Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Saeco Italia sensor problem
"New" (refurbished) Italia worked fine for one day. Now flashes that the coffee grounds container needs to be emptied, even though it is empty. I figure a sensor is loose/defective/etc. Would appreciate any advice on where to look for the problem.
  • RobKaul Nov 29, 2007
    I have the same problem. It's intermittent, but so far no particular "jiggles" or cleaning and reassembling seems to solve the problem.
In order to reset this, you must remove the drip tray while the unit is powered up or it won't know that it has been emptied.
Posted on Feb 15, 2008
It does that after about 8 rounds of brewing, and it doesn't matter if you empty the grounds after every brew or not. It's automatic.
Posted on Jan 20, 2008
SOURCE:
I have a new to me Starbucks Italia. I have made a few shots and it is telling me to "empty grounds". I have done so but the empty grounds mssg won't go off and it won't function. what do I need to do?
Hi
When you want to empty the grounds because it says to in the menu, REMEMBER TO LEAVE THE MACHINE ON when you remove the drawer. The machine is a counter and when it reaches the magic number for that machine the message comes on. If the machine is turned off when you pull the drawer out, the machine doesn't know this and the message will be there when you turn the machine back on. Also remember to leave the drawer out for at least 15 seconds or a little longer so the machine thinks you actually dumped the grounds.
Oct 04, 2010 | Starbucks Saeco Italia Digital Barista...
Saeco Italia Digital Barista Fully Automatic Coffee Machine: I've had an Italia Digital for ~3 yrs. I keep it w...
Could be the burrs on the grinder are dull, instead of nice ground coffee it is producing crushed coffee.
May 18, 2010 | Starbucks Saeco Italia Digital Barista...
Saeco italia
Put a container under the steam pipe, open the steam knob and make a cup of water (Tea).
Hope this will help you.
Best regards
/Mirran
Oct 19, 2008 | Saeco Vienna Espresso Machine
Saeco Italia SUP021 YR - Red light #29 on solid
Not clear on "Empty bean container/full grounds drawer) - not empty/not full. " But I gather that coffee is not being dispensed. Most Likely the grinder needs cleaning + brew group needs cleaning ( filter ). Do you get water/steam?
Jun 10, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco italia
ok turn the machine on and wait till warmed up. Open door while machine is on and remove the dreg drawer. This you always need to do when the machine is on otherwise it will not reset.
flashing means dreg drawer steady means coffee beans
Apr 05, 2008 | Saeco Incanto Classic Espresso Machine
Saeco italia error
What happens when you open the knob on the right? It may just need priming.
Jan 21, 2008 | Starbucks Saeco Italia Digital Barista...
Barista leak
oh la la seal are big problem on those italia idont know if you had that machine for long you probabely need to reseale the machine be carefull for the amouth off money you spend on it sorry to say butt there not the best machine ton of problem you see alot of those italia refurbish for sale cheers
Jan 19, 2008 | Starbucks Saeco Italia Digital Barista...
Water in the coffee grounds drawer
Look for a leak near the brew group on near the piston area.
Changing the brew group should solve this problem.
http://cerinicoffee.com/item.asp?cID=0&PID=206
Johnny C
www.cerinicoffee.om
Oct 01, 2007 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
427 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Pierre Laplante
Info2011
Level 1 Expert
Steve Allison
Steve Allison
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
