Question about HP Compaq Evo n610c Notebook
Startup I bought a notebook at a sale brought it home turned it on the compaq screen came up said to click F1 i did then another message came up said to click F10 there was an update ready so I did and the sceen went blank now it will not come back on at the top of the key board there is a number 1 the letter A and a down arrow all with a little light above them which are all lit up but nothing else what do I do to make the notebook work
    President:
  • 2,961 Answers
I think maybe somebody has tried to update the bios and failed to do so more than likely rendering the laptop useless, you can try locating the cmos battery, remove it and replace and try again, but i don't hold much hope, sorry!
Posted on Sep 16, 2007
SOURCE:
How do I access bios on Compaq 8620s
Compaqs use different keys to access BIOS; try F2, F1, F10.or DEL. At the pause on startup there are usually instructions at the bottom of the screen telling which key to press for access to BIOS.
Dec 25, 2013 | Compaq Business Notebook 8620s Laptop...
My compaq presario v5000 a 5240NR was working fine
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness
Oct 01, 2009 | HP Compaq Presario V5000T Notebook
Trying to reformat my PC but can't get into BIOS set up.
Hey,
Seems the screen is slow to start up, right after pressing the power button, keep tapping on f1 or f10 untill the bios screen or something else comes up. that will definitely get you into the bios and dont mind if the computer starts to beep, slow down a little and keep tapping.
Thanks,
Ekse
Aug 30, 2008 | Computers & Internet
Compaq armada 1700 only starts on safe mode
If this is your notebook - Compaq Armada 1700 (316320-056) PC Notebook. The system memory only came with 32MB's of memory. Your not telling me enough. Have you recently upgraded your operating system? If I have this wrong please post which Compaq you have from the list I'm providing from this link:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=96221&taskId=135
If you are trying to run a XP version your memory will need to be increased to at least 512MB. You still have the Compaq's splash screen loading when you turn on your notebook which blocks you from seeing the amount of memory installed in your notebook. So when you start your notebook press the F12 key on your keyboard. You need to enter the bios. If F12 does not get you there than try F10 or F1 key. At startup. Repeat hitting the key every two seconds till the Bios screen loads. Look for the amount of memory installed. At the bottom of the bios screen is instructions on how to navagate while in the bios. You'll need to post back with what you found If I'm to help further.
Feb 07, 2008 | Compaq Armada 1700 Notebook
Compaq Presario V2000 boot up problem
i have the same problem with mine, the compaq2_bing.gif screen shows and beeps twice and then it says press f1 or f10 but it doesnt respond to anything i press
Nov 24, 2007 | HP Compaq Presario V2000 Notebook
Press (F1) to resume, (F10) to setup
I need a bit more info to try to give you an accurate solution
Does the screen change after you press "F1" ?
Do you have access to an external keyboard, if so try plugging that in while the computer is off and then using that to press "F1"
Nov 15, 2007 | Compaq Presario M2000 Notebook
"Not support" message when computer hooked up
you may have to mess around with the screen resolutions on the compaq, as your notebook may have a lower screen resolution that your TV can handle, but your Compaq may be above the resolution support of your tv.
Aug 24, 2007 | Akai LCT2721AD 27 in. LCD Television
HP Compaq Evo n610c Notebook Logo
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
