Question about Envision 19" Widescreen Flat Panel LCD Monitor
The monitor turns on and connects to my computer then turn off but the power stays on. any ideas?
I have a 9250 envision monitor and am trying to hook it up to my laptop. the monitor turns on fine and auto connects to my laptop but then after a few seconds the screen goes black but the led light still says it is on. any ideas?
    President:
  • 2,992 Answers
Make sure the external VGA port on your laptop is enabled. Not all laptops automatically detect a monitor connected and turn on the port. There will be a function key somewhere on the keyboard to control the port. Location varies by manufacturer and model. The usual sequence when you press the key is: laptop display on and external VGA off, laptop off and VGA on, both on.
Posted on Apr 17, 2009
My Envision LCD Monitor screens turns gray once its power on. I have tried changing contrast will not work.
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Mar 27, 2014 | Envision G22LWK 22" LCD Monitor
Envision H22W monitor will not turn on, light flashes
check for the source if connected, the vga cable if properly hooked up to the port. if ok then still display wont come on, unplug the monitor and then locate the power supply board of the monitor and look for a bulging electrolytic capacitor which is common problem of lcd monitors.
Sep 07, 2012 | Envision Computers & Internet
Screen is black when computer is turned on. Tthe monitor power button blinks, but when you push the button, the light does not stop blinking and the screen stays black.. The monitor was working and last...
Try a different video card or disconnect the one you have in your PC and use the VGA monitor connection on the motherboard. If it works your video card is gone.
Dec 22, 2017 | Envision 19" Widescreen Flat Panel LCD...
Monitor issue
Just sounds like the monitor cable is loose or bad or the input mode on the monitor is set wrong - set it to auto or step through the modes.
Aug 10, 2009 | Envision H191W Monitor
Monitor has no power,light does not light,ac power strip is good Is it worth fixing
Check your main fuse, if it still good check your capacitors from the power supply board. or you'll have to send it in to my shop so I can diagnose the problem and let you know how mch it will cost for repair.
Jun 04, 2009 | Envision EN-9250 19" Flat Panel LCD...
Envision Series / AOC 22 hdtv monitor
Probably blown capacitors, the 19" widescreen uses 6 16V 1000uF
Do you have a soldering gun? Its not that hard to fix, get the capacitors on ebay for $6-$8 with shipping.
Oct 31, 2008 | Envision 19" Widescreen Flat Panel LCD...
Envision LCD monitor
Most likely the 2 470uF capactitors in the power supply have leaked and partially shorted. If you have those replaced it should power up fine. The symptoms will be the green power light will come on and the backlight tubes will light up for about 1 sec then the entire monitor will shut off.
Dec 25, 2007 | Relisys RLT1720 17" LCD Monitor
Envision 17" LCD display will not stay on
Seems the N-Channel MOSFET switch in the power supply is the culprit. NTE does not list a replacement part for this, so a sub is necessary (any N-Channel 600V MOSFET in same TO220F case should suffice). I have to look one up for mine.
Jun 21, 2006 | Envision EN-7100e 17" Flat Panel LCD...
Envision 19" Widescreen Flat Panel LCD Monitor Logo
256 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
