I have a GE monogram side by side that is warm. The fridge is at about 50 degrees and the freezer is at about 21. It is still making ice. any suggestions?
Hi - I just had the same problem on a 48 Monogram 1996 model.
The guys at the factory told my local service center that it was the main logic board ($200 for parts) and they replaced it, but that wasn't it.
It was the evaporator sensor. i don't claim to understand it all, but I think that the sensor is responsible for telling a heating element to turn on and defrost. If it does not do it's job, then frost builds up (You can feel the frost if you feel up in the freezer, up hight and in the front)) The frost keeps the cold air from getting to the fridge. Eventually the logic unit will freak out because ti is trying to keep the fridge cold, but the fridge send back that it is hot.
The repair guy may not want to replace the sensor because it is like an hour and half to get back in there. And it is a tight fit.
Check your coil. To do this on the back of the unit you should see a panel and some screws to remove. Remove those screws and look for a thin layer of Frost not ICE on the coil. If there is not frost on the coil the compressor is bad. If there is frost or to much check the fun and the thermostat
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE Monogram® ZISS420DMSS
GE Monogram® ZISS420DMSS Side by Side Refrigerator
My GE refrigerator/freezer icemaker is leaking water from the ice maker to the bottom drawer of the...
(More)
My GE refrigerator/freezer icemaker is leaking water from the ice maker to the bottom drawer of the freezer where the water is collecting and freezing in a thin sheet. How do I fix the problem?
The problem is the ice maker fails to make ice. I noted the green light was blinking so I shut it...
(More)
The problem is the ice maker fails to make ice. I noted the green light was blinking so I shut it off for a few hours and turned it back on. The light is now solid but not making ice. I am unable to find the model in the manual, although it is a 48" side by side.
Both sides of the refrigerator will just shut off for no reason. I had a new computer installed and...
(More)
Both sides of the refrigerator will just shut off for no reason. I had a new computer installed and once again found it off. No lights on the door, no power at all.
The CCD does not control temp - fan kicks on but temp only goes down - ultimately freezes everything...
(More)
The CCD does not control temp - fan kicks on but temp only goes down - ultimately freezes everything along with the water dispenser.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
