Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Error code c-fb58
For my konica minolta bizhub c250 we keep getting a code c-fb58 error code any clues please thanks wazza
  • cardow May 11, 2009
    many thanks taminol you seem to be spot on  since posting the request for assistance on fixya the problem a was getting worse so had to call in the konica service people and they say the same as you have said., a new mainboard cost $3300. looks like konica is a heap of rubbish. i am extremly anoyed at the quality of the machine seeing that it has done very little work.
    once again many thanks for your expert assistance
    wazza
  • cardow May 26, 2009
    hi taminol
    many thanks for your help and suggestion to try to have the board serviced. i am in australia , but will contact the firm i think must be in usa by the web address, to see how much to repair. thanks for you suggestion will also try to locate a board repair firm in australia
    kind regards
    wazza
    Sniper:
  • 62 Answers
Hi Wazza,
CFB58 relates to an internal bus error on the MFP control board. To reset you simply turn the machine on/off (main swithc inside front door) If the fault reoccurs, you may need an engineer to flash your firmware/replace the MFP control board.
If it's the latter, I suspect it will be more cost effective to replace the machine. Average cost of a MFP board for your model is £1200.00
Hope this helps
Regards
Taminol
Posted on Apr 20, 2009
  • taminol
    taminol May 11, 2009
    Hi Wazza, thanks for the feedback. Wow, $3300 is expensive. Bearing in mind you are in the USA, have you thought of getting your board repaired. It will be a lot more cost effective. These guys offer a board repair servicehttp://www.hytecrepair.com/
    It's worth giving them a call to see how much they will charge.
    Regards
    Taminol
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
How do i clear error code C-D368 on bizhub C250 konica minolta
NVRAM= NON Volitatle Radom Access Memory. Need to have the firmware flashed and Mite also have the NVRAM replaced can not get on line secure Konica Minolta site. That Memory kkeps track copy count and certain machine info Serial Number etc.
Dec 04, 2014 | Konica Minolta bizhub C250 All-In-One...
How to solve error code C-D301 on bizhub C250
NVRAM Non-volitale Radom Access Memory is bad. Re-flash with updated firmware. Only from Konica Minolta secure website. If not have to have it replaced. NVRAM keeps meter count and certain important copier machine information. associated with that serial number machine.
Apr 17, 2014 | Konica Minolta bizhub C250 All-In-One...
How and where to solve /fix error code C-D301 on bixhub c250
here is the link
http://www.ebookbay.com/ebook/938/konica-minolta-bizhub-c250-sm
if you have any problem contact me.
Download
Dec 06, 2011 | Konica Minolta bizhub C250 All-In-One...
My konika copier error code c9401. How to clear code.
Try this steps
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
1 Check the flat cable for proper connection and
correct or change as necessary.
2 Change PWB-C.
Please let me know if you have any further questions or concerns.
Thanks.
May 03, 2010 | Konica Minolta bizhub C250 All-In-One...
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Error code C-D351 on a Bizhub C250
Hi
I have come across this kind of problem.
Is your BizHub on the network? If yes, please switch it off completely, and take the Ethernet cable out of the BizHub.
Wait for atleast 30 seconds and reconnect the cable. Now start the printer again and see if the error message goes away.
Hope this helps!
May 12, 2008 | Konica Minolta bizhub C250 All-In-One...
are you sure that you have a correct model and malfunction ccode ??? i cant find this code on bizhub C250
May 01, 2008 | Konica Minolta bizhub C250 All-In-One...
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Dec 12, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
457 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
