Question about Ovens
After a recent power failure When I try to turn my gas oven on it displays 'off'. How can I get my oven to turn on.
  • craig_better Apr 17, 2009
    I tried this and it didn't work. I'll give it another try.
    Finally found the owners manual. Press 'Cancel' and 'Stop Time' pad for 3 seconds. This will turn the 'lock' feature off.
    Apparently, the 'lock' got set when the power went off and the only way to reset it was with the above procedure.
  • 10,865 Answers
Kill the power to it by either unplugging it or turning the breaker off. Generally, this will reset the systems and you will be back in business
Posted on Apr 17, 2009
No gas to the burner or oven
Hello deodatramdin - If both the range and oven are not working, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. While the unit is turn off, confirm that the shut off valve on the gas pressure regulator is in the "ON" position (typically located on the back left-hand side of the range). This valve shuts the gas off to the oven. Once you have verified, turn the range back on. If it proves to be ineffective, then the range could possibly be experiencing an issue with the EOC, wiring failure or faulty power supply. Contact a certified technician to move forward accurately and to assist with the repairs.
Jan 30, 2013 | Frigidaire FGB24S5A Gas Single Oven
I went to do a self clean on my oven and I opened the door right as it was trying to lock. The door was open when it locked so the lock is out and now I can't shut the oven door. I tried turning off...
give this a try:
  1. Disconnect power from unit for a couple of minutes.
  2. Re-apply power.
  3. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
If this does not work, let me know what error code appears on the display. It should have be an F code with 1 or 3 numbers.
May 28, 2011 | Ovens
My Westinghouse 668 oven turned off in a recent power failure. I need to reset the time so the oven will work. How do I do it?
A lot of the time, particularly if you haven't got a manual, it is trial and error. I normally turn the oven to on. I then watch the oven indicator light as I manipulate the timer buttons/controls. It sometimes takes 5 to 10 minutes. Just try all different combinations.
Feb 12, 2011 | Ovens
KitchenAidKEBS107: NO HEAT after power failure during self clean
Thermostat on the back needs replacement. The problem is caused by overheating the oven. Improper installation or inadequate blower. Depending on the model, the oven might need a new blower in addition to the thermostat. Try calling KitchenAid to find out if the oven needs that blower and get the part number for the thermostat, they might have replaced it with the one with higher temperature rating.
Nov 26, 2009 | KitchenAid KEBS177 Electric Single Oven
Came home from trip tp find oven display flashing E1-F1- Oven will not turn on and cannot clear display! Even tried turning breaker off and back on!!Please Help
the e1 f1 failure means an internal control failure. which means you will need to replace the control board.
usuallly it will cost about 125-150 bucks.
Feb 23, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven comes on of it's own accord following power failure
no you are not over reacting that could have burnt your house down I would demand a new one sometimes you just got to be pure hateful with these manufacturers and tell them you going to give bad ratings all over the net hope you get somewhere with them Please give high rating
Jan 05, 2009 | Ovens
Fiigidaire gas oven trips power when I turn oven on
disconnect the wires going to the oven ignitor,turn the unit on see if its trips.if so the ignitor is shorted if not then disconnect the wires that go to the coil of the gas valve and do the same.i think either one of these is your problem.also if theres a fan in the oven do the same.
Jan 05, 2008 | Frigidaire FGB24S5A Gas Single Oven
No indication on display module - apparant loss of power
Did you check the power cord.
Connection(s) could have been fried during power surge.
Dec 27, 2007 | Ovens
Gas stove works, but oven does not
yes replace the ignitor, this is the most common failures of ovens not coming on.
Dec 10, 2007 | Whirlpool SB160PEE Gas Single Oven
Ovens Logo
88 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
