Question about Marathon DJ-2000 Amplifier
Marathon power amps are they any good - Marathon DJ-2000 Amplifier
2 Suggested Answers
marsrover
  • 682 Answers
SOURCE: What does parallel mean on my marathon 3050 power amp?
parallel mean that you connect speakers wire together to amp(positive side with positive side and negative side with negative side)in this situation you got less resistance from speakers and more current.
i mean more sound level.
Posted on Apr 11, 2009
Marathon ENT-12P ACTIVE LOUD SPEAKER BURNING FUSE WHEN POWER ON, WHAT'S WRONG?
there is a dead short after the fuse
check for a failed/ burnt item
Aug 21, 2015 | Marathon Audio Players & Recorders
Motor red error light comes on, pump won't turn on
if power to motor bad pump motor if no voltage to motor bad relay
Mar 01, 2015 | Marathon Electric Marathon imPower...
My marathon ma-3000 professional power amp wont turn on
MAKE SURE TO CHECK YOUR REMOTE LINE, MIGHT BE BROKE SOMEWHERE. IF NOT CHECK THE CONNECTION.
Nov 18, 2013 | Marathon Car Audio & Video
I cant get the water temp below 125 and I need to for our day care. I have the lower thermostat set to 110 and it still is 125 to 130 degrees. Is there something else I need to do. There is a upper...
You have marathon water heater?
Thermostat is probably bad. Has gone out of calibration.
Replace both upper and lower thermostats for $25 from local hardware store, takes about 20 minutes, turn off power, take photo of wires before starting. These thermostats can be adjusted all the way down to 90 degrees, and then dial up a bit to reach 110.
Copy following link for instructions how to replace thermostat yourself.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If problem continues, then replace both elements.
Elements are special order made specifically for marathon.
Requires 1-7/8" socket to remove elements.
Upper 3800 watt, order part SP610130
Lower 3800 watt, order part SP210197
http://hometips.me/Mar/Rheem-Marathon-parts-2.pdf
http://waterheatertimer.org/How-to-replace-water-heater-element.html
More information about Marathon:
http://waterheatertimer.org/Review-Rheem-Marathon-water-heater.html
Gene
h
Aug 26, 2013 | Rheem MR105245 Marathon Electric Water...
Rheem marathon tripping breaker
Turn power off. Open covers and inspect for burned parts.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Test elements. Marathon takes specific element, and does not use generic element from hardware store.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Oct 27, 2012 | Rheem MSR50245 Marathon Electric Water...
Lost user manual for timex marathon watch 27 lap
I lost a user manual, then found these guys. They emailed it to me in about 2 hours and it only cost about £3, which i thought was very reasonable.
http://findmymanual.com/
Hope this helps.
Jane
Aug 26, 2009 | Timex Marathon Night Light Watch
Setting up my bands new pa!!!
You can work forwards from the mic to the speakers, or backwards from the speakers back to the mic.
The mixer and the amp both should have lights to indicate when there is signal present -- if you don't have lights at the mixer, then you won't have any sound downstream at the speakers. In this case, the problem is with the mixer or the sound source (mic or instrument)
If you *do* have lights at the amp, then the signal is getting that far, and the problem must be with the amp or the speakers.
Jun 02, 2009 | Marathon DJ-2000 Amplifier
Apr 11, 2009 | Marathon DJ-2000 Amplifier
Marathon DJ-2000 Amplifier Logo
683 people viewed this question
Top Marathon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marathon Audio Player and Recorder Expert? Answer questions, earn points and help others
