Question about Yamaha RX-V995 Receiver
No speaker sound when stereo off selected
The speakers work with all sound options except stereo off
The headphones via the headphone jack work ok with stereo off
  • rickdave Apr 17, 2009
    You provided an answer to a different question ie you answered to a question of "my speakers did not work"
    My speakers worked fine
    Its just that with "effect off" they did not work
    In any event I found out what the problem was
    It was that I had both speakers A and B switched in on the receiver
    ( I must have accidentally pressed this button in when I connected the headphones)
    With one switched out, which I have now done, the speakers do now work with "effect off" (and in all other settings)
    I really solved the problem myself but I dont mind paying for your suggestion as long as this reply does not incur another additional charge
  • 10,515 Answers
Hi rickdave,
 That's great and thanks for such a nice gesture.
  As you have solved the issue yourself, we really appreciate that. Infact we are glad. :)
 You can go ahead and select the option "Fixya' and close the thread.
Thanks for using Fixya.
Posted on Apr 17, 2009
    Sergeant:
  • 199 Answers
Troubleshooting a stereo system that is not producing sound begins with isolating the problem. Is it the receiver, the speakers, the source component or speaker wires causing the problem? Starting with the most common/most likely problems, eliminate the possible causes until the problem has been isolated, then proceed to correct or repair it. Note: Always turn off the power to the system when connecting or disconnecting cables and wires. Turn on the system to after each step to check for correct operation..
Here's How:
  1. Check Speaker Wires: Inspect the speaker wires from the receiver to the speakers and look for damage or loose connections. Pets can chew through speaker wires. Ensure that the speaker wires are firmly connected on both ends. Make sure that the insulation is adequately stripped on both ends of the wires and they are inserted far enough to make good contact with the speaker connectors. If the problem persists, move to the next step.
  2. Check Speakers: If possible, connect another speaker to the receiver and test the system. If it does, the speakers may be damaged or defective. If the problem persists, move to the next step.
  3. Check the Source Component(s): If you are using a CD or DVD player, try using the AM/FM tuner built into the receiver, or a tape player or any other source connected to the receiver. If the receiver works on some sources but not others, the problem could be the analog or digital cables between the source component(s) and the receiver. Replace the suspect cables and try the source component again.
  4. Check the Receiver: Make sure the receiver is plugged into the wall and the wall outlet is working. Make sure that the speakers are turned on via the Speaker A/B switch (found on the front panel of most receivers). If the lights on the front panel illuminate when turned on, the problem could be the amplifiers in the receiver. Try using a pair of headphones connected to the receiver to verify that the receiver is operating. If you hear sound from the headphones it means that part of the receiver is working. Make sure the correct source is selected on the receiver.
  5. Try Another Receiver: If all of the steps above do not work, it is likely that the problem is isolated to the receiver. If possible, connect another receiver or amplifier to the system and try again. If the system works, the problem is the receiver. Contact the manufacturer or service center for further advice or repairs.
another solution..................
  • Input source" is the device providing audio directly into the speaker or surround system.
  • "Audio unit" is the speaker or surround system main component with primary terminals.
  • "Audio components" include DVD, LaserDisc (LD), CD-ROM, Cassette Tape, Satellite Tuners, Game Players, VCR's, TV's, Record Turntables, or any other media device which may be connected directly to a primary Input source.
  • Audio cables: Stereo or Mono Audio Jacks
Note: Surround Sound units have multiple Input source Selection Switches which allow multiple Input sources. No Power
  • No power from wall socket. Check for socket wall switch and/or try different socket.
  • The power cord is not plugged in.
  • The power switch is not turned ON.
  • Cables are not fully plugged into audio modules.
  • No Sound
  • Speaker wires are not connected at speakers, or audio unit terminals.
  • Input source (DVD, LD, TV, VCR, Game, Computer) is not connected to audio unit.
  • Input source is not turned ON.
  • Input source output volume Muted, or Minimized.
