Question about Timex T42351 watch
How can I use this and reset it ???
How can reset this watch????
  • BuzWeston May 11, 2010
    What happens when you try to set the watch? Do you know that the crown can be pulled out two notches? The first notch only operates the hour hand. This is for easy changes if you are going from one time zone to another. Pull it out two notches and you should be able to set the watch normally.
    Other features can be reset. Let me know if you need help.
    Problem Solver:
  • 18 Answers
There should be a reset button on the watch have a good look closer but u will have to have something to reset it with you cant use your fingers
Posted on Mar 05, 2010
I know the watch was working until I tried to reset it,I would like to know the correct way to reset the watch,I don't think the watch has a mechanical fault.I have never had instructions.
You will need to provide more information - i.e. make and model of watch, and what steps you took when you tried to reset it.
Nov 08, 2016 | The Watches
Watch is frozen, will not reset or change modes
you will need to press the reset or a/c button located usually near the battery well with a pin and a magnifying glass
May 06, 2014 | Mio 0021usblk2 Drive Petite Hrm Black...
Polar AXN300 Heart Rate Monitor Watch HRM AXN300 is not showing pulse
I would think it is the sensor circuit in the watch. When you replaced the battery did you activate the processor all reset for the watch? I do not know on your model where or how this would be activated.
Electronic watches normally have a reset procedure for when the battery is changed. Very important the watch's processor reset is performed after changing the battery. This is not any of the user readings reset. This is a reset for the watch's processor and system. It is sometimes a contact that has to be shorted out with the jeweler's screwdriver, or it is a contact that has to be shunted, or etc., depending on the model. Maybe if you call the support for the watch they will tell you this. Normally they do not like the user opening the watch.
Feb 10, 2018 | Polar AXN300 Heart Rate Monitor Watch HRM...
I have a 3054. About 3 days ago it reset to 1-1-2005 and has never changed. it now reads 1-3-2005 at 5:57 PM
This same problem (watch resetting to 1/1/205) has happened to me 2x now, about 2 months or so apart.
I have had this watch for ~10+ years now, and works perfectly.
I have replaced the battery 2x.
Again, the watch works great.
I just realized that in the .pdf manual, there is no indication for a "low-battery" condition.
I am guessing that the "low-battery" is what is causing the watch to reset the date/time to 1/1/2005.
Any others having this same problem if this watch resetting to 1/1/2005 after the watch has run just great (auto time syncing, etc.)?
This watch Keeps great time!
Buster Brown
Jul 25, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Cant set digital time and date and alarm, downloaded manual but does not work
There is a reset procedure for most LCD watches to reset the LCD after installing the battery. It is different for every watch brand and movement (inner works). I recommend visiting your local Certified Master Horologist for proper battery and resetting procedure.
Improperly resetting any digital watch by shorting the wrong connection can essentially short out the movement, and the movement / watch must then be replaced, whichever is least expensive.
Feb 23, 2011 | Watches
Seiko watch stop watch needs resetting
You can download an instruction manual for your watch here. It will detail how to reset the hands. :)
Tom
Nov 10, 2009 | Seiko Men's Stainless Steel Chronograph
Howe do I reset the stop watch. It will not reset
I went to the lorus web site which has user manuals for all their watches. Went through the relivent manual whcih gave details on how to reset the stop watch facility.
Nov 06, 2009 | Seiko Lorus LO111 Watch
Guess Watch's stop watch is broken?
it's not broken.
let's call the top stopwatch button "a" and the bottom stopwatch button "b." eg, for normal stop watch function press "a" to start timing, press "a" to stop timing, and press "b" to reset.
to reset: press button "a" and "b" simultaneously and release (an easy way to do this is press and hold down "b" then press "a" and release both). this will send both hands spinning. next press "a" intermittently until the second-hand is back to it's desired reset location. then, likewise, press "b" intermittently until the minute hand is zeroed. now with both hands at the correct reset location, again press and release "a" and "b" simultaneously to save these resets and return the watch to normal function mode.
Aug 05, 2009 | Watches
Techno Marine MO4 Watch, Seconds hand doesn't reset to top cente
You do not need to return the watch. It has self adjusting features (operated by the owner). Pull out crown to the first click, then push and hold the pushbutton at 2 o'clock to adjust the hand. When done - push crown back in.
If it doesn't work, pull out crown to the second click and do as described above.
Rate me, please.
Mar 22, 2009 | TechnoMarine Ceramique Watch TCB02C
My diesel watch gets reset everyday dz-7044110703
I have the exact same problem. The watch was working fine up until I had the battery replaced. I went to another watch repair shop (couldn't go to the same one as I had moved to another town) and the chap there explained that with Diesel watches, when the batteries are replaced a small button inside the mechanism must be pressed to reset the settings, if this isn't done then the annoying problem, inflicting our watches, will occur.
My watch worked fine after, for a few days, then it began to reset again; casting doubt on the watch repair man's explanation. I'll go back to see the chap when I have the time, prob next week and keep you chaps posted on anything new.
Feb 22, 2009 | Diesel DZ7044 Watch
Timex T42351 watch Logo
774 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
