Question about HP LaserJet M1005 All-In-One Printer
Scanner Error 12
MY PRINTER (HP LASERJET M1005 MFP) SCANNER ERROR 12 DISPLAY IN A SCREEN I CAN NOT SOLVE THIS PROBLEM NO SCANNING , NO PHOTO COPY IN MY PRINTER PLEASE HELP ME HOW TO SOLVE THIS PROBLEM
  • 3 more comments
  • Anonymous Mar 18, 2014
    hp laserjet m1005 mfp scanner error cannot communicate
  • Anonymous Mar 31, 2014
    IN HP 2320NF MFP LASERJET PRINTER. ERROR IS MISPRINT AND PRINTER GOES TO CLEANING FOR EVERY 2 PAGES
  • mehul malivad
    mehul malivad Jun 03, 2014
  • Dinesh Chand Gupta
    Dinesh Chand Gupta Sep 15, 2014
    HELF ME
  • 495 Answers
SCAN ERROR 12, IT'S A MECHANIC PROBLEM. YOU MUST CONTACT A TECNICIAN.
Posted on Apr 17, 2009
Posted on Nov 21, 2011
    Habit-Forming:
    New Friend:
  • 54 Answers
First of all update your firmware. again it shows scanner error 12. you must contact hp.
Posted on Nov 28, 2013
    New Friend:
Update firmware
Posted on May 09, 2014
    New Friend:
Try watching this video for the answer.
https://youtu.be/g2iroE0nEBU
Posted on Aug 17, 2015
    New Friend:
In order to resolve this issue, please follow the steps showing in this video:
https://www.youtube.com/watch?v=Gzd-u5Bzi44
After performaning it your scanner will start working but it might give half page with large scanning.
So to fix that follow below steps:
-Power on printer,
-Click on Ok button on printer control panel.
-Press and hold the left arrow key and OK button on printer.
-Release both keys at same time.
-choose the option "Scan top" service.
-Restart the printer.
It should be working now.
Posted on Apr 13, 2015
  • Meren Daniel
    Meren Daniel Aug 17, 2015
    You may alternately try this because slamming and hitting will not always result in solving the problem (though it maybe for Television, but not for Printers or scanners)
    New Friend:
Posted on Mar 10, 2015
2 Suggested Answers
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Posted on Apr 19, 2010
Scanner 12 error
HP LaserJet M1005 mfp is not work properly. printer show scanner error 12 ple. solution
Nov 08, 2012 | HP LaserJet M1005 All-In-One Printer
do a reset on the printer. if you have a cancel and right arrow button on the printer
1. disconnect the power while the printer is on
2. press and hold the cancel and right arrow
3. while holding the buttons insert the power cable
4. release it after 30 seconds
it will reset the printer ...
after that if y0u still face the issue the printer has gone bad .. time for new printer
Jun 30, 2012 | HP LaserJet M1005 All-In-One Printer
Scan head mechanism failed. Remove flat bed glass, take out scan head unit, verify any breakage in mechanism gear pinion,if found replace gear mechanism, if no breakage found replace scan head driving motor. You can see the scan head mechanism as snap shot..followed by how to alter the pinion..
For tech guys:How to alter the pinion.
1_4_2012_7_55_18_pm.jpg1_4_2012_7_55_47_pm.jpg1_4_2012_7_56_11_pm.jpg1_4_2012_7_56_49_pm.jpg1_4_2012_7_57_28_pm.jpgFollow the snapshots, be patience & do it. This is available part if anything goes wrong don't worry.. Best of luck....
Jan 04, 2012 | HP LaserJet M1005 Printer
Scanner error 12 on hp laserjet m1005
When the lid or door of an HP Laser Jet printer isn't properly closed, the printer's display will read "Error 12." You can usually correct an "Error 12" by closing the printer's door securely -- a process which may require that you first fix the orientation of a toner cartridge so that the door can close. In some instances, an "Error 12" appears due to some other issue, such as a missing toner cartridge or a defective paper-feeding component.
Apr 22, 2011 | HP LaserJet M1005 All-In-One Printer
If you get ERROR 12 DISPLAY, check top cover and toner cartridge is seated correctly, dc power supply . If these are proper your printer will be fine.
Thank you
Jan 04, 2011 | HP LaserJet M1005 All-In-One Printer
Scanner error 12
uninstall the software of scanner and reinstall it
check your cables for loose contacts
Jul 04, 2009 | HP LaserJet M1005 Printer
SCANNER ERROR 12
Mar 19, 2009 | HP LaserJet M1005 All-In-One Printer
HP LaserJet M1005 All-In-One Printer Logo
13,059 people viewed this question
Clive
Clive