  • Audio unit Master Volume switch is OFF, or Minimized.
  • Input source Selection Switch (applicable models) is different from cables connected to audio unit.
  • Optical cord is strained at connection (digital optic fiber models only).
  • No Sound
    some Speakers
  • Audio jack is not plugged in all the way, only half way.
  • Individual speaker wires are not connected at speaker, or audio unit terminals.
  • Wrong cable (mono speaker-to-speaker cable) being used instead of stereo cable.
  • Source audio output is Mono, but stereo cable is being used (get Mono-to-Stereo adapter or cable; sound is still Mono but all speakers will work).
  • Change MODE selection (Surround Sound models only; Center and Rear speakers are not active for all Modes).
  • No Sound Front Speakers
    for some Modes
    (Surround Sound systems only)
  • Left/Right Front and Rear Speaker wires reversed at audio unit output terminals (Rear Speakers are not active for all Modes).
  • Low Sound
  • Input source volume is Minimized.
  • Individual speaker control volumes are Minimized (applicable models).
  • Some or all computer source volume controls are Minimized.
  • Distorted Sound
  • Input source volume is Maximized.
  • Input source connection is a Speaker Out versus Line Out. Change to Line Out, or reduce volume on Speaker Out to very low level from Input source.
  • Audio unit Master Volume is Maximized (reduce to about 95% or lower).
  • Audio unit Subwoofer Volume is Maximized (reduce to about 95% or lower).
  • Computer source volume controls are Maximized for some sources not known to be active (default setting for some soundcards is automatically Maximum even for audio sources not in use or inactive). Open Advanced Volume Controls, Select Mute ALL, Save setting; then unMute ALL and activate only individual audio sources actually intended to be used, Save audio settings (never set any audio level above 95%).
  • Humming Noise
  • Input source is stereo, but Mono audio jack cable is being used.
  • Audio cables could be damaged or have short circuits.
  • Left/Right output from other audio components is crossed going into Input source.
  • Too many audio components connected to Input source at the same time. Turn OFF unneeded other audio components. *If problem continues, you may need to unplug certain components from overall system and obtain separate selection switches to select and deselect specific components from the main Input source (even when OFF some electronics audio circuits allow a certain amount of drain on audio signals which can weaken or distort overall audio output in combination with other components).
  • Shrill Feedback Noise
  • An audio source is feeding from output back into input at the Input source component. Check all component cables in and out.
  • A microphone input source is ON. Mute Microphone volume.
  • Check computer Advanced Volume Controls: Options, Properties, Recording. Select ON only those sources required (deselect or mute Microphone, and External Line In as needed). Also try deselection/mute of Midi and Wave selections on Playback audio settings.
  • Left/Right
    Sounds Reversed
  • Left and Right cables are crossed between Input source and audio unit input.
  • Left and Right cables are crossed from other audio components going into Input source.
  • Left/Right sound same
  • Original audio is MONO.
  • Mono output from the Input source (check settings).
  • Computer AWE64: access Advanced Volume Controls, Select 3D Stereo Enhancement, Save audio settings (AWE64 default setting is MONO).
  • Bass Volume Low
  • Original audio has poor Bass levels or no Bass at all.
  • Check Bass setting in computer Advanced Volume Controls.
  • Bass individual Volume control is Minimized.
  • Treble Volume Low
  • Check Treble setting in computer Advanced Volume Controls.
  • Treble individual Volume control is Minimized.
  • Remote Control
    Does Not Work
    (applicable models)
  • Remote Control batteries are dead, or very weak.
  • Distance to main unit is too far (Max distance ~7meters).
  • Angle of reception at main unit is too oblique (Max angle about 30-45º)
  • Remote Control is overheated by exposure to sunlight (store in shaded location).
  • Posted on Apr 17, 2009
    The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
    When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
    Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
    I have a CD Stereo system SA-AK17, 120V, 145W, without speaker. I provided 2 speaker with the brand of Technics, input 200W(.music), 100W(DIN) each speaker. I bought Audio wire and connect speakers...
