Question about Sony Televison & Video
There are no problem with the TV set,we bought the set second hand and didn't receive the manual,we were wondering how we could programe the set to give only 5 stations shown on the set, not the blank screens? Would you be able to tell us how to do this.Many thanks, Rod
  • 56 Answers
Do you have the remote ? What model is the TV ? Usually you can use the remote to add/delete stations. There should be an add/delete button(s) on the remote.
Posted on Apr 18, 2009
  • Jambam Apr 19, 2009
    I will need to know the exact make and model of the tv in order to help you.
I have bought a Ocean Upright Freezer second hand and it came without a user manual, just wondering what is the best setting for it?
See if you can download a manual for it and get the recommended setting. Or just experiment with the knob and wait for a day to take the temp and adjust it accordingly.
Jun 19, 2017 | Freezers
Every 2 days I receive a short message on screen?
As I said a message pops up maybe 24 -48 hrs, but when I go through the guide set up it goes off? Thank you
Jan 21, 2013 | GE Televison & Video
My friend bought this camera ( LUMIX DMC/ZSI) 2nd hand and it didn't come with any instructions, was wondering if you could tell me where I could pick one up from or download ...
You can download the manual from the manufacturer's web site at
http://service.us.panasonic.com/OPERMANPDF/DMCZS1.PDF
Jun 19, 2011 | Cameras
Goodmorning, bought a zenith tv didn't get the remote. Wonndering how i can programme it using just the buttons on the tv. How do i get the menus up. it only catches threes channels as of now.
Hello
There are two types Zenith TVs. One type will have "Menu" button on its front panel and other will not. If your Zenith is the first type, you can programme it without a remote control. If it is the second type, you must have a remote control hanset to programme it.
Programming method
First connect the TVs antenna socket at its back with external antenna or cable.
* With the remote control in hand, press the POWER key to
turn on the Presentation TV.
** Press MENU repeatedly until the Setup menu appears.
*** Using the Up/Down arrow on the remote control, highlight
Auto Program on the screen
**** Press the Right or Left arrow to go to the Auto Program
menu.
***** Using the Up/Down arrow, choose either Cable TV or Off-
Air Antenna on the screen.
****** Press the Right or Left arrow to begin the Channel Search.
******* Press ENTER when the channel search is done.
Note: Auto Program finds channels being received by the TV
tuner
Cable will not work unless you subscribe to a cable service
OK.
Jun 17, 2011 | Zenith H27E35DT 27" TV
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I bought a toshiba 36HF12 36" tv
The TV does need a converter box to receive digital off-the-air broadcasts. It's an HD set, but that doesn't mean digital; no digital tuner was built in. You can find the manual here at Toshiba. Hope this helps, and thanks for using Fixya!
Feb 18, 2010 | Toshiba 36HF12 TV
Trying to program my dvd player with my lg tv remote
Turn on dvd player by hand using your lg tv control push set up dvd plus code.pointing for 15 seconds.
Nov 19, 2008 | LG 32LC7D Television
Just bought a second hand Archos 700tv. Everything works fine, except that I can't get any reception on the tv at all. used both the supplied aerial and home mainone, still reads red in the signal strength...
Hi Dorr
Did you buy your Archos from someone living in a different part of the country? If so, it is quite likely that you will have to retune your receiver to the local channels which may be on different frequencies in your area.
The Archos should have a scan function to look for active channels. I'm not sure how to access this but take a look in the manual, it should be an easy task.
The saved list you refer to, just shows the tags and does not mean that the signals is actually being received.
Hope this helps.............
Mar 22, 2008 | Televison & Video
Set up an a Panasonic TZ-20L3Z
Press MENU button, select PRESET and then , select MANUAL PROGRAM and SEARCH, when search completed the program stops. Give the channel and store.
Aug 19, 2007 | Toshiba 27A34 27" TV
Televison & Video Logo
57 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
