Question about RCA HD52W56 52" Rear Projection HDTV
My convergence won't stay in line. it keeps going in and out.
  • 112 Answers
Does the tv do this even when you are watching the tv?
Posted on Dec 20, 2007
SOURCE:
Mitsubishi big screen rear projection tv the blue
The tv 100% have convergence problems,it dead.If any colors lines don't matches or stay in the - + convergence grid.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv conververgence board must have these parts changes to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 11, 2010 | Mitsubishi Televison & Video
When i try to adjust the convergence, the red and blue adjust ok, i assume the green in the basline color, but it turns up on the right side of the screen and the picture has a green wave in the lower left...
The tv 100% have convergence problems,it dead,if have any colors lines mis alignment or don't stay in the convergence - + grid.The tv convergence board is dead.The 2 STK convergence ICS and some or all is resitors are dead.Must replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 11, 2010 | Panasonic PT-47WX49 47" Rear Projection...
My Mitsubishi HD1080 series screen is coming inward from the top & bottom.. and occasionally red & green lines or black lines will flash through it... It started out just being inwards once in a...
You have either bad convergence ICs or just bad grounds on the IC. I would go ahead and replace the ICs and check those small ohm resistors, as you have to pull the signal board out anyway. For futher instructions see the website www.TvRepairKits.com. They may have what you are looking for. Be sure you have the TV model number next to you. Thanks for asking and show a few hands of support!
Nov 07, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Hi, My Samsung tv had the bad coloring issues described of as convergence/IC issues. Now it just has a red slanted line going across the top of the tv. In the self focus menu I get an error that says...
You can just replace the convergence board which for your model is part # BP95-00415C They are under $100 dollars and are just a plug in board. You should be able to purchase from
www.partstore.com
Aug 28, 2010 | Samsung HC-P4363W 43 in. TV/DVD Combo
Won't stay in focus? keeps getting red out of focus.b
Tv have a problems known as a convergence problems,it dead.Any colors lines R,G,B mis alignment.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved the covergence problems.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.The Samsung/Akai tvs used the same convergence board.Or the shop will cost u $300-350 for parts and labors.
Aug 19, 2010 | Samsung Televison & Video
Convergance problem
Hi, I`m assuming your going into the menu and trying to adjust convergence and the lines won`t align? If so the convergence IC`s have failed and that circuit will need to be checked to see which parts have failed and then replace them, probably time to call in a tv tech for that one, video-tek
Jun 09, 2009 | Samsung HCN436W 43" Rear Projection...
Intermittently screen move to one side with distrited picture
Might be the convergence chips. Do you have any problem moving the convergence under the menu setting? Convergence chips are reasonably priced. If you know a friend or someone who can solder better than average, I would go this route. My tv wasn't that bad; I wasn't able to set 2 of the 3 colors during convergence setup. Changing the 2 convergence chips did the trick!
May 24, 2009 | Philips 43PP9202 43" Rear Projection...
Magnavox convergence arch bottom of tv
you have a problem on your convergence driver board,either a leaky capacitor, resistor increased in value or a STK ic going bad
Mar 21, 2009 | Panasonic PT-51HX42 51" Rear Projection...
52' take about 15 min. to come then only stay on for about 1hr
The convergence ICs overheat , you get bad picture and then the TV detects the fault and go in protection mode, that is the standby state.
That means that the convergence ICs are bad and must be replaced, the job is about $200/$300.
Here there is an example of the repair needed: Fixing Convergence problems in RPTV's
Mar 09, 2009 | RCA HD52W59 HDTV Projection Television
Convergence
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Nov 26, 2007 | Hitachi 60UX57B 60" Rear Projection...
RCA HD52W56 52" Rear Projection HDTV Logo
16 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
