Question about SNK PD-2.3VIS Car Monitor
Wires on my pd-2.3vis are cut and i need new ones
Wiring pigtail input speed sensor on my 2000 sonata. The new plug came with three white wires but the wires from car are different colors. color wiring diagram ?
the connector is the same on both the old harness and the new pigtail. As long as you orientate the connectors the same way you just match up the wires. let me try to explain it this way. If you hold the old connector so the part that holds the connector to the sensor is facing up. Hold the new connector exactly the same way. cut the left wire on both and connect the new connector wire to the old wiring harness. Then cut the center wire and connect them. then cut the right wire and connect. No wiring diagram needed.
One thing I will add is to stagger the new connections. Meaning do nut cut them at the place. Cut one wire then cut the next about an inch or so further and then cut the next about an inch or so further than that. This will prevent the new connections from potentially shorting to each other and will keep the harness from becoming really bulky with all the but connectors in the same location.
Oct 02, 2015 | Cars & Trucks
Hilti pd 30/hilti pd 40
If anyone know I need one too for my pd 32
Jul 02, 2013 | Hilti Drills
My DB Drive pd 1200.1 amp shuts off when the volume is raised. What is happening and what should I do?
The vibration from the bass is cutting off the amp. it is a loose wire causing this issue. you can also get a stabilizer that will stop the vibrations from causing this issue.
Feb 27, 2013 | DB Drive Platinum PD1200 Car Audio...
Car starts but revs for a few seconds with lots of black smoke and then cuts out have disconected exhaust from manifold but no change
Is this a diesel TDI PD ?? If so i had the same problem with one of these TDI engines and traced it to the crank sensor signal implausable. The revs would start increasing with no pressure on the throttle, lots of black smoke and then cut out. The crank sensor wiring was at fault in this case. The ECU didnt know where the crank position was in relation to the camshaft and was guessing when to inject the fuel. Hence the black smoke ! Hope this is of some use.
Nov 08, 2010 | 2000 Audi A4
Need schematic for maytag neptune mah3000aww
Here is a complete illustrated parts listing with wiring schematic diagram for the model washer you have listed:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=MAH3000AWW&sid=MMLxMerchandizexManualsModelxmah3000awwxMAH3000AWW
If you need further advice, please let me know. I hope this helps you.
NOTE: If the link does not take you directly to the website, cut and paste to your web browser.
Aug 12, 2010 | Washing Machines
Trouble codes
You might want to check for a mouse nest under the Underhood fuse block, seen them chew up wiring under there many times.
Nov 04, 2008 | 2002 Chevrolet Silverado
No disc
When the Astar PD-3010 or the PD-3020 shows no disk it mean that your DVD laser are defectived. Need resolve this problem? Please call me at 323-767-6030.
Dec 26, 2007 | Astar PD-3010 Portable DVD Player
SNK PD-2.3VIS Car Monitor Logo
53 people viewed this question
Top SNK Car Audio & Video Experts
xxxxxx xxx
Are you a SNK Car Audio and Video Expert? Answer questions, earn points and help others
