Question about Refrigerators
Water from defrosting unit in freezer is draining inside the bottom of the refrigerator ,not in the water pan under the unit
  • billarnold82 Apr 26, 2009
    I've had this problem for a couple of years. The drain pan under the freezer backs up with ice not allowing defrosted water to drain into the drain chute and down to the tray under the refrigerator. I've defrosted the entire box several times which melts the ice and allows it to function properly for a week or two before the ice builds up and clogs the drain again. I don't know what is causing this or how to repair it permanently. Any help would be appreciated.
  • 358 Answers
That means the drain hole is clogh in the bottom back inside the refrigerator.Put hot water in until it goes through, the best way to clear it is blowing presurise air through it but i8f you don't have acompresor you can do it very careful sticking a wire until it goes through to the drain pan and once in a while put bleach through the hole to keep it clean(every 3 or 4months).
Posted on Apr 17, 2009
Why is water coming out under the refrigerator?
Maybe the freezer defrost drain is blocked. Sometimes the water freezes in the drain and the next time the defrost cycle occurs the water can't drain correctly. Is there any water inside the refrigerated section of the unit? Also there may be a catch pan under the fridge that is misaligned or out of place or the drain line isn't positioned to place the defrost water into the pan. Most modern refrigerators are frost free and defrost the freezer on a regular timed cycle. This is why your ice cubes shrink and stick together and why you get freezer burn on the food left in them for extended time.
Jan 25, 2015 | Maytag Refrigerators
Water leak self defrosting
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website). If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
Mar 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice builds up in freezer bottom pan, not going down the drain tube. Is this an indicator of the defrost timer not working correctly, and if so where is the drfrost timer on a ETIFTTXKT02 model?
Defrost timer is working or there would not be water/ice in the bottom pan (as you describe it.). Check that the drain tube from the pan to the bottom evaproation tray under the refrigerator is clear of restriction.
Dec 14, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Mine collects water under the crispers also.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
Aug 17, 2009 | Kenmore 64802 Top Freezer Refrigerator
Our upright freezer drips water on the floor. We believe the seal is bad since ice also forms inside at the top of the door. Is the seal replaceable or should we buy a new unit?
Self-defrosting refrigerators/freezers dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 16, 2009 | Freezers
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Ice forming bottom of freezer leaking out the door
It is acutually a collector pan for the drain hose. When the refrigerator runs a defrost cycle (about every couple days), that pan collects the water from the ice that is melted and drains it through a hose inside the unit, to a pan under the unit. You will have to pull the back panel off the back of the freezer and melt it with either hot water or a hot blowdryer. Do it until you see the water draining freely into the bottom pan.
Oct 18, 2008 | KitchenAid Superba Architect KSCS25INSS...
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
