Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
Ford 3000 tractor selectomatic transmission 1965-1975- ish
Transmission will not go forward or in reverse- had it going in all gears but no power in 4th and up, weak reverse. Now I have no gears going at all- got it jumping in 9th gear, but nothing else. How do these bands need to be adjusted? Adjustments made according to the manuel have everything frozen. Advise PLEASE!
  • nathan May 11, 2010
    you have posted in wrong section
2 Suggested Answers
craig6773
  • 116 Answers
SOURCE: have a 4490 case wont go into gear but can start
Sounds like the linkage needs adjusment.
Posted on Dec 02, 2010
Ford crown victoria 99 won't go forward goes in reverse
You have a 4r70w transmission and more than likely a forward drum failure has occurred, seeing as reverse still works fine and no forward engagement. This is not an electrical problem, it is a hard part failure and the transmission will need to be disassembled to repair it. Forward drum failures are one of the more common failures in these transmissions. 4r70w no forward gears only reverse help needed Ford Truck Enthusiasts...
Dec 01, 2015 | 1999 Ford Crown Victoria
How can I adjust the transmission linkage on a Husqvarna riding mower model LTH145 product # 954-14-00-06?
The Hydro-Gear transmission in this model tractor does not have an adjustment capability. You can either bend or straighten the actuating rod to adjust it in small amounts. However, with no reverse or forward the transmission may be bad. Check the v-belt first. Replace the v-belt if loose or worn. Otherwise you are probably needing a transmission.
May 06, 2015 | Husqvarna Garden
2002 ford explorer will drive forward but wont move in reverse...what could be the cause?
bad transmission. if it shifts through gears going forward but will not do anything in reverse it is most likely a bad transmission. reverse is usually the first gear that goes out .
Dec 07, 2014 | 2002 Ford Explorer
Wont move when backing up
Hi. It would be best to know the manufactures model of your tractor or the transmission model number to best help. Typically issues with riding mower transmissions is in the shift keys inside the transmission. I would also ask if the transmission gear is moving far enough to actually put the transmission in reverse. Be sure nothing is binding or that the shift arm is not bent. That is the first thing to try. With more information I may be of more assistance.
Nov 28, 2013 | Craftsman Garden
ALLISON TRANS FAULT CODE D12312 WHAT IS IT
I tried the DIY service and repair manuals from
a website and it actually helped me repair transmission problem in my ford explorer. it wont move forward or reverse, engine is good both solenoids for forward and reverse work.
I don't have much technical knowledge but I just followed it step-wise, and works perfect! got it from www.reliable-store.com
Mar 18, 2013 | Cars & Trucks
My 1993 ford tempo 2.3L wants to slip in reverse but changed trans fluid and was very clean and works fine in all forward gears. Is trans going out or could it be an adjustment?
be careful when changing gears into reverse and be careful while in reverse and your transmission should last but if you ride on that gear to much your transmission will fail and you will no longer have reverse in your vehicle even if you have all other gears working
Apr 26, 2011 | 1993 Ford Tempo
My Ford YT-18H model tractor will not accelerate when either in forward or reverse gears. It moves slowly but not with enough power to climb even a snall incline. Could it be a transmission problem, or a...
I need a belt diagram for a Ford Riding mower, Model YT 18H. A diagram for the tractor belts would be greatly appreciated.
bilp07@yahoo.com
Oct 20, 2009 | Ford Garden
1999 F250 only goes in reverse, no forward gears.
I believe that reverse is operated by a brake band. So it seems to be stuck. It is operated by a piston, and the seal could have swelled and caused too much friction. But you could loosen up the adjustor so that it is disengaged, in order to get forward gears again. Perhaps you can force the piston to retract as well, once you drop the pan again.
Jun 26, 2009 | Ford F-250 Cars & Trucks
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Open Questions:
See all RTO Ford Tractor 2000 3000 4000 5000 Water Pump Questions
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
1,219 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
