Question about Bunn CWTF 15-APS Coffee Maker
Bunn CWTF15-APS Unable to hold 195 at the brew head
  1. Unit is in the pour over mode and the external water supply lines are not connected.
  2. The thermostat is set to the maximum.
  3. Water heats up to 205 degrees and the green ready light comes on
  4. I add 1 quart of water and brew head holds 195 degrees
  5. Wait for the water to heat up and green ready light comes on
  6. I add 2 quarts of water and the brew head drops from 195 to 180 degrees half way through the cycle.
  7. When the 2 quarts finish running through the machine it takes 7 minutes for the machine to go to a green ready light state.
Comments:
a. I have an accurate gauge to measure temperature.
b.It seems to me that this 1300 watt element is never going to be able to hold 1/2 gallon of water at the brew head to 195. There is one gallon of hot water in the reservoir at the start of the cycle and adding one half gallon of cool water to the reservoir seems to be too large of a load for the 1300 watt element to keep the reservoir up to 200 degrees. It seems like I have to add hot water to this machine to produce 195 at the brew head.
c. Can I throttle the water going down into the reservoir from the pour in pan? Would this mess up the flow at the brew head and the coffee quality?
d. Would using the plumbed in water line help me hold the water temperature at the brew head. The thought that the plumbed in water line will throttle back the incoming water.
e.. I need to brew 2-3 gallons of good coffee on Sunday mornings. My motto is: We are having good coffee at church from now on. Well I will as soon as you guys fix my coffee machine.
f. Would a new heating element make a significant difference? Could I go to the next larger element the 20 amp one?
    President:
  • 1,618 Answers
Yes it is possible to go the the next larger element.
Yes if the machine was plumbed there would be a difference in the way it brewed the water temp. if you look at the end hose in the pan from the solenoid, it takes a while for it to pour out 3liters.
Try using a different sprayhead(if yo;u are using a 6 hole try getting a 5 hole. That will constrain the flow of water a little more allowing the element more time the heat the water.
Posted on May 16, 2009
  • Bunn Master
  • 2,237 Answers
The tank on the inside holds 5 quarts of water that heats up to 205. when you pour water in the machine, it fills into the bottom of the tank pushing hot water out the top and through the sprayhead. the more water you put in, the colder the tank gets until it has time to heat up again. if you wand it to heat faster, get a cwtf35. it takes 220vac, but it has 2 elements
Posted on Sep 13, 2014
  • 131 Answers
SOURCE: Bunn CWTF15 Airpot brewer
If the unit does this constantly, it's probably seeping past the solenoid valve. you can try taking it off and check for dirt or corrosion that is stopping it from closing properly, or replace it. the solenoid valve is located under the front panel, and is silver in colour with 2 wires & 2 copper tubes coming to it. as always, please be sure there is no power coming to the unit before servicing!!
Posted on Feb 12, 2009
kaldiDOTcom
  • 22 Answers
SOURCE: can you turn a CWTF15-APS Airpot Coffee Brewer to a pour thru
Yes, most Bunn CW models have the ablilty to be used as a pour over. There should be a lid on top.
www.kaldi.com
Posted on Jul 21, 2009
  • 189 Answers
SOURCE: resevoir tank not filling
If you will get the model and date code located on the bottom of the unit and contact customer service, we will be able to help troubleshoot and resolve your issue.
Posted on May 19, 2010
ErusTownsend
  • 592 Answers
SOURCE: dry coffee is left in funnel after brewing.
After use many coffee makers and hot water drink machines will gather mineral deposits. This is very common and the typical maintenece is to run a few cups of white vinegar through the unit a couple of times. This will loose and clean the unit. After this you run water through it a few times to remove the vinegar left behind.
You can also buy professional cleaning/descaling solution like this http://www.buy.com/prod/urnex-14-cl12-3-13-cleancaf-coffee-machine-cleaner-and-descaler-3-pack/q/sellerid/16616284/loc/66357/211223757.html
Posted on Jan 21, 2011
EsWorld
  • 1618 Answers
SOURCE: I have a used Bunn
I would remove the front panel and check the pressure stat to make sure it is set high, turn knob all the way to the right the back it up 1/4 of a turn. It that is done and after 7 minutes water is not hotter then the problem is on the top, the hi-limit needs to be replaced.
Posted on Aug 26, 2011
My bunn cwtf15 won't put out hot water from tap, and won't brew hot enough water even after adjusting thermostat?
your thermal fuse has blown. it's in what is now brown tubing and is located in the top right rear of the machine. remove the top lid, remove the trough drain nut and trough to get to it. you can either bypass it with a jumper, or call (800) 352-BUNN (2866)
Jan 06, 2014 | Bunn CWTF15-TC
Programing for best cup
when feeling upper crusty, I like the pre-soak method, using my good old bunn machine a small blast of 195 degree water to steep for 45 seconds to a minute, followed by the remaining 195 degree water to brew my desired quantity. but I seldom wish to muck about when I want some coffee, so use my good old bunn old school brewer the way it was originally designed,... add grounds, pour water, enjoy coffee!
Feb 13, 2013 | Bunn ICB-DV Coffee Maker
No hot water pouring water into top not plumbed is that an issue? bunnctfw15-ts
If it is not connected to water then it has to be used as a pourover brewer by pouring water into the top for brewing, there will be no water from the faucet.
Apr 19, 2011 | Bunn CWTF15-TS 23000.0006
I have cwtf15-aps older model. Device is wired and plummbed in. lights are working but i get no hot water. Has not been used for about 3 years.
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Dec 12, 2010 | Bunn CWTF15-TC
How do you perform a descaling to a Bunn CWTF15 3LWR
The CWT 15-3 has a water tank that can be filled by a water line attached to the machine or by removing the thumb screw on top of the machine near the front. The screw holds a small cover about 2 by 6 inches that lifts off. You can use this to pour water in if you don't have a waterline hookup. This is the tank opening into which you will pout a quart of vinegar to descale the machine. Also this machine has a long thin spring with it from the factory. If you remove the brew funnel, then unscrew the sprayhead above the brew funnel, you can descale the tube that carries hot water from the tank to the brew funnel. Just snake the spring into the tube where you unscrewed the spray head, and slide it in and out until you no longer see scale on the spring. When you pour a quart of vinegar into the machine let it sit for 20 to 30 minutes and then flush with 3 or 4 carafes of water. This should remove the scale from the tank. In areas with hard water and high usage of the machine, one cycle of vinager may not be sufficient to totally remove all the scale. Repeat as necessary until the water is clear.
Sep 14, 2010 | Bunn CWT 15-3 (3 Lower Warmers) Coffee...
Can you turn a CWTF15-APS Airpot Coffee Brewer to a pour thru
www.kaldi.com
Jul 20, 2009 | Coffee Makers & Espresso Machines
If I can't get the water t6o come out when the
Try this, use the manual fill in the top of the machine, remove the sprayhead, put an airpot under machine and pour water into the machine at least 3 liters, until it pours out of brew tube. If that works, then the problem lies in the solenoid or the ling bringing water to the machine.
Jun 18, 2009 | Bunn CWTF15-TC
No coffee.....but hot water spiggot is OK.
yes there is clogged inside its either the hose or the keypad / connection of the control is corroded.
Mar 09, 2009 | Bunn CWTF15-TC
Bunn CWTF 15-APS Coffee Maker Logo
342 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
