GB
Use windows 98 to make a rescue disk (3 1/2 floppy)
use that emergency disk to repartition and format the hard drive. You can probley use fat16.
Mar 11, 2009 | Compaq Presario 5000 PC Desktop
I have a gateway lb3 500 ancient 98se i tried to load xp pro and it crashed i cant seem to even get a 98 startup disk to work to recover it . how can i recover it to load the xp pro onit
Try running linux on it. Linux will run much better on older hardware. Depending an the specs of the system, it may not be able to handle running windows. Try ubuntu (www.ubuntu.com). If it used to run Windows XP or 98 and it wont now, try checking the hard drive. It may be corrupt. You can find hard drive check tools all across the web, google for drive fitness test by hitachi, it works great. Burn to a disk and boot to it on the older machine and do a full advanced test on the drive.
Dec 07, 2008 | Computers & Internet
Is tere a way to upgrade an older computer from Acer Windows 98 to Windows XP with speed and more memory?
You can up grade from 98 to xp. As far as more speed & memory that comes from a few more components than just upgrading memory. It matters on the limits of what you already have. A larger hard drive & more memory definitly boost things up but your cpu's limits will determine the actual hardware/software upgrades your system can benifit from. You'll have to get the specs on maximums for your model. If you can tell us what you have now it would help to determine a better answer than guessing.
Aug 21, 2008 | Computers & Internet
Had our computer up graded and now our ergonomic mouse will not work with Windows XP. The setup disk is for Windows 95/98/ME/Nt 4.0/2000 How can we adapt this to our computer or do we need to purchase a...
Your best bet before buying a new mouse is to go to the manufacturer's web site of the present mouse and in the Support area see if they have drivers updated for XP.
Jul 23, 2008 | Computers & Internet
Mistake install
Hey, you can probably buy a windows 98se copy from ebay
or with some luck from a local pc shop / repair shop.
Microsoft stoped supporting windows 98 many years ago, and its no longer in production. So my guess is no.
Your best shot is to get it used.
Mar 17, 2008 | Microsoft Windows 98 for PC
Open Questions:
can you please help ms drunel broussard who just received custody of 2 of her abused grandchildren in nov 2017 have a great xmas not having a home with furnishings..she no longer have stable housing ms drunels daughter and boyfriend had been abusing her children..shes a great person with such agood heart and shes struggling to keep the kids..while in moms care the kids was sleeping on the ..have very min clothing..ms drunel took her car notes monies to get the kids basic clothing and hygiene needs..shes help so many7 ppl and always been an strong person..not knowing where they would lay their heads at..i watch her go and visit ,pray for ppl in the hospital..when you ask herhow is things going shell say all will be well..but today i seen her breakdown and crying..letting the kids know she might have to let them go to foster care because she cant provide them with a stable place..to know her is to truly love her..and to see her not be able to care for them the way she cared for hewr children and other ppl children is taking a toll on her.but she keeps smiling..she really need help and an agency in jax fl where she lives told her to give them up or go to a shelter...she replied ok ..and left..doors is not opening and due to the NATURE OF THE abuse..and physical abuse these babies been through she said no..they have nothing i mean nothing for xmas...less alone shes facing losing her means of transportation to get them to and from school...counseling ...and dr.appt...PLEASE PLEASE I BEG OF YOU HELP THIS FAMILY...THANK YOU FOR YOUR TIME
Dec 14, 2017 | The Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
