Question about Sterling Plumbing 1500D-31S VISTA PIVOT SHOWER DOOR
Parts for sterling shower faucet
I have a sterling faucet that is leaking. I cannot find the parts, the cartridge or any other parts for this in any store, home depot, lowes, etc.
Where can i get the parts for sterling shower faucet?
Thanks.
  • tapaskumar Apr 17, 2009
    Thank you very much for the information.
  • 659 Answers
Http://www.sterlingplumbing.com/contact.strl
The above link is the contact info for Sterling Plumbing Company. You can contact them and they will either be able to mail the parts out to you directly or tell you where you will be able to find repair parts.
Posted on Apr 17, 2009
How do I fix hot water handle that is leaking on Moen Banbury ca87000 sink
The valve cartridge needs replaced. Those can be purchased at most home improvement stores, such as Home Depot. Or, it may be under warranty.
http://www.moen.com/replacement-parts/search
Nov 17, 2014 | Plumbing
Handle leak
You need to replace the "guts" go to your local hardware store (Lowe's/Home Depot) and go to the plumbing section. They should have replacement parts for your faucet.
Apr 28, 2013 | Plumbing
Leaking Kohler Vinnata kitchen faucet.
you must use genuine kohler parts,if you got something from lowes or home depot that was some other brand they usually leak. also look for calcium build up inside the valve body,you can use 1500 grit wet sand paper to remove it just be carefull and dont sand too much,then apply water proof plumbers grease inside the valve body befor you install the new cartridge.
Nov 08, 2012 | Kohler K-690-VS Vinnata kitchen sink...
Faucet leaks
Depending on what exactly is leaking, you have a couple options. Many new faucets have a replaceable cartridge, which can often be picked up at a Home Depot or Lowes type of store. If not you may need to replace the faucet as an assembly.
Dec 18, 2011 | Kohler Plumbing
Delta faucet model #25919. The center of the faucet leaks. Not at any of the connections. The water comes from under the faucet.
Either the left or right seals are leaking (within the handles). You can get replacement parts (seals, rings, cartridges) at Home Depot.
Apr 15, 2011 | Delta Plumbing
Water is coming out around the button on top of the pull out spray
if water is coming out on top you need to replace the cartrige. If the button ontop is broken or faulty then the whole handle assembly needs replacement.
The good news is you can replace these parts for free without a receipt. Almost all these faucets carry a lifetime warranty. Simply turn off the water supply at the faucet, then remove faucet and take it to your local plumbing supply store. e.g. Home depot, Lowes, Rona, etc.etc.
Feb 22, 2011 | Hamat 3-2861ST Everest Pull-Out Kitchen...
Leaking bathroom faucet
These single handle faucets tend to need the internal "O - rings" changed every couple of years. Find your model # and take it to Home Depot or Lowes or some similar store and find the "kit" compatible with your faucet. Some kits have a cartridge, some have springs, O - rings, etc. The kit will have instructions on how to remove tha old one and install the new one.
May 24, 2010 | Delta Model 470: Signature Kitchen...
Fix diverter valve sprayer No water pressure Can I soak in CLR? Where to buy Parts ?
CLR usually works great. Replacement parts are available at Lowes Home supply stores and perhaps Home Depot. I've had better luck getting parts at Lowes.
Mar 09, 2010 | Price Pfister Marielle Kitchen Faucet with...
I have all 3 new shower valves purchased from home depot to replace old and they are all leaking from the threads where you tighten down vave stem.Ive tried thread tap they still leak...
Most Price Phister valve cartridges have a plastic washer or "O" ring at the base of the cartridge, where it screws into the valve body. Replacements should be available at H/Depot, Lowe's/similar.
Regards, --W/D--
Jul 13, 2009 | Price Pfister Plumbing
Sterling Plumbing 1500D-31S VISTA PIVOT SHOWER DOOR Logo
4,792 people viewed this question
Top Sterling Plumbing Home Experts
Donni Steen
john h
Mike
Are you a Sterling Plumbing Home Expert? Answer questions, earn points and help others
