hobart lx18 no power to detergent pump, during the wash cycle there is no power present at the...
(More)
hobart lx18 no power to detergent pump, during the wash cycle there is no power present at the connections for the pump, during the rinse cycle the sanitizer terminal will pulse power and the rinse aid and sanitizer pumps will run, is the relay board bad? With the top drawer open and running the led for detergent never lights up during the wash cycle.
I think my machine may be programmed for the 6% hypo-chlorite sanatizing solution and my supplier...
(More)
I think my machine may be programmed for the 6% hypo-chlorite sanatizing solution and my supplier has only the 8.4% solution which would account for the stronger % of sanatizer for each cycle. How can I change the programming on the washer to reflect the 8.4% solution being used???
Hobart 24 in. LXIC fails sanitizer tests. The sanitizer pump is pumping out about 4-5 ml per rinse...
(More)
Hobart 24 in. LXIC fails sanitizer tests. The sanitizer pump is pumping out about 4-5 ml per rinse when I remove the tube at the 90 degree tube fitting. According to specs it should be about 3 ml of 8.5% solution so it seems to be providing more than enough yet the test strips show nothing.