    Some stereo system have the ability to switch off the speakers when playing via headphones. In others the headphone socket itself does the switching. However headphone sockets can become faulty and when the headphone plug is removed it doesn't restore sound to the speakers. It's very easy to fix this, with a check that the contacts are not bent out of place. Or you can rewire a new headphone socket, making a note of the wire connections before you replace it.
    Sometimes it is quite difficult to get the speaker cable to make a good contact with the speaker sockets. You should check that they are making contact.
    To test any loudspeaker just connect a 1.5 battery for a short time across the disconnected speaker. If working the speaker will pop!
    As the sound is going to the headphones the amp seems to be OK and one of the above options should correct the problem.
    Oct 27, 2017 | Panasonic SC-AK17 Shelf System
    Proscan 42" LED 120hz TV no audio out except with hdmi
    Look for the setup menu on the TV. It is common that you need to select either TV speakers or external speakers as only one will work at a time. If you want the sound to come out the audio output, you may need to select this option. Worth checking.
    Dec 08, 2017 | Televison & Video
    Acer aspire one sound not working
    Fix the headphone jack to contact headphone pin. Fix the speaker contact in headphone jack to get sound to speaker when headphone is not plugged in.
    May 23, 2012 | Acer Aspire One Netbook
    No sound out of Behringer BXL3000 speaker
    Suspected Faulty PC board Dead Capacitor Or Mod Pot I would suggest returning it for an exchange the problem is your speaker will work on a regular stereo because a stereo powers the sound internally causing the magnets in the speaker to vibrate Headphone jacks are designed to pick up off a seperate circuit board with a different connection to the main board hence the no sound from the speaker.
    May 04, 2012 | Behringer Ultrabass Bxl3000
    I have no sound
    Try different speakers which you know are working if possible.
    If the good speakers are also not working, then your Logitech speakers may be ok. Try plugging them into a different device such as iPod headphone jack, stereo headphone jack, etc.
    Let me know how you go.
    Hope this helps, Benji
    Sep 26, 2010 | Logitech X-240 Computer Speakers
    Sound through headphones only.
    Try the speakers on another computer, to see if they work at all. If they do, then the problem is the audio-interface on your computer (or DVD-player, or home-stereo system).
    Apr 05, 2010 | M-Audio Studiophile DX4 Computer Speakers
    No voices come out, sound is good, with headphones and speakers
    This sounds like a problem with your connection for your headphones. Your headphone jack on your notebook is stereo, which means that you need stereo headphones to make it work. If you look at the tip of your plug on your headphone cord, it will have 1 black ring, or 2 black rings. 1 black ring is mono, 2 black rings is stereo.
    If you are using stereo headphones, and you're still having this problem, your headphone plug is not going all the way into the jack on your notebook. Press the plug all the way into the jack and the problem should be fixed.
    If you physically cannot push the plug all the way into the jack, there may be a problem with the jack on your notebook that will need to be looked at.
    Hope this helps. Please take a moment to rate this solution. Thanks.
    Mar 15, 2009 | Compaq Computers & Internet
    Only hearing sound out of left side of headphones
    i think the problem is in the jack of your sound blaster. since you have already tried different headphones and the problem still persist, and when you use speakers it works fine. i conclude it is the jack of your sound blaster card.
    Dec 22, 2008 | Creative Labs Sound Blaster Live! 5.1...
    Using 2 Pc speakers on my Tv
    1)probable incompatibility issue--for comparison did you try a set of headphones? 2)The RCA audio outputs on the tv can go to an amplifier that has speakers attached,ie surround sound. 3)Caution==never try to alter vol level at spkr!
    Oct 02, 2007 | Toshiba 27DF46 27" TV
    Yamaha RX-V995 Receiver Logo
    76 people viewed this question
    Top Yamaha Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
